Question about GE 24 in. Profile PDW7800 Built-in Dishwasher
Dishwasher beeps every 15 seconds. I tried closing the door several times but the dishwasher still beeps and will not start.
  • 87 Answers
SOURCE: GE Profile dishwasher LEDs do not light up.
You have a bad control pc board.
Posted on Jun 08, 2007
markevans
  • 148 Answers
SOURCE: Can't cancel cycle without it starting
you have a few choices if the factory says that this is normal. try shutting off the breaker or unplugging the dishwasher. we use plugs when we install them to make removal easier. with the power down for a few moments, it may reset itself if its a solid state board. otherwise, let it run and then start it over again to do what you intended. its not a big problem if that is what you are stuck with for functionality. it is not a common need to reset, i would expect. check the manual too, you may need to hold the reset button for a few seconds or more.
good luck
mark
Posted on Dec 28, 2007
  • 43 Answers
SOURCE: GE profile PDW9880J00SS dishwasher just beeps
appears control is going bad,or problem with control circut
Posted on Oct 16, 2009
  • 18 Answers
SOURCE: GE triton II dishwasher normal light flashes and beep sounds
Ran across this today. Ge dishwasher normal light just blinks and beeps when latch is locked. I had to replace the control module and it repaired issues right away. Hope this helps
Posted on Nov 21, 2009
tbreeze47
  • 3083 Answers
SOURCE: brada dishwasher ef2401 wont start wash cycle
If it's under warranty, get someone to look at it. Probably a bad switch or sensor in the unit, could be something simple, and they're not hard to open up, but the soap dispenser mechanism has to be reassembled (it often falls apart upon taking the door apart). Last resort is the appliance serviceman. New house? New dishwasher? Warranty? That's your best option.
Posted on Mar 14, 2010
Ge dish washer just installed. First run. All lights working but cycle will not start. Error beeps indicate door not closed but it is.
That is exactly what the problem is. There is a switch on the door latch, it is not showing the door is latched. Could be bad switch, loose hardware or not connected,
Jul 08, 2017 | GE GDF570SGFBB Fully Console Dishwasher...
Bosch dishwasher beeping during cycle
Take the front kick panel off and see if anything under the machine is wet.
Jan 06, 2014 | Bosch Evolution 800 SHE58C02UC 24 in....
On the display is a flashing CL, according to the manual the latch is not closed. Tried several times to close the door and push the normal wash button. Nothing happens, only the CL light is on. Tried...
Hi
Error CL appears when the dishwasher control detects door switch is open or door is open. You'll have to open the door and check the continuity of the door switch. If the door seems to be closed then it is the control has detected an issue with the door latch. Check the door latch & seals to make sure door is closing fine. Unplug the dishwasher from power outlet and wait for 10-15 minutes. Restart the dishwasher and check if the error is still there. If error still appears then you'll need to repalce the door switch/door latch. Hope this helps... Please post back for further assistance.
Daniel
Nov 26, 2010 | Frigidaire PLD2855RFC Dishwasher
Water is left in the bottom of the dishwasher after completing a cycle
When you find water left in the bottom of the dishwasher... most of the times there is an "Intake/Drain" flashing, or some other type of fault indication. The dishwasher has faulted out, in the middle of a selected program. The dishwasher won't even bother to drain the water out. If it's not a drain fault, then you can drain the water out by: switching the dishwasher off and on again; selecting a program; and closing the door. Open the door after 15 seconds and see if the water has drained out. If it didn't drain, there is a drain problem. If it did drain, then it can be several things. To better determine the problem, you will have to pay close attention to when the dishwasher faults out.
Nov 20, 2010 | Miele Premier-Plus Built-in Dishwasher
When i close my dishwasher door it starts beeping
you need to replace door switch.adrian,,,,
Jul 14, 2010 | Whirlpool Dishwashers
My bosch dishwasher beeps everytime we close the door.
Better switch of till you are ready with full load. Otherwise you have to trace the beeper and disconnect it.
Apr 12, 2010 | Bosch 24 in. SHY66C05 Stainless Steel...
Ariston Elixia LI68 Duo dishwasher will not start
Same problem , i fixed by opening the door compleet then cleaning the bottom of the door with a kitchen cleaning paper that may do it afther that disconect the power compleet whait 1 minut connect it al again and it should work , don't ask me why this cleaning action i just found it out
Feb 05, 2009 | Ariston Technologies Dishwashers
Dose not finnish washing and starts bleeping and start light keep flahing. water is hot by have not dryed
Neighbor had a similar problem with a GE dishwasher except it wouldn't start and kept beeping when door was closed. So the door was left closed, and while it was beeping, turned off the circuit breaker that fed power to it. Waited about 30 seconds, turned circuit breaker back on, bleeping had stopped, dishwasher was reset. Normal and heated dry were already selected, (since I had tried pressing those two before all this to force a reset), then pressed start and it ran again. Hope this might help you.
Jul 25, 2008 | Whirlpool Dishwashers
Problems with Whirlpool dishwasher model GU1500XTKB0
have they checked the thernals on the bottom of the tub
Mar 14, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
will these units (silo and jtrip) start back on their own? if so, it is likely they are heating the water.
otherwise it sounds like a logic board, unless there is a defective door switch or sensor issue.
electronics seem to be a recurring problem with whirlpool.
i would ask whirlpool (electorlux) to either buy it back or fix it.
good luck
mark
Jan 09, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
GE 24 in. Profile PDW7800 Built-in Dishwasher Logo
203 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
