Question about Garmin GPS
Nuvi 1450 is frozen. Touchscreen is non-responsive and can't turn the unit off. Nothing happens when pressing power button, disconnecting unit from power, or connecting to computer.
  • 343 Answers
SOURCE: garmin nuvi 1450 cannot turn
Have you tried pressing and holding the power button for about 8 to 10 seconds? It should go on then off. Then wait a few seconds the turn it on normally. This usually resets the unit.
If this does not work try a hard reset.
Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite data.
Once it gets going update your gps at the Garmin site.
Thanks for using FixYa
Here is a link to the owners manual if needed.
http://www8.garmin.com/manuals/3130_OwnersManual.pdf
Posted on Jul 01, 2011
n1wgk
  • 84 Answers
SOURCE: Tom Tom go 910 screen get frozen every time I turn it on
I had the same problem...I contacted Technical Support at TomTom and found out the following: I had purchased my unit through Dell and there seems to be a lot of calls in to them to get it going. It IS possible to get it working again. This is a copy of the message I received from Technical Support...it does include formatting the drive...you will need to back up your maps... After all maps have been copied to the computer, we can reformat the disk. This is done by entering to My Computer and right clicking on the drive that displays the TomTom. From there, left click on format and choose start (not quick format). In one to two minutes, the disk will be formatted and all files will have deleted. This does mean we will have lost all demos for audiobooks and mp3 player. After doing this, we can copy the map folders back onto the TomTom drive from the desktop. Then, we can open the TomTom HOME program. Once the program reads the TomTom drive, it will check for updates. These updates should include a TomTom program application and voices. We can download these updates and then choose to install them. Once installed, we can then safely remove hardware. The unit should reboot on its own, but we may have to reset the unit if it does not. After doing this, the unit should be in full working order and you should be able to navigate. Just a quick note...in order for the TomTom to work correctly, we must have an application, a map, and at least one voice installed on the hard drive.
Posted on Jun 17, 2007
  • 55 Answers
SOURCE: Non-Responsive PDA
You may have to do a hard reset. You hold one finger at the power and the other hand hold your stylus and his reset. This technique is applied to most PDA.
Posted on Aug 25, 2007
SOURCE: FROZEN!!! PLEASE HELP!!!
DEFRAG IN MSC! Then check, then format.
Found here, worked for me:
search: format sansa c150
www.fixya.com/support/t137630-mtp_db_mismatch_format
Posted on Apr 09, 2008
SOURCE: New GoGear Vibe will not turn on after first charge!
This is not a solution to fixing the mp3 player, but I no longer need assistance, I returned the product for a refund.
Posted on Jun 05, 2009
Touchscreen on a Garmin nuvi 1350 doesn't work. How do I fix this.
Try recalibrating it using the following method:
Nuvi 11xx, 12xx, 13xx, 14xx, 24xx, 25xx Series: Turn off the Nuvi. Place your finger on the upper left-hand corner of the screen and then push down on the power button to turn the unit on. Release the power button when the Garmin logo appears. Continue to press on the upper left-hand corner of the screen until you see the calibration screen. Press all of the prompted dots.
Once completed the Nuvi will display Calibration Complete
This will recalibrate your touchscreen to the LCD display.
If this doesn't resolves your problem. then your touchscreen may be defective and may need to be replaced.
Please see this page for additional information:
http://www.sharc.net/gps_LCD_repair.htm
Mar 29, 2013 | Garmin nuvi GPS
Tip
Garmin Nuvi 1450 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Does your Garmin Nuvi 1450 Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater.
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 1450 series GPS unit.
I hope that helps.
__________________________________________
Garmin Nuvi 1450 Manual Download
Garmin Nuvi 1450 QuickStart Download
Garmin Nuvi 1450 Webupdate
Garmin Nuvi 1450 Favorites Backup
on May 27, 2010 | GPS
Tip
Garmin Nuvi 1450 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
I hope that helps.
on May 27, 2010 | Garmin nuvi 1450 GPS Receiver
How do I reset my Garmin Nuvi 1450?
