Question about Whirlpool Calypso GVW9959K Top Load Washer
Pump replaced today, 30mins after tech leaves error message and not draining
I have the Kenmore Calypso, tech replaced pump today, after he left still not working, error message FD and not draining water, the techs seem not to know what is wrong, please give me some info so i can tell them what to do.
    Genius:
  • 2,035 Answers
IF the water draining check the valves of the machine :
error code is :
FD:::::::::::Shorted meat probe
Note: Problem can be with the probe or receptacle or meat probe circuit. · Check probe. Resistance should be 30k ohms to 50k ohms at room temperature.
· Look for pinched wire.
· Look for condensation or contamination of receptacle or nearby installation.
Posted on Jun 03, 2008
  • 868 Answers
You still have a clogged/damaged pump.There is a class action law suit from Whirlpool and you are 100% eligible,but YOU have to contact them and give them the information they ask of you.
  • Archie Ferrarini
    Archie Ferrarini Jun 03, 2008
    ANYONE WHO HAS THIS LEMON NEEDS TO CONTACT WHIRLPOOL :CLASS ACTION LAWSUIT IS THERE BUT YOU NEED TO MAKE THE CLAIM.
    Scholar:
  • 110 Answers
If they have already changed the pump you are or should be under warranty with them. they all also need to check to see if debris is stuck at the check ball and in the drain hoses, otherwise their is a fault with the control board
  • 487 Answers
It can be that you have no airgap between the hose and the drain pipe or........... someiting is obstructing the water from coming out of the drum. He needs to take out the agitator and see if there is no obstruction in front of the drain hole.
Check this out please.
WHIRLPOOL
  • eric bosman
    eric bosman Jun 03, 2008
    When you follow the link you can see the 2 hoses attached to the pump. The can be clogged but that seems un likely.
  • 3,037 Answers
Check for clogs in the hoses for one, if it is beeping, the overfill switch may have been tripped. Try unplugging it to reset or press STOP/Cancel
also check valves, let me know what you find and let me know if anything else is showing up wrong
Whirlpool Calypso error code
Hi
Thanks for using FixYa. Error Ld means long drain and it flashes when the water level will not change even after the drain pump is on. To resolve this issue you’ll need to check the drain hose and the drain pump for any blockages. Also check if the pump is running fine and replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 31, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Error code FL and does not drain completly
most probably needs the water pump replaced.  not hard to do if you are a little handy..  there were a lot of problems with this machine regarding the water pumps.
Jul 22, 2010 | Kenmore Washing Machines
Kenmore calypso washer will not spin the clothes ld or ob signal continue to show even after i have evenly distributed the clothes
The OB indicates and out of balance condition has been detected by the motor control. You say this happens when the washer is empty also. One thing about the OB error is that the lid must be opened to clear the error and allow the washer to advance to the next part of the cycle. If the lid is not opened to adjust the clothes then the OB error will happen again.
If the OB error was cleared and the OB occurs with an empty load then the motor control has failed.
The drain pump must work. The image below shows how to run a diagnostic test to check the drain pump. Follow the instructions in the image below and check the drain pump operation. If the pump runs and the water does not drain then the sump is clogged. If the pump hums but does not run then the pump needs to be replaced.
http://media.fotki.com/1_p,wkktswgwqtqrbwfxgtqsskgwtqkq,vi/gftrgbbtfxfffgqskfk/1/1303472/5961857/image48348img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 15, 2010 | Kenmore 24032\24036 Top Load Washer
Calypso washer error codes
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$^@#%
Aug 31, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso: LD error message
hi replace the hall sensor... this will remove ur LD error code...
thank u
rate me!!
May 24, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
FL code on a Kenmore Calypso top loader
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$#@!
Jan 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite Calypso wont drain
Oh the dreaded calypso pump...Seen that one a million times. Pumps get clogged pretty easily. Try to get the water out manually first. Than push the washer back and lean it against the wall so that you can access the bottom. Remove the 3 screws. Bottom panel should come off. The pump is on the right, its black. Get ready with a shop vac or alot of towels, theres gonna be a flood. There are 2 clamps on black hoses that need to be taken off so that you can slide the hoses off the pump. Next remove the 3 bolts that hold the pump in place. Next lower the pump out of the hole it sits in. Youll have to follow the wiring harness up and disconnect it. Now you can try and clen out the pump or replace it. Part # is 285990. Costs about 75.00. Hope that helps. Let me know if yiu need more help. Dave www.washermd.com
Dec 11, 2008 | Kenmore 22422 Top Load Washer
Ld and ob error codes
hello.........
“LD” stands for “long drain,” meaning it took an excessively long time for water to drain out of the washer. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I’ve even heard of bra wires coming loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Can you imagine? Yea verily, as surely as the Sacred Suds doth eternally pass my lips, the “LD” error code springs forth from such anomalies.
Sep 07, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
LD is an error code for 'Long Drain'. The water pump may be clogged, there may be a clog under the washplate where the water exits the tub or a clog at the check valve. The best place to start is the water pump.
Jul 12, 2008 | Kenmore 20172 Top Load Washer
Washer gets ld code
The ld fault is a long drain error. Check your drain pump reservoir and drain hoses for clogs. Removing the agitator in my opinion would be unnecessary. Unplug your machine and remove the back panel. There should be a drain pump reservoir at the bottom under the wash basin. They are notorious for collecting lint and hair and can obstruct the drain flow. You can also squeeze along the drain lines and feel for obstructions. To access the drain pump itself, its easier to remove the front panel. You will need to release the two metal hold down clips located under the front lip approx. two inches from either side. You need a putty knife to push in on the clips and lift on the top front at the same time. Once you have the top released, lift up and remove two screws holding the front panel. The front panel should pull away leaving an open access to the inside cabinet. The drain pump is located on the lower right-hand side of the wash tub at the very bottom of the unit. You can easily remove the two drain lines at the pump and check for obstructions there as well. Again, unplug the unit before servicing the pump. I hope this helps.
Mar 29, 2007 | Kenmore 23822 Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
264 people viewed this question
Dan Webster
Dan Webster
Sal De
