Question about Kenmore Dryers
I have a Kenmore electric dyer (model 110.68932790) When I push the switch (part no. 3395382), the drum will only turn for a fraction of a turn and then it cuts off. Do you think the switch might be defective?
  • 958 Answers
SOURCE: Kenmore Elite Dryer, Model: 110 60972990... will not restart.
yes, a DIY person can replace a thermal cutoff. just open the rear of the unit and look for parts with big red wires connected to it. it is round, one small and one big. both have two terminal clips.
if you can find the schematics inside the switch panel, then it would help you further. the thermal cutoff consist of two pc. replace both even one of them has continuity.
tnx 4 using fixya,
drcool
Posted on Sep 29, 2008
  • 163 Answers
SOURCE: Kenmore Electric Dryer 70 Series
your motor is over heating and shutting off.you need new motor.
Posted on Mar 11, 2009
  • 120 Answers
SOURCE: Kenmore 970 C81062 10 Electric Dyer WILL NOT
It sounds like the drum may be stuck. Turn the dryer on with the door open, just keep the button pushed. Then try to turn the drum by hand, and see if it will start to turn.
Posted on Jun 04, 2009
dmftrucker
  • 1922 Answers
SOURCE: my hotpoint model NVLR333ETOWB, will not rotate drum
sounds like the belt is loose from a defective idler pulley
Posted on Oct 24, 2009
  • 1218 Answers
SOURCE: Maytag Dryer won't start withouth me turning the drum.
Good day. Ugly problem.
My first choice would have been the motor, but.......
Here is the process, it might help you.
The power to the motor goes first to and thru the door switch. It then returns to the timer.
When the timer is turned to any running position, power leaves the timer where it is split into 2 leads.
One of the power leads goes directly to the centrifugal switch Which is the switch on the motor with all the wires. If you spin the drum, you also spin the motor, and if spun fast enough will close the contacts on the cetrifugal switch, thus sending power to the motor, allowing it to run. I guess you have done that.
The second lead out of the timer goes to the push to start switch, it then leaves and goes to the centrifugal switch but on the power side, so it is directly connected to the main winding in the motor.
That is why when you press the press to start switch, the motor runs, and if held in it will continue to run.
In fact, at this point, the motor had 2 sources of power, either of which can run the motor.
Thus releasing the push to start switch doesn't matter, since it runs off the other source.
Possibilities.
The centrifugal switch is not wired right. Please recheck. (or the motor was bad out of the box. Happens).
The push to start switch is bad, and needs replaced.
Or, the wiring going to or leaving the push to start switch has broken or making a bad connection.
Lastley, I said the power comes out of the timer and splits into 2 circuits. Not always true, in some models the timer sends 2 seperate wires out carrying the power, with the possibility the timer could be bad.
Hope this helps.
and thank for using FixYa
Posted on Jan 07, 2010
Testimonial: "Jack was a great help. Really took the time to help me with my problem in depth. Thanks again."
Dyer will not turn on. Can hole the starter button in and dryer will run. remove and the dryer will stop running. When holding the start button the dryer does not heat. Any Idea's as to what may be...
broken belt or broken broken belt switch most likely. Open the door. Hold in the door switch and push the start button. Does the drum turn? If it does turn then the broken belt micro switch is where I would look first. If the drum don't turn of course I would replace the broken belt.
The only Kenmore dryer that has a broken belt switch is the 4 wheel drive model. Here is a video which shows how to get into this dryer and replace the belt:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 08, 2011 | Kenmore 63932 Electric Dryer
I have a Kenmore Electric Dryer Model# 110.96551220. When i push the strat button, the dryer does not start but I hear a surging type noise. Any idea what is wrong?
you will need to remove the front panel, unplug dryer, open dyer door remove screws from inside the door frame, with a flat tip screw driver gently pry up as it is clipped and it will pop up, you will need to disconnect the door switch and sit the front panel aside. The top of the dry will lift up, on the motor look for two switches.buttons one is a reset the other is a trip. you will hear a click when you reset it. hopefully this is the problem, if not then see if you can turn the drum, it should be hard to turn but turn all the same. Hope this helps tim
Sep 11, 2010 | Kenmore Dryers
Kenmore Elite Smartheat Quiet Pak 9 won't start. Light turns on and off inside drum when door opens/closes, but no lights come on on the outside display.
My Kenmore Elite dryer keeps beeping..just going through the end of cycle alarm-high,low,off...anyone have any suggestions?
May 30, 2010 | Kenmore Elite HE4 Electric Dryer
I have an electric dryer. The breaker went off and when reset the dryer would not come back on. I am not sure if the push button on/off switch is now working or if there is a reset on the dryer
I have a Kenmore 80 series electric dryer. The light comes on when the door is open so I know it is getting power but dryer will not turn on. Is the push button not working or can I reset the dyer?
Dec 06, 2009 | Roper REX4634KQ Electric Dryer
No heat
Sounds like you have two problems John.
1. Sounds like you could have a faulty motor run capacitor.
2. Sounds like you have a faulty heating coil or thermostats.
If you have a front load machine, remove the front. This will expose the drum and belt, remove the belt and this will expose the drum rollers, idler arm with pulley, and motor. This will allow you to check out the motor.
I hope this helps
Oct 02, 2009 | Kenmore 62602 Electric Dryer
Dryer won't start
The problem is likely a malfunctioning centrifugal start switch in the motor.
More info, let me know.
Charlie
Aug 20, 2009 | Kenmore Dryers
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
Jun 04, 2009 | Dryers
If I push and hold pressure on start button Kenmore will run ?
Bad start button, most likely. Go to my site and enter this part number, also look inside door for complete model number and you possibly will need to call their toll free number. Kenmore numbers look like this 584.895674 Try part number on the search feature and call. We offer free help. Switch - Push to start number 3395382 my site click on below, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Apr 10, 2009 | Kenmore 62602 Electric Dryer
Dryer will not turn on
your motor switch is bad you need to replace the mmotor
Mar 02, 2009 | Kenmore 62602 Electric Dryer
Dryers Logo
42 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
