Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
My Sub-Zero 650 bottom freezer ice maker works fine until the refill cup ices up. Once it ices up; the water overflow into the freezer. This problem just started. I pulled the ice maker out and cleaned it up, but after a day the refill cup ice up again. I'm thinking something downstream from the refill tube might be clogged up just enough to let water trickel out but not fast enough to keep it from freezing inside the refill cup. What do you think? Does anyone else have any other solutions for this problem? Thanks.
    Sergeant:
    Champion:
  • 351 Answers
Hi you are right the water valve is letting a little water get by. need to re place water valve jim
Posted on Oct 16, 2010
What to do after new water filter installed ice stopped being made?
Need to change water head (the part that the filter fits in).
Aug 29, 2014 | Sub-Zero 650 / O Bottom Freezer...
My Sub-Zero 561 ice maker works fine however when it dumps ice into the tray and fills back up with water, the water pours out on the right side and into the ice tray. any suggestions
I had the same thing - turns out the wife tried to put a wine bottle in to the ice tray to chill it - in turn it had pushed the water pipe back a little too far and so was causing water to spill out - see if you can pull the pipe forward a little - you will need to remove the ice cube bin - and get in to a funny angle to get to it -but its do-able.
good luck
Aug 28, 2010 | Sub-Zero 650 / O Bottom Freezer...
Ice maker not working. I have already replaced the water valve. What's next?
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
99086908
Apr 10, 2010 | Sub-Zero 650 / O Bottom Freezer...
The ice-cube maker on our Sub-Zero 650 has stopped making ice.
try replace the cheapest part first.( vater valve). you only need 2 components to make ice. water valve and ice maker.is simple and easy water valve located in the bottom part of the unit. remove the kick plate. left side. and color blue. ice maker inside the freezer. (DISCONECT POWER BEFORE SERVICE. ALSO TURN WATER SUPPLY OFF.) try main box , garage. and water meter outside your house. good luck
Apr 02, 2010 | Sub-Zero 650 / O Bottom Freezer...
My model 650 subzero ice maker won't make ice after cleaning out freezer drawer
make sure your ice tray in in the righ position. really important. the tray have to press the ice maker switch. or bad ice maker or bad water valve. also make sure to press the ice maker key. in the display. ONLY IN NEW MODELS
Mar 26, 2010 | Sub-Zero 650 / O Bottom Freezer...
Ice maker made too much ice, then none at all...
buy the water valve and the ice maker. replace. water valve locate in the bottom part of the unit. remove kickplate. (left side blue color). ice maker little trick to replaced. (special the 2 screws in the upper part.) call 1800 222 7820. subzero. for your closest store
Sep 19, 2009 | Sub-Zero Bottom Freezer Refrigerator
Ice cube tray overflowing-not shuting off automatically
Yes that is a plastic extension for the icemaker shut off. When replaced the new one should be secured with two small zip ties. You can use the ice on/off button to shut the icemaker off manually in the mean time. When ice is displayed in the panel it is on and when it is off so is the icemaker.
Jul 20, 2009 | Sub-Zero 650 / O Bottom Freezer...
Ice maker won't stop dripping
If your i/m is dripping you most likely have a crack in the ice mold, you should replace the ice maker.
Jan 01, 2009 | Sub-Zero 650 / O Bottom Freezer...
Ice maker not making ice - repair costs?
switch the fridge off and try warming the ice maker workings up with a hair dryer.
Jul 11, 2017 | Sub-Zero 650 / O Bottom Freezer...
Freezer Not making ice
are u getting water to the icemaker? If Not check water valve for ice maker in back of refrig.
Sep 11, 2007 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
292 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
