Question about Dell 922 All-In-One InkJet Printer
A long stripe . looks like film with a small opening on each end came off the inside of the printer.on the right side near the ink cartridges. can't put it back and also can't print . lines are blurry and words are doubled. already tried to align papeer .
    Scholar:
  • 192 Answers
Howdy there! It sounds to me that the alligning tape has broke. Is there any way that this printer is older? Maybe not used for a spell? If it is older then it could have dried up and the line will crack and eventually break..... If this is the case, unfortunately, you need to replace the printer as the repair is just about the same cost.... Guy
Posted on Oct 16, 2010
Getting a black stripe on the right side of print
Black stripe is the main problem of damage roller drum inside the toner cartridge or damage fuser film drum inside the printer. Check first the roller drum of toner cartridge if both sides of the roller is tear off. That would be the problem. If not the fuser film inside printer is damage. This is dammage due to continues bulky printing.
But if your refilling the toner cartridge, you need to clean the waste bin compartment of the toner cartridge maybe it is full and waste are overflowing on it making black stripes on your printer and will damage both printer and cartridge.
Dec 09, 2010 | Brother HL4040CN Laser Printer
How do you get the ink cartridge out of the printer
  1. Unplug your Kodak Photo Dock's power cord. Pull the black tab on the right side of the printer down to open the ink cartridge door.
  2. 2 Push up on the green cartridge release tab in the upper center of the ink cartridge to release the old cartridge. Pull the old ink cartridge carefully from the Photo Dock.
  3. 3 Rotate the new ink cartridge's ribbon wheel on the side of the cartridge clockwise with your finger to remove any slack in the film. Do not rotate the wheel too much---this will damage the cartridge.
  4. 4 Insert the new ink cartridge into the Photo Dock with ribbon film facing down until you hear the cartridge click in place. The ink cartridge will only go in one way.
    Do not touch the ribbon with your fingers. Handle the cartridge by its edges.
  5. 5 Close the ink cartridge door and plug in your Kodak Photo Dock's power cord.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Aug 26, 2010 | Kodak EasyShare Printer Dock Series 3
My ink will not move to the side when I open the
Just make sure the printer is on when you lifted up the top cover for the ink cartridge holder to move to the right side.
You may also try this, try copying a blank paper, look inside the printer when you see the ink cartridges move in the side, disconnect immediately the power cord at the back of the printer. Now lift up the top cover and replace the ink cartridge.
Jul 07, 2010 | HP Officejet 4355 All-In-One InkJet...
The ink produces shadows (repeating)
in most cases a fixing film assembly is damage (worn-out).
Open the rear door and look inside with a flashlight  when the printer is warming up and fuser is rotating. You must see the fixing film worn-out on sides.
Oct 05, 2009 | HP LaserJet 1320 Printer
Vertical line on Brothe MFC 8460N
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 22, 2009 | Brother MFC-8640D Printer
Opening the cover
This model print on Thermal transfer technology: there is a black film inside the fax.
Open the cover from the rght side with the green or grey button.
You can then see the black film.
Usually, the top part is the new, the lower is th used.
To know if the film is near empty, you can remove the film from its place and see which side is bigger.
Good Luck.
Mar 13, 2009 | Panasonic KX-FP101 Plain Paper Thermal Fax
My HP Printer does not show color. When I print black and white, I get a pinkish cast and often pinkish printing.
It is possible you're black cartridge is too low on ink & needs replaced. If you're black ink cartridge is new, there could be small ammounts of sticky tape left over the contacts of the ink cartridge. Please clean the ink cartridge's copper contacts (side only, not the bottom of the ink cartridge), with a cotton swab & a little alcohol. Since the ink cartridge is removed clean copper contacts inside the carriage holder as well. Allow time for the alcohol to dry. All most every printer installs software that monitors ink level's. To check you're printer for this. Click the start button, slide up to & click Printers and faxs. The printer and fax window will open. You're default printer will have a little check mark next to it. Right click once on that printer name, another little pop-up window will open, slide to & left click on properties.
You're printer (It's name) will open. Near the bottom click on Printing Preferences. Another window will open. Click the Services tab. Than click Service this device. You should be able to see the ink levels.
Have more questions? Please feel free to ask.
Hope this has helped.
Luck!
Mike
May 12, 2008 | Office Equipment & Supplies
Plastic strip fell off
Hi, if you open the open the printer, unit to gain access to install ink cartridge, if you see the metallic end which has got a hook on both the ends left and right side. the ink cartridge runs between the strip from left to right which should be connected above the ink cartridge meta rod.
< ------------- >metal hooks on left and right above the cartridge rod
======= __ cartridge rod
Let me know for further info.
Feb 05, 2008 | Dell 810 All-In-One InkJet Printer
Printing is out of alignment after "deep cleaning".
Try using the Q-tip and alcohol on the print head (transparent film). Did you refill the cartridge yourself because overfilling will cause ink everywhere. If there is too much ink for the Q-tip, try a kleenex with alcohol. In order to test prints, the excessive ink must be dealt with.
Nov 01, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Small thin film fell out
Try to cut off a thin plastic strip. just try to copy that. it basically guides the cartridge on where to print. also i remember that it should have a spring connected to the holes.
Oct 04, 2007 | Dell 924 All-in-One InkJet Printer
Dell 922 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
