Question about Fisher and Paykel Washing Machines
My washing machine is a pride 5.5 version, I have removed the water pump, there was nothing lodged in it at all, i checked the pipe and its clear, it pumps out water to the last bit and it wont go no further, there is still a small amount of water in the bottom of the bowl , the pump is trying to pump it, small amount of water comes out it does this for a little while then the maqchine starts to beep continously what else can be wrong with it?. Sue
  • Fisher and P... Master
  • 713 Answers
Hi Sue just read your posting.Now when the machine beeps a series of lights will light up.These lights will be in a row of 8 lights.Starting from the left to right which lights are lit when the machine is beeping,Is it the 1st and 3rd or the 4th and 7th ---etc---?Please reply with this additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Posted on Oct 16, 2010
  • 1 more comment
  • slettey Oct 16, 2010
    Hi I found out the lights that are lightning up with the continous beeps is light 3,4 and 7. I think there is a blockage between the bowl and the outside plastic casing as when the pump is trying to pump and when it pumps it does itr a couple of second intervals, causing the water to move inside of the movements and i heard something inside move like a metal fragment moving around, as i do a metal job at work and have some metal work on my clothing and something has lodged into it somehow, and i work at home and always leave , accidently things in my pocket, like smakll screws , nails etc. So if that is the case i will have to take the machine out the shed and try and see if i can get to the inside casing to remove the object, if that is what you are thinking of too. like i said I can hear something when the pump has moved water around trying to pump . So if it that problem how the hell do i go of removing the outer skin to get it
  • luisa_sgro Oct 17, 2010
    Hi just read your posting.Unfortunately the drain pump has nothing to do with the error code your machine has indicated.The error code on your machine is error code 50.Which is called hot valve fault.To confirm the information could you please supply me with the model number of you machine which is located on a sticker at the back of the machine top left.Now on the issue of removing the bowl to remove the metal objects I can guide you once you let me know the model number of your machine.Hot valve error code could mean that either you hot valve is faulty or the wiring to it is faulty or the control module is faulty.Just to be sure, the lights that are lit up when the machine is beeping are ,Starting from the left to right are 3,4 and 7,Is this correct.Looking forward to your reply with additional information.
  • slettey Oct 17, 2010
    Thanks dude you are a great help for me. Ok, i had a look and the sticker on the back, its says model number MW059AU. And yes the 3,4,7 lights are on when it beeps continously. I did the diagnostic mode by holding down the water temp down button and the power at the saame time, and then made the speed show up with slow and hold light on light up, and the same lights come up with lights on for 3,4, and 7 as well. Thats strange how the hot water valve can cause that, as for one i dont even use the hot water at all, but maybe as you said it could be a dodgy control board, and if so i am going to up for a lot of money arent i?. Is it complicated to remove the inside thing to clean out these foriegn objects?. between the bowl and the inner skin?. Anyway I can take my time to do this i bought another fisher yesterday on ebay ,so i can wash and fix this one and sell the other again. If i can fix it. Thanks mate for your help again.
    I love doing this ,its fun i would like to learn properly how to fix them. Sue
Water left in washer after a total washing
Usually what happens here is that the pump to expel the water is not functioning, the normal problem here is a coin or hair grip gets lodged in the pump and stops the impeller from turning, generally the pump can be removed and opened up to remove the offending article and allow the impeller to operate again, once cleared of obstruction reassemble the pump and refit it. ( be aware, as the machine is still full of water, when you remove the pump the water will flood out so you need plenty of towels so soak up the water that spills.
Sep 23, 2016 | Kenmore Washing Machines
My lg intellowasher 7kg wd-10130f does not pump and always stop and pre-wash , time lights become flash
Have you check the trap for something lodged in it, if there is water in the machine you can use the small hose next to the trap to remove the water from the machine before opening the trap. If you don't know about the trap read the owner manual. If you need help after that please feel free to contact me.
Mar 29, 2014 | Washing Machines
MY WHIRLPOOL WTW5300SQO WASHING MACHINE WONT DRAIN WATER THE OTHER DAY IT WOULD NOT SPIN TO WRING THE CLOTHING THERE WAS A SMALL GARMENT LODGED IN THE SPIN BASSIN(?) WE TOOK IT OUT NOW THE WASHER WILL NOT...
