Question about Seiko QHR016SLH Clock Radio
Looking for Instruction manual for a Seiko Global radio wave control clock Modle #QHRO16 Don't know how to set the USA time zone.
4 Suggested Answers
  • 10865 Answers
SOURCE: I am looking for PDF or online instructions for
Go to seikousa.com and email cust service. They will email you an acrobat version.
Posted on Sep 16, 2009
  • 71 Answers
SOURCE: global atomic radio controlled clock
It should automatically reset to the correct time. Try taking the model number and Google for an answer. Hope this helps.
Posted on Mar 16, 2010
meyer854
SOURCE: I HAVE A SEIKO GLOBAL
Remove the battery cover, press and hold set until it beeps. Use the up down keys on the front and you cycle through year, month/day, then time, then 12/24 hour mode. You advance to each function using the set key. Once through the cycle, the time will stop flashing and the clock will function normally.
Posted on Nov 12, 2012
How can I get the correct day of the week? I can get the date-month & day, but not the correct day such as Sat when the clock says Monday.
check you have set to the correct year, and remember a leap year has one day more... note date,month stays the same but the day changes from year to year.. hope your clock has a year function?
May 12, 2016 | Seiko Global R-Wave Radio Controlled...
How do I change the time zone?
You may have to do a time set for the particular time zone you wish.
Mar 13, 2015 | Seiko QHR015SLH R Wave Get Up and Glow...
My La Crosse Radio controled atomic clock is spinning for the last two days, How can this be corrected? I have a secound Clock same modle it is working fine. Modle# wt-3102
Hello
To set up your clock simply install one fresh AA, LR6 ALKALINE battery. Due to the nature of long wave radio signals it is normally not possible to receive a signal during the day so it is best to install the battery late in the evening. Select your time zone by pressing one of the four time zone buttons PT-Pacific Time, MT-Mountain Time, CT-Central Time, ET-Eastern Time. The time zone buttons may be pressed any time after installing the batteries. If multiple buttons are pressed the clock will set to the time zone selected last. If no time zone is selected the clock will default to Pacific Time. Another time zone can be selected during or after the clock has set itself. Your clock can only set itself to one of the four time zones stated above. For time zones outside of PT, MT, CT or ET you must manually set the time using the Manual Time set button on the back of the movement.
When the battery is installed the second hand will advance eight seconds (two seconds per step x four steps). The clock is now searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each
hour until a signal is received. If the time is manually set the clock will continue to periodically search for a signal and automatically reset the hands when the signal is received.
Select a location to place your radio controlled clock where it will be at least six feet away from a TV, computer, air conditioner or other household electrical appliances. The optimal location is near a window. Windows facing Colorado providing the best signal. The WWVB time signal will easily penetrate Masonry and wood framed buildings. WWVB will penetrate almost every residential building and most steel buildings if they have adequate windows. It is not possible, however, for WWVB to penetrate most indoor shopping malls and rooms in the center of large office buildings that do not have windows. In buildings that WWVB cannot penetrate you may set the time using the manual time set button. When the clock is exposed to the WWVB signal it will automatically set the hands to the exact time.
Ok.
Jul 31, 2011 | La Crosse Radio Controlled Atomic Clock
I HAVE A SEIKO GLOBAL RADIO WAVE CONTROL MODEL QHR019SLH AND NO MANUAL HOW DO ISET THE TIME
Nov 09, 2010 | Seiko QHR016SLH Clock Radio
I am looking for PDF or online instructions for the Seiko QHR007G global travel alarm clock.
Sep 16, 2009 | Seiko QHR007GLH Clock Radio
Need users operating manual for seiko qhr016 travel atomic clock
The time should be done on automatic by pressing WAVE.
To set manually:
Press the [SET] Button for more than 2 sec. The Year will pop up set to correct year then press SET again to set date/mth, keep holding till it get to right month n date (the month and date does not set separately). Press SET again and set TIME then press SET again for your choice of 12hr or 24hr.
Apr 26, 2009 | Seiko QHR016SLH Clock Radio
I need to change time zone on atomic clock to EST
I need help setting the time zone on the sharp atomic clock model #spc364.
Apr 18, 2009 | Bose Wave Radio
Seiko QHR016SLH Clock Radio Logo
500 people viewed this question
Top Seiko Audio Players & Recorders Experts
NOEL
NOEL
cwradio73
Andrew Taylor
Andrew Taylor
Are you a Seiko Audio Player and Recorder Expert? Answer questions, earn points and help others
