Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Whirlpool side by side model number ED5PHEXMQ00 Comperessor clicks few second and stop. Changed relay and the run capacator. Now, the compressor runs so nicely can hardly hear it. The freezer side is work beautiful, but the refriderator side is not cooling enough. Hardly any air come from the vent on this side. Is there some sort of fan that needs replacing on this side? chris
    President:
  • 1,891 Answers
If evap fan is not going the change it . but do ck for ice build up in the back of freezer and if so the heater or termonator or a d c contro is failing . if ice is forming on the cold coil it slows or stops the air form getting to the fresh food area .. hope this helped . and hey you did a good job on that relay .. hope this helped mm .
Posted on Oct 16, 2010
Whirlpool ed25dq Not Cooling
Unplug unit from the wall, remover the start relay from the compressor and shake it. If its solid possible bad compressor, if it sounds loose (broken part) then most likely bad relay. Verify your model number as you are missing some letters.
Good Luck
Dec 13, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool eet171pk relay switch
do you mean the compressor won't start and you hear a clicking sound every few minutes?if so most likely the start device on the compressor is bad,you have to send the model number off of the machine,if it's a bottom mount or side by side,open the fridge door and look on the right side wall up near cieling and you'll see a tag with model and serial numbers,if the freezer is a top mount open the fridge door and look on the left side wall up near cieling and send model number so someone can look up your machine.have you vacuumed out the coil,if the coil is filled with dust the machine will run hotter than normal and can damage the start device and the compressor.
Sep 30, 2017 | Whirlpool Refrigerators
I have a model g56shaxlq02 side by side. Fan runs but when compressor starts it clicks off in a few seconds. Does not cool at all. I can hear the compressor start and then a clicking off sound after a...
From you description you gave you will need to replace you starting device to your compressor called a relay. This part should correct the starting problem to you compressor. I also noticed you posted the wrong model number, please verify before buying your parts. GS6SHAXLQ02
Thanks and good luck
Oct 12, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
My whirlpool fridge freezer keeps making a clickin noise like theres an airlock wot can i do to stop it?
Hi and wlecome to FixYa, I am Kelly
First off unplug it for about 15 -20 mintues. If there was a momentary power loss the compressor may be in a high coolant pressure fail to start situation. The high side pressures are well in excess of 150 lbs and the coolant system needs to stabilze for about 15 minutes so that the compressor does not "dead head." The clicking sound your hearing is the start winding trying to start the compressor. If it does not reach full speed in about 45 seconds the Klixon thermal overload will cycle and there will be a 4 - 5 minute pause before you hear the clicking again as the compressor again tries to re-start.
After unpluging the unit and then restarting it... if it does not re-start then there are a couple of things that can cause this.
1. The PTC relay mounted on the side of the compressor has failed.
2. The run capacitor has failed.
3. The compressor has failed and the internal rotor has LOCKED.
Unless your electric bill has been steadily climbing over the last few months I doubt that the comressor is locked,
Since you did not include a model number this is a GENERIC response without any parts links for the PTC relay or the run capacitor. If you need help with parts or further troubleshooting please provide a complete Model number in any future responses.
Thanks for choosing FixYa.
Kelly
Jan 29, 2011 | Whirlpool Refrigerators
Knocking noise coming from bottom of refrigerator
check the compressor for operation adn check the fan in the back of unit to make sure it is running...whirlpool units are notorious for compressor relay failure normally they click in and out every few minutes... if it is a knocking noise and continuous make sure compressor is not trying to start and sitting there shaking... normally it will stop after a few minutes and then start again....
Jan 25, 2011 | Whirlpool GS6NBEXRS Side by Side...
Fridge not getting cold, making clicking sound - Whirlpool EDSFTG
remove the rtc overload off the compressor and shake it,if it rattles thats your culprit,also if when its running and the compressor is quite warm to the touch,its only running on the start windings and isnt actually running right and will overheat and ruin the compressor,replace the rtc its cheaper than a new compressor
Jan 25, 2010 | Whirlpool ED2FHSS Side by Side...
Whirlpool refrigerator model ED25PQ. Interior warm
possibly the relay on compressor is bad. the relay will need to be removed. shake it, if it rattles and or particles fall out of it, it is bad.
Jan 08, 2010 | Refrigerators
Side By Side refrigerator ED5PHEXMQ00 Model #_ Click
The clicking noise may be the overload located at the compressor. If so the compressor start relay, start capacitor and overload may need replaced. Have you noticed any change in cooling or freezer temperatures? Sea Breeze
Nov 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Oct 03, 2009 | Whirlpool 25.3 Cu. Ft. Frost-Free...
Compressor on whirlpool side by side
STOP! DO NOT RUN UNTIL YOU GET PROPER PART!
I hope you have not ruined the compressor by now. Your original problem was that your compressor start relay assembly was bad. The click noise you were hearing was the overload protector preventing damage to the compressor. When you bypassed this relay and overload protector you may have burned the windings of your compressor. You would need a compressor tester or you will need to put a good relay overload assembly on to see if the compressor is usable now. If the compressor is destroyed the repair bill could run from about $350.00 to $700.00 depending on model and technicians labor charge.
I hope I have helped, supertechks
Mar 06, 2008 | Jenn-Air JCD2389G Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
127 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
