Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Water come from my fridge - GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
  • dennis dodge Oct 16, 2010
    need more info and complete model # water from the frig ? if sxs the water would come from under or back or inside the freezer . now if under neat it could be a line or water valve and if inside the freezer it may be a pluged drain and or the ice mker itself . help me to help you i need more info . hope some this helped ouy with this problem mm
    Genius:
  • 1,157 Answers
Hi sharifmorgan,
If your experiencing water on floor outside the refrigerator it might caused by the drain pan. There are some ways on how to correct this issue, either you clean the pan and reposition tray. In addition, here are some tips that you can apply to solve this problem. Please follow the steps below.
Before conducting any repair, please remember your safety. Unplug the machine or shut off the power at the breaker panel to avoid any electric shock.
1. Remove the drain pan and clean it with a warm soapy water or water and baking soda.
--> the drain pan is located at the bottom of the refrigerator behind the front grill.
--> Please remove the grill which snaps into place. Hold the drain pan while pulling slightly upward and forward.
2. If you noticed that the pan is too closed to the compressor please reposition the tray.
3. You may also try to check water invelt valve. It is located behind the refrigerator. Look for a water supply line coming into the valve and turn it off at the source. Now disconnect the supply line. It has screws so you need to remove them.
4. The water inlet valve is connected by two wires. Before disconnecting the wires please label the wire placement on the water inlet valve.
5. The wires are connected to the terminal with slip on connectors. Firmly pull the connectors off of the terminals ( don't pull on the wire ). You can use a pair of needle-nose pliers to remove the connectors. Please check if the connectors and terminals has corrosion. If corroded they should be replaced.
Hope it helps.
Thank you for using FixYa.
Posted on May 11, 2011
Why is there water on top shelf in fridge
I would guess the fridge is not set level. A small amount of water is normally meant to condense and run down the back of the fridge and then evaporate outside the fridge.
If either the fridge is leaning forward slightly or if anything on the top shelf is touching the back of the fridge, then instead of running down the back of the fridge water may instead end up on the top shelf.
Assuming the fridge is still working in every other respect then this is what I would suspect.
Aug 25, 2014 | Max-Fridge Refrigerators
Ice tastes bad
If It were me I would change the filter in the fridge, that always worked on mine.
Dec 03, 2013 | LG LRFD22850 Bottom Freezer Refrigerator...
Water dispenser and icemaker not getting water on a maytag fridge
pull line off of the back of fridge to see if water comes out if not its where ever you have that line taped into yuur water supply for the fridge had the same problem hard water clogged up the tee off take it off poke some thing in the little hole make sure you have the water shut off to the water supply when was the last time you changed the filter in you fridge it could be tht too
Nov 12, 2011 | Refrigerators
Water come's out to slow? changed filter! was doing it before i changed filter!
James -
Check to make sure the valve for the water supply is on fully - and not between the ON and OFF positions. If that is ok, the water supply line may have become restricted when the fridge was pushed into position the last time it was rolled out (for cleaning, etc.). The line may have become kinked (usually a copper line problem) or partially crushed (copper or plastic) under one of the fridge's rollers.
You should close the water valve before moving the fridge for inspection. Unplug the fridge. Disconnect the water line at the back of the fridge. Inspect the length of line for evidence of a crush or kink. Replace as needed. Test the flow of water into a larger container before reconnecting to fridge. If close to the fridge output, the valve and line to the fridge is suspect. Replace parts one at a time as needed until the problem is solved. If there is significantly more flow than when connected to the fridge, then the problem is somewhere in the fridge - but outside of the filter - there's little to change or go wrong for a "slow flow rate". It's usually an "all or nothing" deal inside the fridge.
Reassemble, turn water supply back on (check for leaks), plug into power, carefully roll fridge into position (watch the water line as long as possible to prevent crushing / kinking) and test.
Please rate this reply if helpful - good luck!
Aug 09, 2010 | Kenmore 77719 Side by Side Bottom Freezer...
