Question about Whirlpool Washing Machines
Trouble installing inglis front load washing machine
Hello, when installing our new washing machine we have to removre four shipping bolts along with the spacers. One of the spacers fell into the machine. Is this a problem? Thank you so much!
  • 487 Answers
No problem when the spacer fell to the bottom. You can tilt the machine to get it out from underneath but normally there should be no problem
Posted on Jun 03, 2008
F7 on my hot point. Washing machine
This error code indicates that the motor is having difficulty turning.
Are the shipping bolts removed?
All four (4) shipping bolts and the plastic spacers must be removed from the rear of the washer before you operate it. Each unit is shipped from the factory with four bolts, which are designed to secure the washer during shipping. Failure to remove all of the shipping bolts, and the four plastic spacers that are with them, can result in noise, vibration or error codes. See the Installation Instructions for details; find them by entering your model number in the search tool below.
Were you washing a very large load?
The washer may be overloaded for the cycle you are running. Remove a few items from the load. See the Cycle Guide in the Use and Care guide for loading suggestions for each cycle.
To remove the error display, press Power once. Then press Power again to restart the washer.
If pressing Power does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
Apr 22, 2015 | Washing Machines
FOUR BOLTS AND RUBBER WASHER ON BACK OF WASHING MACHINE DO THEY NEED TO BE REMOVED BEFORE OPERATION
Hi Jamie, thank you for your inquiry! It seems like you are referring to the shipping material. This consists of 4 shipping bolts, 4 spacers, 1 metal "P" clamp, and 2 hose clips. Yes, according to the installation manual for the model number posted above, GLTF2940ES, this material must be removed. I have attached the Installation Instructions on how to do so. I hope this information helps to some degree. If you have further questions, please do not hesitate to reconnect.
Aug 11, 2013 | Frigidaire GLTF2940ES Front Load Washer
I just bought the affinity front load washer and did my first load of laundry. During the cycle, it vibrated so hard and literately moved one foot from the original location. What is causing the washer to...
Sounds like the shipping bolts are still in place. There are four bolts on the rear of the unit. Remove them and it will fix the issue.
Apr 22, 2011 | Washing Machines
Need transport bolts for my Whirlpool Duet front load washer, model # WFW8400T,
The transport/shipping bolt for your washing machine is part number 8540199. It is sold as set of four here.
Aug 21, 2010 | Whirlpool Washing Machines
I manage a Moving Company and was wondering if all front loading washing machines require shipping bolts to be installed prior to shipping, or just certain brands?
Hi just read your posting.In my experience with front loaders they all have transit bolts .The reason being is that the internal bowl and tank are separated from the outside frame by suspension rods and, or springs.The easiest way to tell on most front loaders is to look for the holes in the back of the frame of the machine where the bolts attach the frame to the tank .Hope this helps and good luck.
Jun 16, 2010 | LG WM-2077C Front Load Washer
Just hooked up yesterday. Have done 3 loads. Machine shakes vigorously, moving about 2 feet. What is the problem?
It sounds like perhaps the shipping bolts are still in the machine. Look at the back you'll see 4 large bolts that must be removed to release the main tub assembly from the cabinet.
Refer to your owners manual and it should give you an illustration of where they are located.
Also make sure all four leveling legs are secured with the locking nut against the cabinet once it has been leveled.
Hope that helps,
Good Luck :)
Oct 28, 2009 | Electrolux Kenmore 3.5 cu. ft. I.E.C....
Very noisy and moving around Hotpoint washing machine
there are four shipping bolts in the back of the washer that need to be removed they are long bolts connected to plastic pieces. unscrew them and remove the plastic pieces
Oct 22, 2009 | Hotpoint Aquarius WD63 Front Load...
Shipping bolts for Maytag Neptune
There is a product call LITKIT TM, it is a universal shipping kit for washing machines. www.litco.com
May 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
How to fix excessive vibration during spine cycle?
if your machine is new, and you self installed it, you forgot to remove the shipping bolt, for front load-check the back there are four long screw sometime three depending on the brand , for top load tilt ur unit take a look on the bottom- in the middle again depending on the brand they use a single bolt to hold the tub during transporting- remove it, slide out the spacer it will be ok. now if your unit is some years back already you have your problem with its transmission or gearcase for top loader-quite difficult to fix it sir, or suspension mechanism and bearing on front loader sir- u have to replace it or call a qualified service tech - happy washing soon sir
Apr 06, 2008 | Washing Machines
Washing Machines Logo
112 people viewed this question
Dan Webster
Dan Webster
Sal De
