Question about HP w1907 LCD Monitor
My HP W1907v 19'' LCD monitor keeps turning off and going into sleep mode, i've took every cable out of it and even the video card out & put it back in please help.
soumyak
  • 73 Answers
SOURCE: sleep mode Philips LCD Monitor
I think u need to check monitor properties.In those properties in screen saver mode there is a power button.u need to select that power button and change the turn off monitor option.
Posted on Sep 15, 2008
tantong
  • 138 Answers
SOURCE: Monitor problem
Hi, I used to repair a monitor from Dell. You might have to check what wrong with your monitor when it went back by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem like broken lamps and it is very easy to replace. But the most important part is you need to know how to teardown the screen. . If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Hope this help you to examine your monitor. If there is anything I can help you with, feel free to let me know.
Thank you,
Posted on Mar 13, 2008
  • 3 Answers
SOURCE: envision 19"lcd monitor
Could be a problem with the VGA cable. Try using another one. But first you might also like to check your graphic properties. To do this simply right-click your mouse on the desktop, go to graphic properties and make necessary adjustment if or as required.
Newarz
http://visualtreats.googlepages.com/
Posted on May 16, 2008
  • 156 Answers
SOURCE: Monitor says No input signal and going to sleep.
Try cleaning your RAM it should be the issue mostly 80%
You can check by rremoving the VGA cable if the system shows no signal mostly monitor should be fine
Posted on Nov 30, 2009
noone
  • 105 Answers
SOURCE: I've got a HP w1907v
If this monitor is going into sleep mode the normally blue power led will change to yellow. This indicates loss of video signal or possible out of range resolution. If the picture goes dark and the power lite stays blue, you have a backlight malfunction. It can be an inverter power fault but this model mostly has worn out backlights causing a shutdown condition.
Monitor Mike
Posted on Aug 21, 2010
When i turn on my pc and window is coming up after 30 seconds or 1 minutes my monitor is going to sleep and then i have to turn it off from case and then turn it on my monitor is hp w1907v please help me...
if you can see the Windows Logo. i think the problem is with the Video card.
try to boot in safemode:
Turn off computer and as the computer is booting tap "F8 Key" Continuously which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
see if your going to have the same problem. if not try to reinstall the graphics driver or see if other application is causing the problem
May 10, 2011 | HP w1907 LCD Monitor
I have an HP w1907v monitor. It is connected to my PC via a blue 15 pin VGA cable. It has now started going into sleep mode when connected to my PC. The monitor came with the PC and is 3 years old. I have...
If the monitor works when connected to another pc then it's good and the defect is in your present pc - its video card is defective and it will have to be replaced.
Apr 18, 2011 | HP w1907 LCD Monitor
When I start the computer the Windows XP Logos light up on the Monitor (HP w1907) when the computer starts the Logo disappears and the monitor goes to sleep
If this monitor (HP w1907) is going into sleep mode the normally blue power led will change to yellow. This indicates loss of video signal or possible out of range resolution. If the picture goes dark and the power lite stays blue, you have a backlight malfunction. It can be an inverter power fault but this model mostly has worn out backlights causing a shutdown condition.
Monitor Mike
Aug 19, 2010 | HP vs19 (Silver) 19" LCD Monitor
I've got a HP w1907v monitor and latly it has been going into sleep mode without warning while i'm using it. All my power saver settings are set to off.
Monitor Mike
Aug 18, 2010 | HP w1907 LCD Monitor
Hello
I FIX LOTS OF COMPUTER, AND MY ADVISE IS. IT MIGHT BE YOUR COMPUTERS VIDEO CARD CAUSING THAT PROBLEM . ALSO CHECK FOR VIRUSES THEY CAN DO STRANGE THINGS.
Mar 17, 2010 | Computers & Internet
Monitor says No input signal and going to sleep. Pc is on and running Vista. Hp w1907v monitor HP Pavillion slimline pc. Can you help please?
Nov 30, 2009 | HP w1907 LCD Monitor
HP w2207 monitor keeps "going to sleep" then it will not come back on and says no input signal.
most times this is indicator of a video card problem, most times you try booting in to vga mode and see does it go to sleep. if it does not go to sleap you video driver is bad and needs to be reinstalled. if it does go to sleep it is usually video card issue. to boot in to vga mode turn ur pc off and once u press on to put it back on start pressing button F8 and advanced menu will come up and you have to choose boot in to vga mode. if this does not work same way go to safe mode with networking and reinstall video driver by going in to device manager.
Nov 27, 2009 | HP w2207 Monitor
No Input Signal, Monitor Going to Sleep
if you have twisted od bent the cord to much the wires could have broke inside the cord.
Jul 31, 2009 | HP w1907 LCD Monitor
Monitor going to sleep at startup
try changing the video card of your computer..
Aug 27, 2008 | HP vs19 (Silver) 19" LCD Monitor
Issue with 20" WideScreen Monitor
I think you are having trouble with the plug the cable connects to.
Jul 09, 2008 | HP L1955 19" LCD Monitor
HP w1907 LCD Monitor Logo
1,036 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