It leaks water from underneath
If the water is coming out from under the fridge and you have a water dispenser or automatic ice maker, then I would suggest that you pull the fridge out from the wall and check the water tubing going to the back of the fridge. The tubing is connected with a compression fitting (a special nut that compresses the tubing to the fridge. There may also be a few more pieces of tubing on/in the back of the fridge with these fittings. Place you fingers on each fitting to see if it is loose or wet. If you find a wet or loose fitting, take some pliers and tighten it (snug it up, but not too tight because you can damage the fitting. Dry up the water. Watch the fridge for a while to make sure the leak is stopped. If you can't get it stopped, or if it gets worse, you can cut off the water (there should be a valve under a cabinet next to the fridge, or under your sink). You can get a replacement fitting at Lowe's2_bing.gif and they can tell you how to install it if necessary. If you have water pooling under your fridge and it goes up to the wall, then you should check on the other side of the wall for water also. This happened to our fridge, but we did not see the water in front of the fridge because it ran to the back of the fridge and under the wall into our carpet on the other side. Wet carpet is how we discovered the problem.
May 05, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water is coming out on the floor in front of the fridge, what might be wrong?
If the water is coming out from under the fridge and you have a water dispenser or automatic ice maker, then I you should pull the fridge out from the wall and check the water tubing going to the back of the fridge. The tubing is connected with a compression fitting (a special nut that compresses the tubing to the fridge. There may also be a few more pieces of tubing on/in the back of the fridge with these fittings. Place you fingers on each fitting to see if it is loose or wet. If you find a wet or loose fitting, take some pliers and tighten it (snug it up, but not too tight because you can damage the fitting. Dry up the water. Watch the fridge for a while to make sure the leak is stopped. If you can't get it stopped, or if it gets worse, you can cut off the water (there should be a valve under a cabinet next to the fridge, or under your sink). You can get a replacement fitting at Lowe's and they can tell you how to install it if necessary. If you have water pooling under your fridge and it goes up to the wall, then you should check on the other side of the wall for water also. This happened to our fridge, but we did not see the water in front of the fridge because it ran to the back of the fridge and under the wall into our carpet on the other side. Wet carpet is how we discovered the problem.
May 01, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
There is water dripping filling up the bottom under the salad container. The model is a LRTN22311TT.
Remove contents of fridge and check the drain line running down the top back of the back of fridge and follow to lower section of fridge (usually a back ledge or under the crisper sections) and locate a small round drain hole. Also, check to see that the drain collector (funnel looking thing at top back of fridge section) is located under the freezer defrost drain opening, to allow water to flow through the fridge into the drain pan under the fridge.
If something has obstructed the drain funnel, path, tube, or lower drain hole, remove the blockage to allow water to drain into underneath of fridge into drain pan for proper evaporation of water produced from the usual daily defrost cycle of fridge/freezer.
If that is not the problem, it could be that you have a leaking water supply line for your ice maker and you'll need to see if the freezer is allowing excessive water to flow out of the ice maker into the fridge section.
Another simple check/solution is that the fridge is not properly leveled, meaning that the front of the fridge should be slightly higher than the rear to allow for proper drainage and self closing of the front doors. This will help keep the water flowing in the built in channels and drains.
A perfectly level fridge isn't the right way to install most moveable refridgerators, while built in fridges (Sub Zero, etc.) are designed for plumb and level installations for proper functioning and use.
Apr 09, 2009 | LG LRTBC1825T Top Freezer Refrigerator
Water and Ice in Door Tastes Awful!!!
If your water tastes ok without the fridge then you'll need to replace or clean the piping inside the fridge.
If your water has the same smell and taste without the fridge then you'll need a better grade filter on the water going into the fridge.
If it's in your fridge piping try going to a plumbing supply and ask them for a cleaner to run through the fridge!
jack
Mar 08, 2009 | Amana SXD524VW Side by Side Refrigerator
Heavy water leak in basement under fridge
Has this fridge got an ice maker???
Because ice makers require a water supply to make ice.
This could be where your water is coming from.
Jan 19, 2009 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
