Question about RCA Audio Players & Recorders
Ok so im trying to hook my home built system running on win 7 to a blue ray hometheater system via the HDMI slot on my theater system and the one on my video card but i havent had any luck viewing or hearing the system. how do i accomplish this? thanks
  • 2 more comments
  • mrkev0 Oct 16, 2010
    im trying connect my blue ray home theater system to my computer using the HDMI slot on my video card and the one on the theater system. i have not been able to see or hear the system yet. how do i make this work? is the hdmi hook up the best way to do this? my opperating system is windows 7 home premium. thanks for the help
    i have no properties when right clickin windows screen. but there is the nvidia control panal for the screen. did not find the option in there either...
    there is no properties... my options are--- view, sort by, refresh, paste, paste shortcut, Nvidia control panel, new, screen resolution, gadgets, and personalize. the video card im pluging the hdmi in to is a Galaxy GeForce 210 if that helps.
    having trouble figguring out how to make my blue ray hometheater system to my computer. my video card and the theater system both have hdmi ports so i connected them but still am unable to hear or view the system. my OS is windows 7 home premium and the video card im connecting to is a nvidia 210.
  • 1,472 Answers
Mrkev0
Lets go back to the start. Please let know the make and model of the video card that you have. Note even though the card says NVIDIA or ATI on it because that is the chipset of the card but the card may have been made by another manufacture. Example manufacture would be MSI or ASUS.
Also if the card that you are connecting your HDMI connection to is your computer video card this will not work for what you are trying to do. The connection on your video card are for output the video from the computer to another device. If you are wanting to connect the a device to your computer so the video from an external device shows you will need a video capture card.
Along this line let me know the make and models of the devices that you are using in your setup and I can let you know the best way to hook them up.
Issken
http://www.fixya.com/users/issken
Posted on Oct 16, 2010
  • 11,896 Answers
On you main windows screen, right-click, go to properites, go to display, drag box #2 to theleft side of box #1. Then hit ok and then apply and the picture should show up.
  • Nate Stansfield
    Nate Stansfield Oct 16, 2010
    right click , properties, settings.
LG blue ray won't play sound from RCA sound bar. HDMI cable is hooked into HDMi slot on TV
the details you provided were very vague, however from my experience when a device is connected to another device via and audio capable hdmi cable, that device renders it audio output to the device its connected to and normally turn off all other audio outputs beside optical- I would assume there is an option in the blue ray player to turn off hdmi audio, which will in turn activate other audio outputs- you may also look for audio out port on your tv, it is ideal to connect the sound bar directly to the tv set audio out ports. To sum this up,
if you plan to use your player via hdmi cable you need to turn off hdmi audio output on the blue ray player and the plug an audio cable from your blue-ray player to your sound bar
you may also as i said connect your sound bar directly to your tv, the issue is most tv sets now a days do not have an audio out port, if you do then everything you play thru your tv will have audio via sound bar
there are several way to go here but unless your sound bar has hdmi av switching capabilities (im sure not) this is one of the most simple--Good Luck.
Jan 29, 2013 | Audio Players & Recorders
How to hook up my cable box and tv to panasonic sc-btt190
You could have a bad Hdmi outlet . Try hooking up component c what happens
Dec 19, 2012 | Panasonic Sc-Btt190 Home Theater System...
Can i connect dmp-bd871 to a home theater system
It will depend on your home theater system and TV. If your system accepts HDMI in from other devices and HDMI out to the TV, connect an HDMI cable from the blue-ray player to an HDMI input on home theater system. Then connect another HDMI cable between the home theater system and the TV. This will provide the best video and audio experience.
Another option is connect the HDMI cable from the Blue-ray player to the TV. Connect the audio output of the TV to the home theater system. (This will depend on the TV as well as the home theater system. Some TVs have digital audio outputs; others have analog outputs. If your home theater system doesn't have the same input as the TV's output, you would need a converter as well as the digital and analog audio cables. This is an example of one for digital to analog: http://www.gefen.com/kvm/dproduct.jsp?prod_id=4907 .)
If you do not want to get the best picture from the Blue-ray player and your home theater system has analog audio inputs, you can connect the composite video out to the TV. Then connect the audio outputs from the player to your home theater system. (This means only an SD picture will be provided to your TV.)
Panasonic has the manual for the DMP-BD871 here: service.us.panasonic.com/OPERMANPDF/DMPBD871-MUL.PDF .
I hope this helps. Please add a comment with the other devices in your entertainment system or their inputs/outputs. Then I can add specific information for your system and any tips for setting up the system.
Nov 26, 2012 | Panasonic DMP-BD871 Blu-ray Player with...
My Blu-ray DVD MBFH does not work on my Blu-ray player
do you have it hooked up via hdmi to a tv that has hdmi? also make sure you set the output for the dvd/blu ray player to the correct output your using (hdmi 1 or w/e not a passthru or input) also if your using component cables you may have to go to menu on the unit and select that as your outpput get back to me let me now if this helped
Mar 17, 2011 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
When setting up my home theater system, do I want to plug the HDMI cable into the TV in the HDMI In slot or HDMI out slot. Do I want to plug it into the HDMI In slot for the blu ray system or the HDMI...
You plug the home theater system into the television's hdmi in slot. However you want to plug the blu ray player into the HOME theater system's hdmi in slot not the television's.
Then you can take another hdmi cable and connect the hdmi out from the television into another hdmi in on the home theater if you have enough room.
Aug 20, 2010 | Insignia Televison & Video
Blu ray connect to my sc-pt660
as far as hooking up your blu ray player to the sc-pt660, the only real way to utilize the surround sound (with true surround sound) is through the optical audio out. You need to connect your blu ray player through hdmi to your tv and then connect your blu ray player to your surround sound using the optical audio out/in. I, personally have the sc-pt660 hooked up through component cables so I don't waste an HDMI input on my TV. Except for cd's, there is no reason for you to use the actual dvd player part of the surround sound considering you have a blu ray player. In conclusion, hooking your blu ray player and the sc-pt660 up to get better video simply isnt possible (your blu ray player alone gives the best possible resolution, 1080p). As far as audio goes, run an optical audio cable from your blu ray player to your sc-pt660 to get true surround sound.
Mar 23, 2009 | Panasonic SC-PT660 Theater System
Best way to connect new system
After trying several ways, we decided the best picture was to run the blue ray (out) directly to the TV (in) with an HDMI and another HDMI from the sat. box(out) to TV(in), then optical audio from TV (out) to receiver (in). This way you don't have to change channels on the reciever when switching from TV to DVD. Remember that HDMI is one cable that supports audio and video. If you are using all Samsung products and want to use one remote, using the Anynet feature, I think it has to be connected with an HDMI. I'm going to try connecting an HDMI too from the reciever to the TV to see if this feature will work. It does with the Blue Ray.
Nov 21, 2008 | Samsung HT-AS720ST Theater System
Hook up surround sound system to entire system
Is the 42 inch a lcd tv. is the blueray player & ps3 hooked up in the hdmi inputs?
Jun 01, 2008 | Samsung 1200W 5.1-Ch. XM-Ready Home...
Doesn't work
run blue ray diret to tv ok or set it in 720 p mode with bit stream for sound but go diredct to tv and back from tv in coxial in of sterio ok for sound
Jan 21, 2008 | Onkyo HT-SR800 System
49 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
