Printer driver nec superwriter superscript 610plus laser
Any advice as to drivers for above nec printer to operate on xp or vista.
Shame to throw away - still as new hardly used ....
Thankyou
Eric
  • Anonymous Jun 03, 2008
    lost the disk but do not want to change printer what can i do
  • 99 Answers
Sorry to have to say this, but it appears that XP and Vista drivers aren't made for this model...sorry...
Posted on Jun 03, 2008
I recently acquired an NEC SuperScript 1260 laser printer but I need an adapter cable so it will work off my computer (Vista). I need a pin connector for the printer on one end and USB for computer. The...
The NEC SuperScript 1260 has a parallel printer port. So you would need a parallel to usb adapter. These aren't very expensive; depending on the brand and length you'll pay between $8 and $15. See https://www.amazon.com/TRENDnet-Parallel-Converter-10-6-10-9-TU-P1284/dp/B0007T27HS or https://www.amazon.com/Sabrent-Parallel-Printer-Adapter-CB-CN36/dp/B00IDU0T1Y Alternatively, if you have a desktop, you can find a PCI or PCI-e add-on card with a parallel port, depending on the slots available in the system. These will be closer to $20 to $30. Then you need a standard parallel printer cable. Many computer parts sites, including Amazon.com, will have both.
A bigger problem may be the printer drivers. NEC did not update the drivers after Windows XP. (Some XP drivers will work under Vista.) NEC doesn't supply the drivers on their site: https://support.necam.com/Printers/Drivers/ . They refer you to the original driver CD that came with the printer. A few sites may have these drivers online. However, I haven't seen a link to a known trust-worthy site with the XP driver.
I hope this helps. Please add a comment if you need more information.
Sep 15, 2017 | NEC SuperScript 1260 Laser Printer
DRIVER FOR PRINTER NEC870 x WIN7 x64
You could try use the Windows XP SuperScript 870 driver or you could install the HP LaserJet III printer driver. It should work with your printer, but may have limited functionality.
Feb 08, 2010 | NEC SuperScript 870 Laser Printer
Need printer drivers for NEC 1450N printer (yeah, I know, it's old, but it still works great) that work with Windows 7. Do they exist?
Many printer manufacturers are not making drivers for the older printers on Vista or 7. If you really need it you can load windows XP on VMware virtual machine and switch to XP to use your printer.
Feb 01, 2010 | NEC SuperScript 1450N Laser Printer
Nec superscript 860 printer driver
Hi Richard,
As you might all ready know, this printer is not supported by Vista,  pasible solution: - if you have another "old" computer, you could install your printer on that, and share it, that way you can printe via the other computer. in case you want drivers for all other software, here is the link.
regards /Teis
Jan 07, 2009 | NEC SuperScript 860 Laser Printer
No Vista Printer Driver for this Printer.
http://h10010.www1.hp.com/wwpc/ca/en/sm/WF25a/12144670-12144918-12144920-12144920-12735588-12735640.html
Fallow this link and you will find a printer that's very interesting in price and options to....
The only way to keep your printer alive is to change your OS by and older(win 95,98 or 2000) one...Sorry!!
Mar 27, 2008 | NEC SuperScript 1400 Laser Printer
Vista problems with NEC SuperScript 870
If you load the printer drivers from a Windows XP install disk (in the i386 directory), that worked for me.
Feb 22, 2008 | NEC SuperScript 870 Laser Printer
NEC SuperScript 1800 Laser driver to use for Windows Vista
Use the HP LaserJet 4 Driver. That's what I did and the printer works fine.
Nov 15, 2007 | NEC SuperScript 1800 Laser Printer
Driver for Vista, Windows 2007
This has been a problem since XP. However I found that if you install HP Laserjet IIp drivers the printer WILL work in Vista! You won't have all functions but at least it is very suable. Hope this helps!
Oct 19, 2007 | NEC SuperScript 1260 Laser Printer
NEC SuperScript 870 Printer
First open your Control Panel and click Printers. Now click “Add a Printer”. Specify if you printer is Local (plugged in to your computer) or on the Network (plugged in to a different computer). We are assuming you have a Local printer.
Next specify the port. Usually you can just take the default here. Now you will be presented with a list of available printer drivers with manufacturers on the left and printer models on the right.
Under manufacturers choose “HP”. Then on the right scroll down and find the “HP LaserJet IIP”. It will probably show up just after the “Laserjet IIIP”. Click next and follow the instructions to complet installing your printer.
Aug 13, 2007 | NEC SuperScript 870 Laser Printer
125 people viewed this question
jasbo
jasbo
