Question about Samsung SyncMaster 2253BW LCD Monitor
Hi there, i seem to have a problem with my samsung 2253 bw, i have had it for roughly 2 year and its been great, but just recently it has developed a shadow over everthing, just wondering if there is some reason why and if there is something i can do to fix it?
    Genius:
  • 1,325 Answers
We have paper jump problem.after reseting and changing powder developer.for konic Minolta .bizhub250 bw
So you recently replace the drum? and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8/Developer Charge. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 21, 2016 | Minolta Office Equipment & Supplies
C-2253 erroe code
DID Some one recently replace a color image unit? Was that image unit stored standing up? and placed directly into the machine.? Might have all the developer sitting at one end and motor can not turn. Pull out all the image units, shake each one along the axis of the unit to spread the developer over the entire length of each image unit, then re-install, open close front door to reset code, if the code comes back you might have a burn out color image motor, or on of the color image unit needs to be replaced replace all three, worse case the board that controls the motor was damaged. Store all Image units and toner length wise
Aug 30, 2015 | Konica Minolta Minolta Bizhub C253 Copier
How do I reset the time on the display ?
1. Press the transfer button and enter 200
2. Enter password ** 1234** default.
3. Enter 1 to enable
4. Press SPK button and enter 505
5. Display will read
OLD: 1040703: 1125
NEW:WMMDDYY:HHMM
For Monday April 7. time 1:00p.m
enter the following
104070313:00 and then press the Transfer button.
6. Display will return to normal..
Jun 12, 2014 | Samsung Ds-24d 24 Button Display Phone For...
My Samsung SyncMaster 2253 BW won't display any image. I've tried different computers and different cables, but no luck. The screen will turn on for a while and swith between analog and digital...
It can be due to bad laogic board or the logic board is no getting clean DC from the power supply due to bad DC filter caps. Failed SAMSUNG TV and monitors: http://s807.photobucket.com/albums/yy352/budm/SAMSUNG/
They made them to fail.
You need to do some in-depth troubleshooting and you may want to read my guide to understand how LCD monitors work.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jun 24, 2011 | Samsung SyncMaster 2253BW LCD Monitor
SyncMaster 2253 BW Samsung
Hi...there,
Have try open your monitor on screen display (OSD) and used the auto adjust settings.
Oct 13, 2008 | Samsung SyncMaster 2253BW LCD Monitor
Samsung 940 BW Monitor Not working (Black screen)
Hi...there,
That's indicated your backlight inverter are busted. Need to replaced a new one or repaired it. To repaired look for a bad capacitors with a bulged on top of each caps. Not sure, just replaced all the caps... Have a nice weekend!
Oct 09, 2008 | Samsung Syncmaster 940BW LCD Monitor
Prints a skewed image
Your paying good money for that service contract. I'd have them send a tech and have him stay there until it's fixed or find a new service provider. Questions like this drive me nuts. Were not talking rocket science here, these devices are not that complicated. Hold contract providers feet to the fire until this is solved. I'm really sorry.
Sep 26, 2008 | Sharp AR-BC320 All-In-One Led Printer
Samsung HD tv help
Is it a Plasma Television? I recently had a customer have the same issue with a 2 year old model Samsung 50" plasma TV. In his case one Of the computer panels failed. He didn't have a service plan and the warrenty was out, so i directed him to Samsungs help line. They inturn directed him to a authorized repair center. Repairs were roughly $800. Thats a possibility but it may not be the same as your issue. Try leaving your TV running for a little while when it has the issue, and see if it eventually goes away. Some older plasma models have started to require a warm up time for the pixel cells. This has been a down fall of plasma that for the most part no longer exists on newer models.
I hope eveything works out.
Have a great day
Mar 22, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Samsung SyncMaster 2253BW LCD Monitor Logo
285 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
