Question about Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve....
I just installed a Moen shower valve Model 82910cbn. The cold water supply is on. The shower works when the cold and hot water is going to the valve, but when I turn off the cold water supply going into the water heater, I do not get any water coming out of the shower head. Does the Moen valve need hot and cold water pressure going to the valve at the same time in oder for it to work? Thank for your help. Ray
  • 760 Answers
This is taken from the Moen manual. You can download it here:
http://www.moen.com/shared/pdf/instruction_sheets/ins162e.pdf
Balance Spool Maintenance
The precise and instantaneous pressure control illustrated has been
achieved through the balancing spool, which has been manufactured to
exacting tolerances.
During construction or valve installation, foreign material such as solder
flux, pipe cuttings sand, dirt or wood is unavoidably introduced into the
water system. Occasionally, however, rare, these foreign materials can
cause the balancing spool to become stuck temporarily between the
rough-in and trim-out operations. If this happens, it will be apparent at
the trim-out test, in that the valve will deliver only a small trickle of water
or it will deliver only hot or cold water. If this occurs, proceed as follows:
1. Make sure that both the hot and cold water service lines are ON. Also,
make sure that both screwdriver stop-check valves are open. The valve
WILL NOT OPERATE unless both supplies are ON.
2. If the valve still does not function properly, turn off both the hot and
cold supplies and remove the balancing spool, using a wide blade
screwdriver. The inner piston of the balancing spool should shake
back and forth freely. If this is not the case, jar the spool on either
end to remove the foreign material and free the spool. When the
spool is free, replace it; turn ON both water supplies and the valve
will function properly. If you are unable to free the inner piston,
replace the entire spool.
Posted on Oct 16, 2010
Testimonial: "Thank you, I now understand that both hot and cold water supplies must be on for the valve to work."
Moen shower valve turns on full to cold water but flow becomes minimal when valve is turned to warm/hot. not getting enough warm water to shower. can this be fixed without rplacing the valve?
yes and no. Find hot water heater and insure cold water supply valve is open all the way. check to see if there is a hot water supply value and that its open all the way. If you replace shower value over iron pipe on the hot side it is corroded up replace pipe and value. If copper, find hot side, find value and open it up.
Nov 28, 2010 | Moen & One Handle Tub & Shower Faucet
I've been given an old (10+ yrs) Moen shower control valve that I want to use (it does apparently have pressure balancing built-in), but don't know which side is hot and which is cold. Does Moen always...
Moen and all shower valve manufacturers follow american federal guidelines. Hold the unit in your hand with the handle facing you - the left side is the hot water inlet and the right side is the cold water inlet.
Nov 25, 2010 | Moen & Posi-Temp Single Handle Shower Or...
& One Handle Tub & Shower Faucet : i have a moen shower faucet and i get not hot wate...
these valves can be adjusted by removing the handle and adjusting the white gear that regulates the hot and cold that come out, try going more to one way if it gets colder then go the other way.
May 16, 2010 | Moen & One Handle Tub & Shower Faucet
No cold water from Moen 2253 tub/shower valve, when i turn handle to cold I get hot water, when handle is turn to hot i get hot water
Here is a quick check to see if the cartridge may be at fault allowing the cold and hot to mix. Turn off the hot water supply, with hot water supply off turn faucet on. Turn to the hot and cold sides, If you have only cold water then your faucet cartridge is at fault or the cartridge housing is worn. Shut all supply valves and remove cartridge and inspect housing for signs of wear. If wear is visible a new shower valve is needes. If none visible replace cartridge. I have included a link of a PDF file an exploded parts list. I hope this helps in solving your problem. Please rate if the answer helps in any way. Good Luck and have a great week. Jeff
Apr 05, 2010 | Moen & One Handle Tub & Shower Faucet
Low water pressure
When it was installed was there any copper sweating done? If so, the valve cartridge can get fried if not removed prior to the immense heat from a torch.
Jan 23, 2010 | Moen Posi-Temp Single HandleTub And Shower...
My(installed today) moen single handle shower valve (82910CBN) is only producing cold OR hot water. It is not mixing. What should I do to fix this?
if u still have instructions it will explain how to adjust the water -in the handle are a red and blue plastic tabs that are adjustable pull back and turn to adjust --this is the anti-scold--till u are satisfied
Nov 03, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Not enough hot water, has to do with a shower valve
Hello, first if any water supply hot or cold is turned off, you will experience trickling as you mention. You must have both cold and hot in order to adjust the temperature on your valve. if you had a plumber intall this unit you should ask him to adjust it. Otherwise here is how:
Rotate the handle counterclockwise to stop and let water run till cold water is purged, check
temperature. Rotate handle to off, remove handle parts (see Disassembly in your manual) and temperature limit stop, rotate clockwise to decrease and counterclockwise to increase maximum hot water temperature, reinstall temperature limit stop and handle (TIP: Do not screw handle in until desired maximum temperature is achieved) Repeat steps until desired maximum
Feb 21, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Moen single handle valve tub/shower
The Moen Posi-Temp Valve is a pressure balanced valve and when not used for long periods of time they can stick causing only cold or hot water to pass through the valve.
A New Posi-temp cartridges can be purchased at most plumbing supply houses or big box outlets such as Lowes or Home Depot.
As long as you had cold water before, a new cartridge will solve the problem. In the future it would be wise to occassionally operate the valve at least a couple of times a month in order to keep the pressure assembly from becoming lodged in position. Just follow the instructions included with the new cartridge on the proper removal of the old cartridge and the installation of the new cartridge. a little silicone grease inside of the valve before installing the new cartridge will also help.
Be sure that there is no particles of the old cartridge left in the valve.
sanray
Dec 27, 2008 | Moen & Posi-Temp Single Handle Shower Or...
Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve.... Logo
1,207 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
