Question about Sony Playstation 3 (PS3) Console
The fan on my ps3 came unplugged. Now it turns on for just a few seconds, beeps, flashes the yellow light, then turns off. I just want to know how to fix it. Thank you.
    Genius:
  • 1,622 Answers
Try unplugging it for AT LEAST 2 min this will reset it. this cause of overheating.
Hope this helpout.
Posted on Oct 16, 2010
My Sony PS3 will beep three times and shut down on its own shortly after it is turned on, any idea what it is?
It sounds like the "yellow light of death". After beeping three times does it flash to a yellow light at all? If so your hard drive is no longer good and will either a. need to be replaced by a professional, or b. buy a new ps3.
It is what we all fear on the ps3.
If there is no yellow light, the ps3 is probably just doing a hard shutdown because something is freezing. a few things you can try are. 1. put in a different game, loading that game may be whats causing it to freeze. 2. do the fan test to make sure its not overheating
Aug 26, 2011 | Sony Playstation 3 (PS3) Console
My PS3 (40Gb) has just shut down on me. I was playing COD Modern Warfare 2 when the PS3 just shut down and then beeped at me 3 times the red light started flashing and when I pressed the power area the...
Its called yellow light of death. Here is a link to my step-by-step instructions on how to fix.
http://www.fixya.com/support/t8396931-ps3_turns_ok_but_turns_itself_off_after
Feb 24, 2011 | Sony Playstation 3 (PS3) Console
After pressing the on button it turns green for 5 seconds then it flashes yellow/orange for a second then it flashes red.
Yellow Light of DeathThe "Yellow Light of Death" or YLOD is the common phrase people use to describe the following sequence when they try to turn on their PS3:
  • Press Power Button
  • Red Light Flashes Three Times
  • Yellow Light Flashes
  • Green Light Flashes
  • Beeps Three Times
  • Red Light Flashes
The sequence above may vary a bit but you do see the flashing yellow light (sometimes shows up as orange) that normally you would not see when operating your PS3. The YLOD is a general hardware fault that can mean a lot of things. However, one of the problems is cracked solder that leads the PS3 to think one of its internal chips is not connected or is broken somehow. Cracked solder can happen when the chips get too hot (RSX most likely) and leads the motherboard to start bending, which may crack the solder. Changing the power supply (lower the average wattage going to the chips to lower the heat) and better thermal compound (heat dissipates faster to the heatsink) may prevent this error from occurring. However, if your PS3 has already had the YLOD, then you can reflow your motherboard every few months to keep it working (but it is not a permanent fix as the YLOD usually comes back).
Oct 09, 2010 | Sony Playstation 3 (PS3) Console
When i turn on my ps3 it starts up fin and the frezzes then a yellow light flashes and then turns of
have you tried this?
Turn the console off at the back switch for a few minutes. Then switch it on from the back, then hold the Power button until you hear a second beep. If your PS3 is completely stuffed it probably won't do this, but there's a chance it might let you into the recovery menu which will let you do a format or System Restore and hopefully get your machine running again.
Is there any green or red flashing lights?
Hope you don't have the yellow light of death.
Apr 08, 2010 | Sony PS3 40GB Best Sellers Bundle Console
My playstation has the light trun green yellow flashing red light
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
Jan 22, 2010 | Sony PlayStation® 3 (80GB) Console
Ps3 turns off beeps twice but there is no yellow light only red!
The yellow light is also know as the yellow light of death casued by a hardware failure. It can be casued ny over heating a bluray drive failure, a hard drive failure or even a powersupply failure. You know you have it when you power up the yellow light flashes then you hear some beeps then the red llight flashes. I would suggest returning it if you have that option or getting it fixed somewhere else as a last option.
Jul 16, 2009 | Sony PlayStation® 3 (60 GB) Console
I was just playing a game on my ps3 and it shut down, so i tried to start it back up. it turned on then seconds later it went yellow then to a flashing red light with the three beeping. the fan kicked in...
Same **** happened with my PS3. So I returned it, and got the newer version of it. I went home and plugged it in: The fan came on along with a green light. BUT THEN..... 5 seconds into it, the damn thing shuts down and flashes red along with the three beeps. Not to mention the yellowish orange light. Even the brand new version did the same ****. I am in your same position and I would love to hear a way to fix this. Pretty weak.
Jun 28, 2009 | Sony Playstation 3 (PS3) Console
My PS3 wont turn on it just flashes a yellow light then red light that beeps cant get disc out
I found a way to eject the disk:
  1. Power off the PS3 on the main switch on the back of the console
  2. Press and hold the Eject button
  3. Turn on the main power switch
  4. The PS3 LED will go green and the fan will spin at max speed
  5. Wait a few seconds and press the eject button a couple of times, the disk should now eject
  6. watch the PS3 die after 30s or so…
This procedure did not fix my PS3 but at least I got my disk back before sending it to Sony for repair.
Jun 10, 2009 | Sony Playstation 3 (PS3) Console
PS3 shut down during mid-game/now it will not eject the game disk
not a solution but a possible answer it is possibly the ylod (yellow light of death) it seems a few people are getting this and my ps3 has broke aswell even sony dont know what is wrong with it. but your problem sounds like the ylod
Jun 07, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
24 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
