Question about Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - Natural Gas
Sometimes when after a while not using the unit, once tou switch it on the DSI fault comes on, & when you count the alarm sequence to find fault, it says Gas Interuption. ????? When i reset it, then it all works okay. But after a while it fails again. Why?
  • 11,800 Answers
The processor chip from the controller board has started to malfunction - it doesn't process the sensor data correctly from the get go. This is a "hardware" fault - the chip has aged and you can't fix that. The problem will only get worse, until the furnace will simply refuse to start over.
Don't wait till the middle of the winter, call a repairman now and have the controller board replaced. And no, it's not something you should do yourself, if you touch something you shouldn't you can easily fry some very expensive sensors.
Posted on Oct 16, 2010
15 year old micromark intruder alarm need to switch off
Not really enough info to give you an answer, but I can generalise...
You say Knocked alarm box with ladder alarm started"
If the fault is there permanently from when this happened there's a good chance that you have disturbed the tamper spring/switch on the cover of the alarm unit. when the front of the panel is removed you should be able to see the Sping/switch which is automatically depressed by this front panel, you may find the spring has fallen off the switch or gone out of alignment, refitting / realigning it should remove the tamper fault once the lid has been refitted properly. As for "bleeps when doors, windows opened"
This sounds like the "Chime" feature has been switched on and without the manual I cannot tell you for sure how to switch it off.
Chime is a feature which "Chimes" when a door is opened (Not often used on windows), if this started when the ladder fell on the panel it is most likely just a single key press to switch it off, Once the tamper fault is sorted you should be easily able to find the correct key press to turn the chime feature off.
Sorry for being a bit general but I don't have that particular manual. Hope the info helps you :o)
Mar 20, 2017 | Home Security
Tip
Washer knob / Dial going round & round
If the washer knob of the unit is going round and round all by itself it means that there is something that has malfunctioned in the unit or else there was an error in setting proper cycles.
You will first need to reset the unit, to see the reset procedure click here
Once you have reseted the unit and even then the washer knob is going round & round it means that a part or parts in the machine have gone bad which may need to be replaced.
The question would be how can one understand which part in the unit has gone bad.
To make things easier, here is what needs to be done to know which part has gone bad.
  1. After reseting the unit, set a new cycle and switch on the machine.
  2. If the washer knob starts going round and round, the mode+Door lock light will flicker in a sequence, for example, it may flicker 4 times before taking a pause and then flicker 4 times again and continue this sequence.
  3. Once you know what is the count which is also the fault code there is a fault code chart which you can refer to understand which part has gone bad.
  4. The fault code chart is as follows:
Hope this helps, do let me know if this information was helpful or else you need more clarification on the same.
on Mar 02, 2010 | Washing Machines
I replace the fuil pump and spark plugs on my 2000 experdition and it start but want stay
Once you replace the fuel pump, you need to repressurize the fuel system.
In order to do this, follow this sequence:
  1. Place the key in the ignition;
  2. Move the ignition switch to ON (not START");
  3. Count to 5
  4. Move the switch back to OFF
  5. Count to 5;
  6. Move the switch back to ON;
  7. Count to 5;
  8. Move the switch back to OFF;
  9. Count to 5;
  10. Once more, to ON;
  11. Count to 5;
  12. Once more to OFF;
  13. Count to 5
  14. Now START THE VEHICLE.
Aug 09, 2014 | Cars & Trucks
Trouble codes
You may just have a stray fault, try to clear it and see if it returns: Key ON, Key OFF, Key ON, hit left turn signal 2 times wait for 2 flashes,,, hit right turn switch ONCE =>One Flash. Hit Right switch once =>2 flashes, Hit right turn switch once again =>3 flashes. Hit Left turn switch once than read codes to clear Hit left switch & hold for confirmation 2 flashes (hold at least 5 seconds).
If the code comes up again you've got a poor ground issue somewhere.
Apr 02, 2014 | 2002 Harley Davidson FLSTC - FLSTCI...
97 chevy suburban have replaced fuel pump, relay, fuel filter, & the fuel pressure regulator but now it will crank & then die once I press the gas pedal. It also bogs down after coming to a st
possible faulty accelerator position sensor. Have the fault codes read. Replace faulty items. Use only genuine items as non-genuine replacement are not always compatible with the OEM fitted CPU units
Jun 03, 2013 | 1995-1997 Chevy Suburban Ignition Starter...
Getting Fault 73 for my CVA 4070 at start-up. Have removed the brew unit to ensure is clean and plastic piece -- shaped like a block "M" or block "W" - is in the "W" position. Have tried a manual on and...
I have had the same fault 73. Miele is coming out to replace the drive and the brew unit. SHould be a $700 repair. Thank God for warranties. I'll et you know the end result once repairs are complete.
