Question about Sansui HDLCD3210 32 in. LCD TV
When we turn power on picture shows for just a second and the goes away we can still here and change channels but with no picture
  • 11,361 Answers
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Posted on Oct 16, 2010
My tv is buzzing & the sound doesn't come on when I change channels
I need a little more information. Does the TV show a picture? Do you have audio on some channels or no audio at all.
Is the noise you hear of a low frequency, i.e. low hum? One thing you might try is unplugg yo6r TV from the wall for about 60 seconds or so, plug back in and see if the problem goes away. if not contact me back with the info I asked about. thanks
Mar 03, 2015 | Samsung Televison & Video
We have a large screen TV and it displays a solid
your closed caption system is turned onn to its TEXT FUNCTION use your remote to find the CC or closed caption option and turn it off and the block will go away . good luck
Oct 26, 2009 | JVC Televison & Video
Change channel, lose picture. power off/on, picture appears
switched HDMI plug from HDMI1 to HDMI2 port and that solved the problem
Oct 11, 2009 | Polaroid Televison & Video
Samsung T.V. goes on for 30 seconds then no picture
If this is a flat panel LCD tv, this is a sure sign that the panel itself is bad. I have seen this before. Tv comes on works fine then within 5 minutes goes blank.
Aug 07, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Picture splits into two halves
Change the box it will solve the problem.
Jun 02, 2009 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
Screen goes black after unit is turned on.
Contacted Mitsubishi directly and found out that QV9 on the remote control resets to factory defaults, clearing the Parental lock out someone had put in place. The TV is in a Retirement Home and some of the folks are sneaky about wanting to control the TV in their own fashion. We will be watching the remote a bit closer now!
May 01, 2008 | Mitsubishi VS-50802 50 in. Rear Projection...
A17w221 goes off automatically with power on
I have the same problem. The next stage is that the picture won't come on at all and the blue light will constantly blink. I think the light source is bad. Noit sure though.
Mar 25, 2008 | Envision A17W221 Television
Sony FWD-50PX1 no picture
try changing the channel with the original remote or by the tv's physical controls. It sounds like it has switch to an AV channel.
Oct 09, 2007 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Black Rectangle Appears on Screen
Perhaps the caption is on?
May 27, 2007 | JVC AV-27220 TV
Sansui HDLCD3210 32 in. LCD TV Logo
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
