Question about Traxxas 4910 T-Maxx RC Monster Truck
My tmaxx for some reason will not move it runs good and jumps once and a while but will not engage
Is the spur gear missing teeth?
Posted on Jan 03, 2011
Bladesdoturnwhenengaged
your belt has most likely jumped out of it's intended route, or has broken, check with engine NOT running keys out switch off, pull engage knob and try to manually move blades if they move while knob is engaged, belt is broken or off track
Mar 21, 2014 | Husqvarna Garden
Problem toyota unser
you need a new thrust bearing ,make it a new clutch as well.
Dec 24, 2013 | Computers & Internet
Toyota Unser Automatic
need email from google cbachaibar@gmail.com
Tmaxx 3.3 starts and runs when holding off the ground but as soon as i put it on the ground it dies
Change your clutch shoes and spring, if shoes are still good,then just the spring
Mar 07, 2013 | Traxxas T Maxx 3.3 Monster Truck
Mower cuts out when cutter engaged
Check your blades for turning. A OTHER REASON COULD BE THE AIR FILTER GOT WET. If got wet. Put in the sun for a few days.
Mar 03, 2012 | Garden
I have a riding mower that will not turn over. I used jumper cabels attached to my car, stupid I've been told. I have done this before and the mower will start. When attached the mower engine will...
it is hard to say exactly what the problem is, but it sounds like the starter, starter solenoid, and or a charging problem. 1. last year I am assuming that the battery was low on charge and once you jumped it, it would start with the key for the rest of the season? if yes your battery should be OK just make sure at the end of the season you disconnect it and store it some where cool but not freezing. if you had to jump it all the time the battery and charging system has problems,(cables)(?). 2. if you have to use the car to jump the mower make sure the mower and car are both 12 volt systems, and the car should not be running. 3. make sure the battery is fully charged and there is no corrosion between the cables and connections. 4. once you do the above you can jump the solenoid to see if the starter is bad, if it moves it should be good, if you have to jump the solenoid make sure the mower is in neutral and the wheels are locked so it cant jump forward. also make sure all your safety switches are engaged, most mowers have switches on the seat, the blade engageing handle, and breaks.
The lights might have a bad connection at the battery, follow the wires from the lights for fuses and check them, some models have to be started before you can turn the switch back to turn the lights on.
May 13, 2011 | Garden
My tmaxx runs in reverse only
It could be that the "dawgs" in the f/r clutch are not pulling in totally.
Take apart the tranny, tighten the spring tension about a 1/4 turn, just like on the 2 speed clutch, on both the f/r gears.
You won't notice any difference in engagement speed but it will not get stuck in reverse mode now.
Thanks for using Fixya.
Good Luck and have a nice day.
Jun 06, 2010 | Toys
Air conditioning
If there is no r-12 or freon in the system it wont come on. Try jumping the pressure switch. It's a 2 wire plug somewhere one the AC lines. Just pull it off and jump the wire end with another wire.If the clutch engages you need freon or R-12.
Jul 25, 2009 | 1996 Chevrolet Corsica
Traxxas 4910 T-Maxx RC Monster Truck Logo
115 people viewed this question
Top Traxxas Toys Experts
Michael Brisco
Level 1 Expert
cwradio73
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