From page 4 of the manual, press and hold the power button.
Jan 15, 2012 | Garmin nuvi 1450 GPS Receiver
Garmin Nuvi 1450 will not turn on
Try performing a soft and or hard reset on the GPS.
The soft reset is done with the unit disconnected from the power cord, press and hold the power button down for at least 10 seconds until the Garmin screen is displayed.
The hard reset is done with the unit disconnected from the power cord and the unit off, press and hold the lower right corner of the screen and press the power button. A prompt will appear asking "Do you really want to erase all user data?". This will erase all favorites that were saved to the unit. Press yes to reset the unit to factory specifications.
Run the Garmin WebUpdater program to install or reinstall the latest software for your device. This will usually fix any issues.
Be sure to download the correct version for PC or Mac.
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
You may also want to contact Garmin Support for assistance.
1-800-800-1020
Dec 25, 2011 | Garmin nuvi 1450 GPS Receiver
Comes up with press dot screen nothing I do seems
Have you tried a screen calibration? Turn off the unit then press and hold the upper left of the screen as you turn it on. A dot will show up on screen and then press the dot firmly as it moves around the screen. When it is done it will say screen calibration complete.
I also assume you tried a reset by pressing the reset button or on the newer units just hold the power button while turning it on for about 15 seconds until it reboots.
Sep 25, 2011 | Garmin nuvi 1450 GPS Receiver
My garmin nuvi 660 touch screen dosen't work
To calibrate the touchscreen on a nuvi 300 or 600 series:
  1. Power the unit On.
  2. From the Where to? / View map screen, touch Settings (wrench icon).
  3. Touch Display.
  4. Touch Recalibrate.
  5. A new screen will display that says Press Dot.
  6. Touch the center of the dot.
  7. Keep touching the center of the dot as it moves around the screen.
  8. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
When I turn on my nuvi 200 it says press dot. When I press the dot it just moves around the screen to different location.
To calibrate the touchscreen on your nuvi 200 series follow the steps below:
  1. Have the unit turned OFF and unplugged from power.
  2. Slide the power switch to the ON position and hold for about 45 seconds.
  3. A message will display on the screen: Press Dot.
  4. Once this message displays, release the Power button.
  5. Press in the center of the Dot.
  6. Keep pressing in the center of the Dot as it moves around the screen.
  7. Once this is complete, there will be a message: Calibration Complete.
  8. Touch Ok and the unit will restart.
*Note if unit is running software version 6.00 or newer you will want to follow steps from below.
To calibrate the touchscreen on your nuvi 205 series follow the steps below:
  2. Place your finger in the top left hand corner of the touch screen and apply pressure.
  3. Slide the power switch to the ON position. Once unit powers on release the power button.
  4. Hold pressure in left corner until the Press dot message appears.
  5. Once this message displays, remove your finger from the screen.
  6. Press in the center of the Dot.
  7. Keep pressing in the center of the Dot as it moves around the screen.
  8. Once this is complete, there will be a message: Calibration Complete.
  9. Touch Ok and the unit will restart.
//changed this line from 'solution1description.innerHTML' to use getElementById //to prevent FF warnings. They both appeared to work, but this is cleaner. solution = document.getElementById('solution1description').innerHTML; Last modified on: 09/30/2010
Oct 23, 2010 | Garmin nuvi 205 GPS Receiver
Won't turn off, frozen screen
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Try "resetting" it.
The reset button on your nuvi will switch the device off. The reset button can be used to switch your device off if the screen is frozen and you are unable to switch the device off by the power button.
To reset a nuvi 2xx:
  1. Look at the bottom of the device
  2. Locate the small circle with a dot inside (very small)
  3. Press the circle to reset the device.
To reset a nuvi 3xx or 6xx:
  1. Lift the antenna
  2. Locate a button with the word Reset inside
  3. Press the button to reset the device.
The device will now switch off.
Jul 25, 2009 | Garmin nuvi 260W GPS Receiver
GPS Logo
213 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
