Question about Bosch WFK 2401
Hi - Our Bosch WFK2401 washer wasn't spinning. As per other suggestions on this site, we replaced the brushes. The old brushes were quite worn - one was worn down to the brass. Unfortunately, the drum still won't spin. We've also made sure the trap is clean and did that before we replaced the brushes. We've also re-run the diagnostics (Result = 08). Does anyone have any suggestions? Does the fact that the drum still won't spin after replacing the brushes suggest it really is a motor issue? If so, we'll be getting a new W/D set as this set is 9 years old. Thanks!!
  • bberryhermit Oct 16, 2010
    Actually, my husband noticed when he put the brushes in that one was easy to put in, and the other was very tight, almost to the point of obstruction. He filed a very little off the long side of the "tight" brush and replaced everything and voila! it works!
  • bberryhermit Oct 19, 2010
    My husband actually suspected it was a brush contact issue. The one brush didn't go all the way into the slot as easily as the other, so he very lightly filed the stubborn one and now it works! Therefore, if there's anybody else who replaces brushes, we suggest ensuring there is contact before you abandon this potential solution.
    Thanks!
    President:
  • 1,554 Answers
The fault code is actually speed sensor fault. It happens when no speed is detected by the motor control through the speed sensor. It is either a motor winding is open, harness connection to speed sensor and motor is broken, motor control is at fault, or the speed sensor itself is at fault. Check the continuity of the motor windings, speed sensor and the harness. If all of these turn out okay, then the motor control is the one at fault.
Posted on Oct 16, 2010
  • Jahn27
    Jahn27 Oct 16, 2010
    The tight brush didn't go all through to make the necessary contact.
Bosch FD8805 washing machine rinse light was on but nothing working replaced brushes on motor were well worn down but still no response machine dead apart from flashing rinse light dn
Plug off the power cord from the wall mains. I give you several alternatives, sort out thru the easiest: Note your brand and model. Check on YouTube for change of motor brushes. Then disconnect your motor and check your brushes; follow noting how you dis-assemble so you can re-assemble easier. If your brushes are less than half an inch long get new brushes (thru this very site Fixya) and refit; actually this is quite easy. The spin has a lot to do with worn motor brushes. Manufactures want you to dump machines and buy; it helps them all. Not you - you shell out bucks.
If you have already cleaned out your filter, which is usually just under the tub (be prepared for a lot of water; and disconnect from the wall power socket), your washer still may not spin. So look into next para below. The tech sheet is usually taped to the body of the washer inside somewhere.
Note your brand and model. Check on YouTube for change of motor brushes. Then disconnect your motor and check your brushes; follow noting how you dis-assemble so you can re-assemble easier. If your brushes are less than half an inch long get new brushes (thru this very site Fixya) and refit; actually this is quite easy. Thespin has a lot to do with worn motor brushes.
Check the motor housing for an overload button, usually on the back and coloured black or red. Give it a push and if it clicks then the motor might have just been overloaded and shut itself off.
There is a big connector located at the motor - giving power to the motor (located under the tub) to the right side, could be loose. Disconnect the connector and refit to make sure it is tight. Before refitting the back, etc, try the spin alone; if it works you are done.
Click if helped pl, at my solution. I am doing this for the enviro. (& you)
Apr 05, 2013 | Bosch Washing Machines
Bosch wfk2401 fault 08
Most likely this means you have a belt problem, or the brushes have worn out. If you are confident, UNPLUG the machine, and remove the back cover. It will be obvious if the belt has come off, and you may be able to re-instal the old one, or buy a new one.
Worn motor brushes will be less obvious, but if you're reasonably confident with electronics, you could remove the motor, and inspect the brushes, or get someone else to.
Sep 28, 2012 | Bosch WFK 2401
Our Bosch wfmc1000uc washer will not spin leaving clothes soaked. We unplugged and did lint ***** suggestion and still does not work. I read about bushes for motor but am not sure if there is any other...
It does sound as if the motor requires replacement. It is not uncommon to find that the brushes are worn sufficiently for them to not make perfect contact with the commutator.
Now, a word or two of advice from this old hand- it might be suggested that just the brushes on the motor want changing; experience (of others) suggests that they may only last months rather than many years UNLESS the motor itself is refurbished. Refurbishment includes skimming the commutator on which the brushes run. Without skimming the brushes do not sit cleanly on the commutator (like the worn ones!), often causing excessive sparking and excessive wear on BOTH. Alternately a new motor! I changed the motor on our 19+ year-old Bosch at a cost of GBP250 ;-0(
The choice of course is entirely up to you- but do not forget that it is not an uncommon fault, especially if the washer is not exactly new. Others I have given this advice to have chosen new brushes and I don't blame them!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Aug 30, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
We have a Kenmore washer. It does everything but will not spin. At first it would spin if you gave it a boost. Now it does not spin at all.
It does sound as if the motor requires replacement because it is struggling, particularly when called upon to run the spin cycle. It is not uncommon to find that the brushes are worn sufficiently for them to not make perfect contact with the commutator at the higher speeds- bouncing and sparking. Now, a word or two of advice from this retired Englishman in SW France. It might be suggested that just the brushes on the motor want changing; experience (of others) suggests that they may only last months rather than many years UNLESS the motor itself is refurbished. Refurbishment includes skimming the commutator on which the brushes run. Without skimming the brushes do not sit cleanly on the commutator (like the worn ones!), often causing excessive sparking and excessive wear on BOTH. Alternately a new motor! I changed the motor on our 19+ year-old Bosch at a cost of GBP250 ;-0(
John C
Jul 24, 2011 | Kenmore Washing Machines
My Frigidaire Model ATF6700FS1 does not spin unless it is empty? The belt was replaced once under warranty already, but now the machine is two and half or three years old.
Sorry for the not so good news but it does sound as if the motor requires replacement because it is struggling, particularly when called upon to run the spin cycle but your washer is not that old and well used.(Our Bosch was 18+ years old when I had to replace the motor- not that that helps you at all!)
John C
Jun 28, 2011 | Frigidaire ATF6000ES Front Load Washer
My bosch classixx 1200 wont spin when on function but will spin by hand i have cleaned the pipes and checked the belt everything seems ok
John C
Apr 25, 2011 | Bosch Washing Machines
Dryer not spinning
hi, if its not spinning try the motor brushes, will be well worn if 5 yrs old or over. not too hard to replace or expensive if carbons only..please leave feedback.
Apr 07, 2010 | Dryers
I replaced the brushes but machine still does
it may be the belt is loose, can you hear the the drum trying to turn? if so its the motor, take the belt off the motor and see if you can spin the rotor it should spin easily
Feb 17, 2010 | Bosch WFK 2401
I have as Bosch WFK 2200 washing machine, I can't get it to spin... Can you help please!?
Hi. If the machine is over 6 or seven years old it is possible that the wash motor brushes are worn out. Give me more info. FD number and number of washes per week.
0417362396 Melbourne metro area
Regards Sam
Dec 22, 2008 | Audiovox Bosch 718 World Cellular Phone
Washer will not spin
Carbon brushes in motor have worn down clean armture and replace brushes.
Nov 26, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing Machines Logo
300 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
