Question about Hardware & Accessories
Timer doesnt turn on , how do you know if the clock is working
If the timer is digital, the screen displays the time.
If the timer is mechanical, the dial on the front of timer rotates as time passes. If dial is not rotating, then timer clock is not working for some reason
Posted on Oct 16, 2010
Oven and digital display clock and timer doesnt work but burners and oven light works
Clock & Main control display issues - YouTube
? 4:44
https://www.youtube.com/watch?v=OmOocInxHOo
Jun 28, 2013 - Uploaded by ApplianceVideo.com
... symptoms: Clock and display does not work At: http://www.appliancevideo.com For ... and show you how to ...
Range/Stove/Oven Repair - Replacing the Clock Timer ...
? 3:42
https://www.youtube.com/watch?v=0RSnf4wfSZM
Oct 20, 2011 - Uploaded by PartSelect
Range/Stove/Oven Repair - Replacing the Clock Timer (Frigidaire Part .... My timer still works fine, but ...
Y0315570 Amana Range/Stove/Oven - Appliance Timer
Dec 01, 2015 | Kitchen Ranges
Why it doesnt start and make a long noise
Grandson just had this problem with our dryer. he was setting the timer by turning it counter clock wise, all he got was a buzz. When it set it clock wise it worked find.
I know this is a simple fit but worked or him
Randy
Apr 29, 2014 | Siemens WFXD5200UC Front Load Washer
Pool timer clicking but doesnt keep time
If timer dial does not rotate and keep good time, then replace clock motor.
Clock motor is getting weak, and maybe trippers are sticking on on-off lever.
Add a bit of white grease to on-off lever, and turn power off then spray metal gears with bit of WD40. WD40 is highly flammable so power should be turned off.
Copy following links for troubleshoot resources, and clock motor replacement.
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
http://waterheatertimer.org/How-to-replace-Intermatic-clock-motor.html
Aug 19, 2012 | Intermatic T104 24h 208-277v Mechanical...
The digital clock on my beko dv555 cooker isnt comin on and as my cooker was on timer now my main oven doesnt work either but my grill and hobs do
Try turning off the power for 3 minutes to try and reset the clock module. If this does not work it will need the clock replaced or a clock by pass done. A good electrician can do this.
Mar 09, 2011 | Ovens
I am not sure on how to wire the freeze protection wires to the time clock. i know they must go to the load side of the clock for the main pump but will this reverse the power back into controls and short...
Here's a 240V diagram with clock timer and freeze control:
Add a comment if explanation does not fit your exact timer:
See image full size:
http://waterheatertimer.org/images/Freeze-protection-500.jpg
Here's how freeze control works:
Freeze control is like regular timer, except it turns ON by thermostat instead of time-clock
Freeze control turns ON pump whenever thermostat kicks on.
Both clock-timer and freeze-control are wired to pump in 'parallel' so to speak.
Think of it as having two controls wired to same pump...
Both controls can turn pump ON-OFF.
If one turns ON, and other is OFF ... then pump is ON.
If both are ON, then pump is ON ... and electricity just flows around on extra wires.
If both are OFF, then pump is OFF.
Say it's below freezing all day.
Freeze control circuit is ON all day ... pump is ON all day
Clock timer turns ON > but circuit is already ON, so timer just opens more wires for electricity to flow around on.
When clock timer turns OFF > freeze circuit is still ON because it's below freezing ... pump is still ON.
240V wiring:
Power leads coming from circuit breaker go to terminals 1&3 on clock-timer
Same power leads connect to freeze-control-black and freeze-control-red.
Or connect freeze-control-black and freeze-control-red to terminals 1&3
This action puts power to clock and power to thermostat
Pump wires connect to terminals 2&4
Same pump wires also connect to freeze-control-blue and freeze-control-yellow.
Or connect freeze-control-blue and freeze-control-yellow to terminals 2&4
This action connects pump to both freeze-control and timer.
When either clock-timer or freeze-control turn ON, then pump turns ON.
Nov 15, 2010 | Intermatic Timer PF1222TB Multi Circuit...
I've set the time on/off and ive tried turning on manually but the lights wont turn on on exact time set. y? when i manually turn on the lights come on 2 hrs later or so, y doesnt it turn on right away?
If I understand correctly, you have an Intermatic timer.
The timer has a yellow dial that rotates around like a clock.
Does the manual override work?
If yes.
a) then the circuit has electricity
b) the lights are in working order
Does the clock rotate?
If yes
a) then the timer is probably good
b) the clock motor could be bad
c) the gears could be rusty and dirty
Do you have the current time set correctly?
Lift and rotate dial until current time lines up with silver pointer.
Do you have the trippers set on the correct time?
There are ON trippers and OFF trippers
Attach trippers to correct time
Tripper pins wear out
Suggestion: You sit in front of the timer and watch the trippers as they rotate to the bottom of the dial
When the trippers get to the bottom, they push a lever that turns lights on and off.
Look at the photo:
Here's a website that sells tripper pins and clock motors for Intermatic timers.
You can buy new trippers or clock motor
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
Answer this post if you still can't figure out the problem, or need more help.
Oct 23, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Just brought a bosch oven and there no life in the bottom oven
If it has a timer, then make sure it is set manual and not auto, or the oven will not work.
Try pressing 2 buttons at the left of timer and one button on right of timer to set it to manual, if it does not work this way, then try another combination of buttons.
Hope this helps.
Plz rate my solution.
Thanks.
Jan 03, 2009 | Bosch HBL 435 Stainless Steel Electric...
Timer doesnt move while dryer is on
Please page me here so that i can get back to you
May 19, 2008 | Estate TGDX640JQ Gas Dryer
Hardware & Accessories Logo
77 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
