Question about Logitech Webcam
How to get this thing to record video with sound?
  • Logitech Master
  • 32,281 Answers
If the Logitech WEBcam dows not have a built-in mic, then you need to plug a microphone into your computer.
Posted on Oct 16, 2010
  • Chris Hingee
    Chris Hingee Oct 16, 2010
    You have rated me NOT HELPFUL, it is a bit unjustified because I have to guess your problem.
    You need to give me more information if you want my help.
    Has this model Logitech WEBcam got a built-in mic?
    Have you install the Logitech WEBcam drivers?
    Have you tested the mic, can you record from the mic?
    When you run Logitech utility can you see a video image and can you record a video with sound?
I recorded a video without sound not realising that the 'voice' option had been turned off. Is there any way to recover the sound or anyone I can send the video to to have the sound recovered?
maybe a movie producer,if you dont record audio,where do you think the audio will come from??,that is why there are switches on things,so you can turn things on and off
Jul 13, 2015 | Samsung DigiMax SL102 ES55 Digital Camera
When I record a video, the camera does not record the sound
This is caused by one of two things.
The first thing is that you might have accidentally activated the mute function and as a result, it cannot record the sound of the environment since the mic has been de-activated.
The second and most likely thing is that your mic is faulty and can also not record the sound in your environment.
You can try to restore the default settings and see if there is any change as the mic settings may have been altered but if it doesn't then you have to send it to an expert technician to help you change the mic.
Hope this solution helped you? Please comment if you need more information and thank you for using Fixya.com
Jan 01, 2011 | Cameras
I Don't Hear A Thing On It When I Record.
The 8025 is designed primarily as a still camera, with some video capabilities grafted on. As such it captures images not sounds. You can add a soundtrack using video-editing software on a computer, but you cannot record one on this camera.
Sorry if that wasn't the answer you wanted to see, but there it is.
May 20, 2010 | Vivitar ViviCam 8025 Digital Camera
Cannot record on Toshiba DVD Recorder
Sounds silly, but are you sure you have a DVD in the slot? It probably won't let you record video on a CD. (From experience, that is an easy thing to do.) The second thing I would check is to make sure the connections are correct, and the plugs fully inserted. Things can work loose. If there is no signal coming in, it cannot record. Unplug it for 30 seconds or so, then start over.
Jan 03, 2018 | Televison & Video
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
Audio on Dell Webcam Central And voice record isn't working
I have a Dell 1545 with Dell web cam central & I've had this issue. The problem is that Dell web cam central installs it's own microphone settings onto your laptop called something like Dell web cam Live!. This isn't the built in microphone in my laptop & maybe not yours either. You have to change the settings for your computer system & Dell web cam central. Go to start> control panel> sound> recording .. on mine there is an option for Microphone "High Definition Audio Device" ... that is the built in mic. You want that for your default & apply it. Also .. as a side note .. I disabled the web cam central Live! microphone completely from this window. Then open Dell web cam central & go to the "Record Video's" option. In the middle of this is an orange button with a video camera icon. Next to this on the same button is a little arrow pointing down .. click that. Under microphone .. choose Microphone "High Definition Audio Device" just like the sound option in control panel. I've done this & it's completely fixed. I can record videos with sound & use my built in mic in voice/video chat.
Aug 15, 2009 | Dell Inspiron 1545 Notebook
No sound recording during video recording with olympus fe 170
To my knowledge, an Olympus FE-170 has no audio recording capability and records the video on 15FPS.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 30, 2008 | Olympus FE-170 Digital Camera
This thing recorded video without audio.
No, sorry. This camera has a small glitch where it occasionally records video without sound, especially if it has been on for a while. In order to fix this, you can simply turn the camera off and on when it is recording without sound.
Oct 27, 2008 | HP Photosmart R927 Digital Camera
Sound on my c613
These cameras DO have sound--they record sound, you just don't play it back. When you download the video, the sound will be there.
Apr 10, 2008 | Kodak EasyShare C613 Digital Camera
Logitech Webcam Logo
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
