Question about Conair SW-2504GPH Corded Phone
I have an old CONAIR CORPORATION phone, model sw2504; it has the cloth covered cord with the tightly wound metal spring at the end that attaches to the phone. I is push button dial and looks like the old phones from when I was a kid? I was just wondering about it and if it could be made into a useful phone now.
3 Suggested Answers
  • 20 Answers
SOURCE: Need manual for Conair Corded phone Model SW3414wcs
You can find the manual here:
http://www.conairphone.com/IBs/feature_telephone/sw3414.pdf
Posted on Jan 04, 2009
SOURCE: My Conair Phone CID 502 works except for some
Hi friend, I'm really sorry for your problem.. But it could be easily fixed. Don't worry.
>> Your problem may be due to the malfunction of any hardware parts in the device..
>> if your device was still in warranty period its easy to fix. Just give the device to the nearest conair service center along with your warranty details or bill. >> If not, It's better calling the toll free customer service number of your device manufacturer that will be in your manual.
>> If nothing works, then the best way to seek professional help. Get it to the nearest service center to make the device work for you.. All the best.. don't forget to vote me..
Good luck. :)
Posted on Jan 30, 2011
I have a retro Conair SW2504 phone. I can't dial out
Is there a switch to select pulse or tone dialling? If so try it in both positions.
Jan 10, 2013 | Conair SW-2504GPH Corded Phone
NEED TO CHANGE PULL CARD ON RH2660DA HEDGE TRIMMER
This is a messy frustrating job, and if you had to put a price on the hassle that it is, it is probably better to pay somebody else to do it. That said, remove the starter cover with the cord and pulley inside. If there is a plate holding down the cord pulley, remove it and carefully lift out the pulley, try not to dislodge the recoil spring as this is where the frustration part comes in. Remove the old cord and insert the new cord end into the hole and copy the old knot - pass the other end of the cord through the eyelet in the cover. N.B. At this time take note of the direction that the recoil spring coil is orientated. Wind about 3/4 of the cord around the pulley and attach the start handle to the outside end of the cord. Carefully fit the pulley over the spring and place the cord into the cutout in the pulley. Wind up the pulley so that it engages in the curl in the inside of the recoil spring and further wind up the pulley in the opposite direction of the normal pulley start pull, holding the cord in the little cut-out so that the cord does not wind up as you wind the spring. It probably takes about 5 extra turns on the pulley to get the recoil tension right. Always hold the pulley in place to prevent the spring from jumping out. Release the cord so it can retract and replace the retaining plate. This is all if the spring does not jump out - which it so often does.
If the spring jumps out, hold it by the inside portion and start winding it up, pulling it tight to keep the coil small enough to fit back into its receptacle, . Once the spring is wound up and will fit into its position the problem starts. I found that gripping the spring with an alligator jaw vice grip will allow you to replace the spring and carefully release it without it going wild again, engaging the outer hook in its retaining slot or around its peg. Trying to feed the spring into position coil by coil seldom works, it has to be wound up outside and then inserted, especially on a small motor.
This procedure is as difficult to explain as it is to carry out. I have done many cord replacements and always dread the next one. If you have any problems, feel free to come back to me.
Jul 11, 2011 | Ryobi Garden
How do I repalace the starter cord
Jul 04, 2011 | Poulan Pro 25CC 2Cycle Gas Blower
How do you rewind the spring for the pull rope.
This procedure is as difficult to explain as it is to carry out. I have done many cord replacements and always dread the next one. Please rate this response and if you have any problems, feel free to come back to me.
May 19, 2011 | Homelite Garden
How to install string on trimmer
May 14, 2011 | Craftsman Garden
How do i install new cord to my tap head echo model gt-22ges trimmer
Can you verify the model number please. Models for Echo usually have 3 numbers and sometimes a letter, I do not have a gt-22ges in my data base.
Apr 30, 2011 | Echo Garden
Cord frayed and broke on my honda eu200i
Apr 26, 2011 | Garden
Replace starter cord on echo cs345 chainsaw
Apr 12, 2011 | Garden
I am trying to replace the cord on my mower, but the cord wont spring back in when I attempt to start it. Please help
the spring below the cord 'spool' must be wound tight before new cord is attached.disconnect cord,wind spool in the direction cord would pull it when starting until it stops & hold it there[spring is wound] release it enough to align & attach cord.release spool & allow it to wind cord onto spool.replace cover.
Oct 11, 2009 | Garden
Conair SW-2504GPH Corded Phone Logo
133 people viewed this question
Top Conair Lands Phones Experts
k24674
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Conair Lands Phone Expert? Answer questions, earn points and help others
