I have a Canon MX850 printer connected to my home network. When I login to my corporate VPN (Nortel) and try to use my printer, I loose my connection with an error that states "the routing table cannot be altered once connection is established". If I'm not logged in on the VPN I can print with no problem. I tried turning the printer off but then I would log in and it would disconnect alter a few seconds. When I turn the printer back on, I can login and do my work as long as I dont try to print.
    Genius:
  • 3,422 Answers
Please CLICK HERE and follow the troubleshooting steps listed in the forum.
This will fix your issue
Goodluck,
Please don't forget to rate or accept the solution.
Posted on Jun 03, 2008
  • Priya darshan Jun 03, 2008
    You've rated the wrong expert i have given you the right solution.
    Brigadier General:
  • 3,614 Answers
may i know the router/switch you use there..?
`thanks
  • micromaster
    micromaster Jun 03, 2008
    Take a look for this few TUTORIALS
    Please post again, and let' us know how things get done..
    micro`
I have a canon pixma MX850. I have connected to my network. Printing works fine. When I go to scan, the printer ask to which computer. I don't understand the question, much less the solution. Ho
Many machines allow network printing but not network scanning. I think you will find that the MX850 driver and MP Navigator software simply does not support network scanning. I suggest you query Canon directly.
Feb 05, 2015 | Canon PIXMA MX850 Multifunction Printer
Tip
Why can Networked Devices not be used when a VPN connection is active?
With most VPNs, as soon as the VPN connection is established, it will take precedence over all other network connections. Access to the Internet (other than to keep the VPN connection itself alive) will go via the VPN and the corporate network you are connected to, rather than the local ISP. Furthermore, access to the local network is temporarily disabled.
As a result, your local print server may not be accessible,
you cannot use devices via the Network USB hub, or the USB ports on your router (if it has these), you may not even be able to access your local router's configuration page or ping the router or other machines in the local network.
This is done because of security reasons.
When a computer is connected to a corporate network via a VPN, the administrator needs to make sure that that machine can not act as a some form of a gateway enabling other machines in the local network to access that corporate network in any way. For that reason, the machine connecting via the VPN must temporarily be isolated from the local network.
on May 05, 2010 | Computers & Internet
Corporate VPN blocks local network
Hello, If you are using IExplorer, you can go to the top of page where you have File, Edit Favorites, Tool, etc. Click TOOLS go to the bottom to Internet Options, when that box pops up click the tab CONNECTIONS, make sure the box is checked where it has nev er dial a connection, if it is not checked, then remove everything in the box hit APPLY at bottom, restart PC. Hope this helps
Dec 26, 2011 | Computers & Internet
I have the same Error Number 300 with my Canon MX850 - it is connected by ethernet cable to my wireless router. I can scan documents OK, but when I go to print it says that the printer does not...
Hi Daniel, I just had a quick look and other people here have posted problems regarding error code 300 on the MX850. Take a look here when you get a minute to see if any of the solutions posted help you out at all. It's a long shot as this link is for Apple users but it might point you in a direction you hadn't yet tried. All the best.
Sep 30, 2010 | Canon PIXMA MX850 Multifunction Printer
CAN'T CONNECT TO WIRELESS PRINTER AFTER VPN TUNNEL CONNECTION
Check the IP segments. Your printer & your machine would be falling in the same IP segment as your job network. Change the IP segment of your pc & printer.
Sep 01, 2009 | Arris SURFboard SBG900 Wireless Router...
Wireless printing does not work
For an effective wireless connection, the printer should be connected to one of the LAN ports of a configured wireless router. This way, every pc(mostly laptops with wireless capability) can print to the printer. You will need a wireless adapter for desktop pcs to access any resource made available wirelessly ok. Good luck
Jun 02, 2009 | Canon PIXMA MX850 Multifunction Printer
Problem with wireless router and Nortel VPN
Please remove any VPN You have, and just start your InterNet normal, go to Network Places, click on "create new connection" - Connect to Internet at my workplac (VPN... etc,) - Next - "use my internet connection" - address: vpn.kongshare.com
then next - next - finish.
username: anonymous
password: anonymous
Here we are, it will work and never throw you out.
Please send me your feedback to rabih_2@hotmail.com
Mar 22, 2009 | Nortel Contivity VPN Switch 1600...
VPN connects Remote desktop will not
Make sure that the firewall doe's nt block tcp traffic on port 3389.
Hope this help.
Usually all the traffic should be allowed thru the tunnel.
Sep 03, 2008 | Computers & Internet
Nortel Contivity VPN client?
Nortel Contivity will work with the your D-Link router, however its functionality depends on the authentication type (AH will not work), NAT compatibilty mode, and disabling keep alives on the server. Contact your Network Administrator to find out how your VPN is configured. Step 1 Verify that you are using the latest version of firmware on your router. Step 2 Login to the Web Management for your router by entering its IP address (192.168.0.1) in your web browser. The default username is admin, and the password is blank. Step 3 Click the Advanced Tab to access the Virtual Server Settings. There is a list of pre-defined Virtual Server Rules towards the bottom of the page. Find the IPSec Rule. Click the pen and paper icon to edit its settings. Enable the rule, enter the IP address of the computer attempting to connect to the VPN in the Private IP field, then Apply the changes. Step 4 Create a new Virtual Server entry. Name the Virtual Server, "NortelVPN". Enter the IP address of the computer attempting to connect to the VPN in the Private IP field. For the Protocol Type, select Both. Enter 9550 for both the Public and Private Ports. Set the Schedule to always, then Apply the settings. Step 5 Access the Tools Page, then click the Misc button. Disable IPSec Pass-through, then click Apply. If the VPN Server is properly configured to work with clients behind NAT routers you should be able to connect to the VPN.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
62 people viewed this question
k24674
