Question about Maytag Bravos MTW6600T Top Load Washer
My Maytag bravos is 2 months old and the very bad smell from the tub does not seem to be getting any less....can't place it but, it is a cross between rubber, mildew and/or stagnant water...the machines drains and cleans of but, this smell is very bad....does this go away? Can I use something to make it do away? Thanks, George
  • 4,348 Answers
George, there is a cleaner available, usually this issue is present on front load washers.
Posted on Oct 16, 2010
Maytag Neptune MAH5500 smelled like burning plastic at the end of the cycle. (The whole basement smelled bad.) The smell seemed to be coming from the plastic part at the top where it latches.
Tub bearings get worse, if they faulty, the machine would be noisy and getting louder. Sudden burning smells usually mean an electrical failure of a component but if this has stopped and the machine is working properly, its possible that something has got caught up in the rim of the tub or gasket area and during spin it has got "burnt" by being dragged around the edge. Have a close look at your clothes that were washed on that day for signs of burning or damage and around the top at leading edges of the tub for signs of melting or damage.
Mar 21, 2017 | Maytag Washing Machines
Maytag Bravos 300 tub stuck down
if this is a washer you should not have to remove the tub unless re placing seals and bearings!
Jan 29, 2018 | Maytag Dryers
Maytag Washing machine; Bravo,not filling up with water.
what is your model number is then we can get started okay
Jan 01, 2013 | Maytag Washing Machines
Maytag bravos washer- bleach compartment wont drain during wash cycle
The solenoid that turns on to dispense the bleach is bad, or you have a clogged tube that goes from bleach dispenser to tub.
Apr 29, 2012 | Maytag Bravos MTW6600T Top Load Washer
I Bought a Bravo series 300 Washer and Dryer 18 months ago. They came with a 1 yr. manufacture warranty The first month I had problems with the dryer which was covered under warranty.. It was inconvenient...
hi,
usually most areas have a USED appliance store. usually these guys will have a bunch of old fridges and stoves around outside the store. Our town has three or four of them. you may have to ask around but these guys usually have parts for cheap. and they will sometimes make house calls. try googling used appliances in your area. they may also set you up with a cheaper washer with a METAL tub.
good luck
jm
Nov 15, 2010 | Maytag Bravos 3.8 Cu. Ft. Washer
My Whirlpool Estate Top Load washing machine is less than a year old. The last few months it has begun to smell really bad between washings. I leave the lid up but that doesn't help. The clothes don't...
Chances are there is mold forming in the outer tub, put two cups of bleach in the tub, set the water level at highest setting and run it in heavy wash mode. Do not add any laundry, that should help kill the mold that is causing the smell.
Oct 09, 2010 | Washing Machines
Bravos Dryer blinking start button
Manual says it could be a number of things, and you should have a copy of the manual since you've only had the dryer 3-4 months. If not, go to the Maytag website and download.
Some things to check -
1) Press Start/Cancel if dryer was stopped in a middle of the operating cycle.
2) Check that one of the two breakers has not tripped or fuses blown (if an electric dryer) in your breaker panel.
Please reply the flashing code number so that I may can help you further.
Jan 19, 2009 | Maytag Bravos 7.0 Cu. Ft. SuperSize...
Maytag Bravos MTW6600T Top Load Washer Logo
835 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
