Question about Pentair Mastertemp Pool & Spa Heater Dual Electronic Ignition 400,000 Btu Lonox Propane 460737
Mastertemp 250 service system light comes on when raised above water temperature
  • hhgmaintenan Oct 16, 2010
    Thanks Greg, so what I need to do is change the thermocoupler? MIKE
    Thanks, the digital temperature now fluctuates up to 120 degrees and you can hear the water boil down by the inlet valve with a popping, crackling sound. So, your answer seems to hit right on. I'm glad I used this service and I thank you so much for the advice since its the weekend. Mike (Chief Engineer Holiday Inn Gulfport MS)
    Genius:
  • 1,340 Answers
This has something to do with a water temperature sensor which normally is a thermocouple.It seems that yours is reading the water temperature,sends a feedback signal to some sort of computer type controller,and when the heater output water starts getting a bit hotter than the temperature which it knows the water currently is,it's shutting down.Within thermocouples,there is a small section known as a reference temperature.That section sounds like it's gone bad because when comparing the temperatures and going above the reference,the best way to describe it is it's like popping a circuit breaker in your house,which causes shutdown,but in your house it's to prevent fire and/or save the housing wiring.In the pool heater,it's saving the water from boiling because it doesn't know when to stop.If you need more help or this is not correct,just comment back here and I will get an autolink to your post and reply ASAP.Good luck! Greg
Posted on Oct 16, 2010
  • Greg McCarthy Oct 16, 2010
    After I had shut down my computer,I realized i had forgot to ask you something.When you turn the temperature dial to attempt to heat up the pool,then the dial you are turning gets past the current water temperature,that is when the light appears?If so,then yes I would recommend the thermocouple.
    You are quite welcome sir.Now go enjoy your weekend.Greg
I have a Master Temp 250 pool heater that shows an AGS error on the back of the board. The heater runs for about 20 seconds then shuts off, any ideas?
AGS = Auto Gas Shutoff...
What is happening is the heater is monitoring (or sorta, by reasons difficult to explain here) Water Flow and Water Temperature. In this case, the AGS is triggered by a low water flow, or high Incoming Water Temp.
High internal water temp = triggered AGS.
If you have and can confirm, PROPER water flow, water temp coming into heater is Lower than 104°, then it is possible you have a faulty AGS.
But in most cases, it's only doing its job. Locate the reason for the fault, or why the AGS Switch turned the heater off.
Jun 05, 2015 | Pentair Mastertemp 250 Natural Gas Pool...
Pentair MasterTemp 250 Natural Gas with "Service System"
possible bad pressure switch or loose wire or plugged line to switch
Sep 05, 2017 | Pentair Pool & Spa
Pentair MasterTemp 250 Natural Gas Heater with "Service System" issue
this heater will display 2 red light related problem 1-service the system mean you need to clean you filter, and service the heater mean it may be a problem with the heater this 2 you will be able to see it in key pad control the heater ,now reset the board and see what happens (CUT THE POWER ON/OFF UNCE )
Jun 09, 2013 | Pentair Pool & Spa
Pentair MasterTemp 400 Stack Flu Sensor Reading Stuck
check gas pressure and for clogged burn tubes unit is overheating
May 12, 2012 | Pentair Mastertemp Pool & Spa Heater Dual...
Pentair Mastertemp Pool & Spa Heater Dual Electronic Ignition 400,000 Btu Lonox Propane 460737 Logo
285 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
