Question about Zodiac BARRACUDA G3 IN-GRND CLEANER
New g3 i straighten out the hoses, connect up barracuda,the hoses twist all back up,and it stays in one place
Try disconnecting all the hoses and laying them out in the sun for a few hours. The heat should loosen their shape. Then make sure to not reconnect in the same order. The hoses develop a "memory" if bent in the same position over and over again. If all else fails buy new hoses, although if it's new that shouldn't be the problem.
Posted on Dec 15, 2010
How to adjust flow keeper
that is usually an indication that there is suction loss or the diaphragm is again damaged. good water chemistry will lengthen the life of this part.
Aug 07, 2014 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Barracuda head keeps coming unscrewed from hose
Try wrapping white plumbers tape around the threads 3 or 4 times and then screw back together. That worked wonders for me when i had that problem.
Apr 05, 2013 | Zodiac BARRACUDA G3 IN-GRND CLEANER
I just installed my G3. It pulsates fine and actually goes backwards instead of forward. Is this correct. Also, it seems to keep on the same path and cleaning only the path it has already cleaned going...
It depends on what you call backwards. These do move in the direction of the hose, not opposite the hose. Try adjusting the hose weights per the installation manual and it should work fine for you.
Aug 27, 2011 | Zodiac BARRACUDA G3 IN-GRND CLEANER
New pool cleaner , pool hose just keeps twisting up have laid in sun, but as soon as connected back up it twists
Is the pool cleaners hose actually twisting in the pool or before you put it in? If it is twisting outside of the pool, it might still straighten out when you put it in the water. It it is twisting in the water, you might need to add some additional hose lengths to help it operate smoothly.
Feb 26, 2011 | Hayward Navigator Pool Cleaner
Water circulation is OK. barracuda g3 does not pulsate, hoses are clear
If the cleaner is not pulsating, then either you don't have enough suction or the diaphragm is bad or clogged. Very common to have a **** or tear next to or just below the plastic retaining ring that holds the diaphragm on the inner cassette tube. Also check and make sure there are no holes or breaks on the hoses. Your cleaner should have come with a suction gauge that you put on the end of the hose in place of the cleaner. It's a clear tube with a spring and plastic piece inside that indicates high, low, or normal. Use this to check your suction. If you don't have one see if you can get one at the local pool supply house, they may even have one you can borrow. Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave a good thumb rating if you found this helpful. Thanks, and good Luck!
Sep 30, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
I love the product and it's been amazing ever since I purchased it less than a year ago but my barracuda g3 ends up in the exact spot over and over into the stair which it gets trapped.
Here's a couple of things you can try.#1 First, change the direction of the jets in the pool. #2 Take the hoses out, lay them out flat and let them straighten out in the sun for a couple of hours. When you replace them, reverse the order they were in. #3 Try changing the amount of suction a little either way.(more or less). #4 Try adding one hose length. You can also try removing one.
Aug 14, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
My Barracuda inground cleaner keeps the same cleaning path.
mine does this too. I was told that the cleaner learns a path and sticks to it. You have to switch the sections of the hose around or just twist them to a different position so it will take another path. Unfortunately, you have to do this quite often to avoid it sticking to the same path around the pool.
Mar 22, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
G3 is not moving, but has suction? Please advise.
I had the same problem. come to find out there was somehting stuck in the diaphram. (a piece of mulch). Once I removed it, everything worked fine. Take your Barracuda apart and check the diaphram for blockage.
Mar 21, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Zodiac BARRACUDA G3 IN-GRND CLEANER Logo
260 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