Jan 09, 2010 | Miele CVA4070 Coffee Maker
Park brake light flashes 10 times. For 1989 Chevy 1500 pickup. What does this mean?
This truck probably has Rear Wheel Anti-Lock (RWAL) brakes. There is a small black module near master cylinder that is the brain for this system. There are ways to check for diagnostic trouble codes in this system. Once you have any codes set, diagnosis can be fairly simple. PROCEDURE:
Diagnostic Trouble Codes (DTC) 's can be displayed by jumping terminals "A" and "H" of the Data Link Connector and observing the flashing of the "BRAKE" warning light. This should only be done when the brake lamp is "ON".
The terminals must be jumped for about 20 seconds before the code will begin to flash. Count the number of short flashes starting from the long flash. Include the long flash as a count. Sometimes the first count sequence will be short. However, subsequent flashes will be accurate. If there is more than one failure, only the first recognized code will be retained and flashed.
NOTES:
DTC's 6, 9 and 10 will only turn the "BRAKE" lamp on while the fault exists. These are soft codes faults and can only be read with the Tech 1 scan tool.
Do not jump terminals "A" to "H" if the "BRAKE" lamp is not on. Jumping the terminals with the "BRAKE" lamp off will set a false DTC 9. This will turn the "BRAKE" lamp on and disable the antilock system.
  • 1, 11, & 12 ECU Malfunction
  • 2 Open Isolation Valve or Malfunctioning ECU
  • 3 Open Dump Valve or ECU Malfunction
  • 4 Grounded Antilock Valve Reset Switch
  • 5 Eccessive Actuations of the Dump Valve
  • 6 Erratic Speed Signal
  • 7 Shorted Isolation Valve or Faulty ECU
  • 8 Shorted Dump Valve or Faulty ECU
  • 9 Open Circuit to Speed Signal
  • 10 Brake Lamp Switch Circuit
  • 13, 14 and 15 ECU Malfunction
  • Sep 29, 2009 | 1989 Chevrolet C1500
    My r41 wont work my dsi is 1.4 how can i degrade
    i have just done a system upgrade on my sons Dsi. All good until i put his R41 card back in it. it now says system error and to switch on and off and contact nintendo!!! i have tried to format dsi but still will not work!! any ideas?Can This be fixed?????????????
    Sep 05, 2009 | Nintendo DSi Black Console
    How do I set the digital time on a mossimo analog/digital watch. Where do I find instructions?
    If you have the Mossimo that is an analog and gisital andhas the four (4) buttons around the side, here is what I have:
    Legend:
    Button near the number 10 = A
    Button near the number 8 = B
    Button near the number 2 = C
    Button near the number 4 = D
    Switch Control/Normal Readout:
    Press:
    A = E.L. Backlight
    B = Mode
    C = For Month Date and Day of Week
    D = For Alram Time
    Setting Sequence:
    1. In normal time readout, press B three times to get normal setting mode.
    2. Press D once; Minute flashing, Press C to advance.
    3. Press D once: Hour flashing, Press C to Advance (A on display = AM, P = PM)
    4. Press D once: Date flashing. press C to advance.
    5. Press D once: Month flashing, press C to advance.
    6. Press D once: Day of Week flashing, press C to advance.
    7, Press B once: Setting completes - returns to normal time readout.
    Alarm Setting Times:
    1. In noraml time readout press B twice, Alarm Time hour flashing, Press C to advance.
    2. Press D once: Alarm Time minute flashing, Press C to advance.
    3. Press B once:Setting Completed, returns to normal time readout.
    Alarm Function
    1. In normal time readout, arm alarm by pressing C and D simultaneously. Alarm signal will appear.
    2. In normal time readout disarm alram by pressing C and D simultaneously. Alarm signal will disappear.
    The alarm will stop itself after 1 minute or can be silenced by pressing D or press C with snooze feature - will re-alarm in 5 minutes for the next hour.
    Chime:
    1. In normal time readout, chime activated by pressing D and B simultaneously. All day flag appears.
    2. In normal time readout, inactivate chime by pressing D and B simultaneously. All day flags disappears.
    Chronograph:
    1. In normal time readout, press B once to get into 'Chrono" mode. Pressing C will start the counting.
    Two Options for "Chrono" mose:
    a. Durning coutning, pressing C will stop count and then press D to reset the mark.
    -Or-
    b. During counting, pressing D will enter teh watch into laptime mode, meaning 1 portion of the count is registered on the display while the counting contiues until completed by pressing C, then D twice.
    Apr 08, 2009 | Watches
    Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - Natural Gas Logo
    29 people viewed this question
    Top Rinnai Heating & Cooling Experts
    paulcarew
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
