Question about Kitchen Ranges
Light cover for Zanussi Zhp 613 x/a
I need to purchace a new light cover as i am missing one on my Range Hood.
Can you help me!
    Genius:
  • 1,036 Answers
Espares have them for £4.99 + the usual.
Their link is here for ordering.
http://www.espares.co.uk/part/cooker-hoods/zanussi/zhp613nx%2fa/p/1091/332/0/1003008/622089/light-diffuser.html
Hope this helps,
Posted on Jun 11, 2008
FGMV205K cover removal
Good Afternoon Friend,
I understand that you want to know how to remove the cover on your Frigidaire microwave, model# FGMV205K. There are two different covers that you are able to remove for access to two different light bulbs.
If you are trying to change the Microwave Oven Light for inside your microwave:
    1)To replace light bulb, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
    2)Remove the louver by removing the three Hood Louver Screws.
    3)Push in the upper tabs and pull the louver away from your appliance.
    4)Remove the light bulb and replace with a new 20 watt light bulb. DO NOT USE BULB LARGER THAN 20 WATTS.
    5)Close the Oven Light Cover by carefully pushing into place. Push the louver back into place (engaging both the bottom and top tabs) and change to hood Louver Screws.
    If you are trying to change the light bulbs underneath your Microwave:
      1)To replace light bulbs, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
      2)To open Light Cover, remove the screw on the light cover.
      3)Replace the light bulbs with new 20 watt light bulbs. DO NOT USE BULBS LARGER THAN 20 WATTS.
      4)Close the Light Cover and secure with screw removed at step 2.
      If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
      -Best Regards-
      WP
Jun 07, 2014 | Frigidaire Gallery FGMV205K 2.0 cu. ft....
How do i change a bulb on a zephyr verona range hood
I could not turn the bulb, and the rubber glove approach did not work. I unscrewed and removed the middle cover, which meant I could easily reach inside and turn the whole light bulb fixture.
Apr 18, 2014 | Zephyr Kitchen Ranges
Need light cover nutone whispaire 36'' stainless hood aprox 20007
You might be able to get the part from an appliance parts supplier
Mar 21, 2013 | Broan-NuTone Intermediate Whispaire ...
How to change the light in technika range hood
Safety is important when is comes to replacing a light bulb of a range hood. The first thing to remember is to turn off power and allow lights to cool before proceeding.
home light
Jun 03, 2012 | Kitchen Ranges
How do you remove the light bulb cover in a fivestar 48
You remove your incandescent light bulb and insert your automotive LED light bulb.The LED lights cover the landscape area for people to be able to see.
home light bulbs
May 28, 2012 | Five Star FiveStar 48'' Range Hood -...
Burned out light on bertazzoni hood
Here is how I fix this problem in case someon is still looking for an answer: 1. Turn power to hood off at electric panel 2. Remove light diffusers - these are the round glasses under hood covering the light bulbs. Turn the light diffuser counter clock wise to remove 3. Remove the burned out light bulbs 4. Install the new light bulbs
Jan 05, 2012 | Bertazzoni K48HERX 48" Kitchen Hood
The light diffuser cover is broken. The model number of the range hood is HO60488. The range hood dates back to possibly the late 1950's when the house was built.
When faced with the total unavailability of replacement parts, its time to get creative, and make your own diffuser cover. Flat ones
can be easily made - find anything plastic that's semi-translucent (like a plastic milk bottle), and cut it with a utility knife.
I have also used a utility knife to cut a polystyrene diffuser cover
originally intended for a 2-ft x 4-ft suspended ceiling fluorescent light fixture.
In case the diffuser cover you make wants to burn when placed close to a light bulb, replace the bulb with a CFL (compact fluorescent) bulb, which run MUCH cooler than incandescent light bulbs.
Old lampshades can be cut and used, but may need to be ironed flat. The major advantage of lampshade material is that
it can be folded over at the edge once or twice, which will fill space - and possibly hold the cover where a plastic sheet might be too loose.
You'll know that your efforts have met with success when you can easily remove your ne diffuser cover to replace the light bulb.
Feb 20, 2011 | Venmar Kitchen Ranges
Venmar stove hood, plastic cover for light is broken
Need plastic cover on Venmar vent Hood, which measures 3 1/2 inches by 18 inches with 2 tabs.
Sep 06, 2009 | Venmar Kitchen Ranges
Light doesn't work on Kenmore Model 55022 Range hood...
If you have 120VAC on the center contact of the light socket, and a working fan, but the bulb won't light...the most likely cause would be a disconnected neutral wire (white) in the light wiring inside the hood....assuming everything else is wired correctly.
If you're comfortable with further electrical testing...let me know, and I can describe a detailed procedure to check the status of the neutral wire. Otherwise, you may need the assistance of someone familiar with electrical troubleshooting or appliance repair.
Jan 27, 2008 | Kenmore 51840 Kitchen Hood
Kitchen Ranges Logo
189 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
