2c831 shutter motor - Heating & Cooling
Error E000840 on canon ir2535 every time you want to make a photocopy.
There is a shutter error.While the shutter is in operation, the sensor signal is not detected and, in addition,it is still not detected after 3 retries.
Check the connection of the connector of the shutter motor and the shutter HP sensor. - check the mounting of the pin used to match the shutter gear phase of the fixing unit (See descriptions under "Points to Note When Mounting the Fixing Roller.") - Replace the shutter HP sensor and the shutter motor
Dec 22, 2017 | Canon Office Equipment & Supplies
Error sc270
"check the laser shutter the spring may be missing or out of position"
270 LDU shutter error
[D] Sensor output does not
change even if 1 second
passes after the LDU
shutter motor is on.
Sensor defective or LDU shutter motor defective
1. Replace the LDU shutter sensor or shutter motor.
First thing check the shutter, sometimes they just get stuck. Second check the spring attached to the shutter. Thats my two cents good luck
I don't have access to the part numbers at the moment, but I can almost guarantee the problem is with the shutter stuck/bound up - not the motor/sensor (but there is that small chance). The printer may have taken a jolt during shipping.
It's very easy to remove the laser, just remove the electrical board unit (basically the back cover with 4 screws, the board is attached to it). The the laser unit can be slid out by pushing the 2 tabs (watch the harnesses, there are 2 attached to the iob on the side you may have to unplug first.). The shutter is attached to the top of the laser.
Nov 08, 2013 | Ricoh Aficio CL4000DN, SPC400DN, SPC410DN,...
Canon 40d will not take pictures
1) CF card in camera? Won't shoot without one
2) Does mirror go up?
3) Canon had a run of bad motors for this model - if mirror does not go up, then it is the mirror motor. If mirror goes up, shutter will not fire, press release again then the mirror goes down, the shutter motor is bad (same model motor). If mirror goes up, shutter fires, both blades travel together/no exposure, probably the shutter is bad.
May 07, 2012 | Canon EOS Digital Rebel XS / 1000D IS...
IBM 9068-A03 printer error 22
error 22 normally caused by the motor shutter not functioning.check the motor connection and test the motor movement.if the motor is moving,try to adjust the motor position.it might help if the motor still working or else,replace the motor.
Jan 12, 2012 | IBM Office Equipment & Supplies
The copier is saying: Turn the main power switch (on the main unit's right side) OFF & ON again. If the machine still does not operate normally, contact your service representative with the error...
The shutter open sensor does not go on. (The shutter does not open.)
1. Check the shutter home position sensor. Is it normal? 2. Check the wiring between the finisher controller PCB and the stack feeding motor and between the finisher controller PCB and the shutter open/close clutch. Is it normal? 3. Is there a fault in the shutter mechanism? 4. Try replacing the stack edging motor and the shutter open/close clutch.
May 11, 2011 | Canon imageRUNNER 5000 Copier
I'm getting error code E000584-0001
E584
Main Cause The shutter open sensor (PI5) is faulty. The safety area detecting switch
(MS3) is faulty. The shutter closed detecting switch (MS4) is faulty. The
No. 2 feed motor (M8) is faulty. The finisher controller PCB is faulty.
Mode of
Detection
0001 The shutter closed detecting switch does not turn on when the No.
2 feed motor has been rotated CCW for 1 sec or more.
0002 The shutter open sensor does not turn on when the No. 2 feed motor
has been rotated CCW for 1 sec.
0003 While the tray lift motor is in operation, the shutter closed detecting
switch is found to be off when the tray 1/2 is at OFF position
of the safety area detecting switch.
-David.
Nov 03, 2010 | Canon imageRUNNER 5000 Copier
What is E000584-0001
E584
Mode of
Detection
Mar 20, 2010 | Canon imageRUNNER 5000 Copier
40D turns off as I press shutter button
The shutter mechanism had to be replaced. I've heard that this is a typical 40D problem, due to a shutter design flaw. They say that it has been fixed on replacement shutters.
Jul 26, 2009 | Canon EOS 40D Digital Camera
Canon powershot s2 15 shutter won't open
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
May 10, 2009 | Canon PowerShot S2 IS Digital Camera
Shutter
sounds like the lil motor that is in charge of opening and closeing the shutter might have shorted out causing it to stick, or it could have just simply burnt out or striped the lil gears on the motor. If the shutter moves alil bit i would say you probably have a short in the shutter motor.
Dec 05, 2007 | Fuji Zoom Date 60 35mm Point and Shoot...
Heating & Cooling Logo
149 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
