Question about Kenmore 63252 Microwave Oven
The turntable doesn't turn while operating - Kenmore 63252 Microwave Oven
  • Kenmore Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ..
Posted on Oct 16, 2010
Manual for a whirlpool microwave oven model wmh31017aw-1
There is no turntable control. It is always on. The turntable should change direction each time the unit is used. If the turntable is not operating, it has malfunctioned. Newer microwaves for the most part all have full-time turntables to promote even heating, thus reducing customer complaints about ovens that don't heat right.
Dec 30, 2015 | Whirlpool Microwave Ovens
Turntable will not turn
see the diagram attached: God bless you
If the carousel inside your microwave won't turn when you run it, the small motor that operates it may be broken.
Jul 09, 2013 | Baumatic BTM25SS Convection Microwave Oven
My microwave makes a grinding noise when running and the turntable doesn't work.
Possible there is friction within the drive , the shaft or the motor. You can remove and RESET the drive. Remove the motor , MANUALLY check the motion of the mechanism which will confirm the case. You c an reset using a bit of lubrication.
Jan 10, 2013 | Microwave Ovens
Microwave turntable keeps turning even after timer is off and door is open
There are one or two door switches that have become defective, they must be replaced for normal operation.
Mar 24, 2012 | GE Microwave Ovens
Sharp R-405H microwave turntable doesn't rotate and makes strange noise
Replace the turntable motor, it is defective and will only get worse.
Mar 17, 2012 | Sharp R-405H 1100 Watts Microwave Oven
Turntable doesn't turn, no heat. Turntable cleaned, installed properly
heatman101
Jul 28, 2011 | Dacor Microwave Ovens
Turntable turns intermittently so unit will not operate
The turntable fan and light all share the same feed, first check wiring for loose connections the problem though is most likely with the controller
Dec 28, 2009 | Viking DMOC205SS Microwave Oven
Turntable does not work
If the rest of the oven works fine, then this indicates that you might have a problem with the motor that turns the turntable.
If you try to turn the turntable manually (gently), does it turn freely or is there resistance? If it turns freely, the mechanical mechanism between the turntable and motor may be broken and the motor may be ok.
The oven's microprocessor also controlls the motor. There could be a problem there.
You'll need to have it looked at by a service center. Although its not that difficult to determine which of the reasons I mentioned above is the cause, it can be however, dangerous to operate a microwave oven with the cover off and with high voltage circuits exposed.
Please let me know if I can be of further assistance to you.
- Jim
Mar 08, 2008 | Goldstar MV-1526 Microwave Oven
Emerson Microwave Oven AT1551
The fact that all other functions seem to operate ok, indicates that you might have a problem with the motor that turns the turntable.
- Jim
Feb 13, 2008 | Microwave Ovens
Kenmore 63252 Microwave Oven Logo
61 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