Could be filter is blocked. Or drain pipe is blocked.
Fact it wouldn't spin, could point to blockage, as spin won't start if too much water in drum. Bad news is, it could be the water pump needs renewed.
Make sure drain pipe is properly connected to the waste pipe, and clear of obstruction.
Jan 16, 2013 | Washing Machines
Trying to find pump.
Hi - I understand you will like to know where to find pump and check for clogs. Try the following steps below and hope it is helpful:
To completely clear any clogs in the washing machine drain you will use a pipe auger (snake). Start at the roof plumbing vent and drop cable to roughly 10 or 15 feet past the actual drain. If there is a clog present, the snake will bring up a chunk of debris. Remove it from the top of the vent and discard.
The drain hose is visible toward the bottom of this washing machine. It is held in place by a clamp or a couple of screws.
Remove the drain hose from the back of the washing machine. This is normally held in place by a clamp or a couple of screws. When a drain backup occurs, pieces of debris can lodge in the hose, causing clogs and odors.
Soak the hose in a bucket of warm bleach water.
Soak the drain hose in a bucket of warm water mixed with 1 cup of bleach. Look to see if the line is free of obstructions. Run a small length of clothes hanger through the hose to clear any hard debris.
Reattach drain hose and connect to drain pipe.
Reattach the drain hose using a screwdriver or pliers. Insert the hose into the washing machine drain. Be sure it is all the way into the drain opening.
Run the washer through a full cycle with 2 cups of bleach added.
Cycle the washer with warm water and 2 cups of bleach. The bleach will help remove any odor-causing particles in the machine and drain hose. Running the washing machine through a cycle will help flush away any remnants of the drain pipe clog.
Oct 12, 2012 | Frigidaire Affinity ATF7000E Front Load...
Nd error Washer will not drain. Had this problem before and removed coins from the pump all worked well. Now however there is nothing lodged in the pump and it will not drain.
get something to catch water in, then disconnect the outlet pipe and hold it as low as possible to the floor if water drains out, the pipe should be clear of any blockages. if it is re,connect the pipe...next turn the washer on and put it on empty cycle if you can hear the pump motor running and ,still does not empty the pump is probably damaged,if it is you will have yo have it checked out by the repair man
Jul 24, 2011 | Washing Machines
Just purchased a Whirlpool Cabrio top load HE washer. It filled with water then would not drain. Now it is not working at all. It is plugged in, water lines are good, etc. The display panel works. I let it...
You need to chech inside the machine if water is still inside the tub.(ie.is it draining?). If not, there is the problem. All the programs are sequential and if one part malfunctions, it wont proceed to the next part of the cycle. So, after pulling the plug out of the socket, follow the drain pipe to the drain pump motor. You need to remove back plate first. then check the filter for fluff or if it is clear, you need to remove the pump off the washing machine body then unscrew the plastic pump section to gain access to the impellar that very possibly has something lodged in it. Once removed, reassemble then retry. Should be ok.
Aug 20, 2010 | Whirlpool Washing Machines
Water will not drain humming noise
Humming sound could be jammed pump.Remove th filter and check pump Blades are free, nothing is stuck in it....
Nov 25, 2009 | Washing Machines
We have a bosch washing machine and cannot open the filter
If the filter will not unscrew there is an object preventing it from doing so. There are two options to fix this. Firstly try turning the filter one way then the other to try to dis lodge the item. This usually works after a few attempts but if not you will have to remove the large black pipe from the pump and try to remove it from there. There will be some water in this pipe!
Hope this helps.
Thankyou for using Fixya.
Jan 17, 2009 | Bosch Exxcel WFO 2264 Front Load Washer
Hotpoint aquarius wf340
First remove the filter (if you can do this easily) - place a roasting pan under it to catch the water.
If you cannot get to any filter, remove the rear pipe from the waste pipe, and check it is not obstructed.
If it looks good enough, try a hot wash with 1 cup of soda crystals. This should clear any accumulation of grease in the pipes.
If still no good, you may have to open up the machine to clear any internal filter before the pump, and check pump vanes are still intact.
Nov 05, 2008 | Kenmore 13202 Top Load Washer
Washing Machines Logo
67 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
