Question about Samsung ML 4600 Laser Printer
ML4600 not printing with Window vitsta.
Recently I connected my ML4600 to my laptop which has windows vista. but its not working. Any IDEA, please?
    Guru:
  • 1,342 Answers
You can get your Vista driver and User Manual HERE
Posted on Jun 03, 2008
How to print from Window Vista to Canon BJC80 printer using USB to Parallel cable
Helen, is the printer correctly installed in laptop? Check if shows under Printers and devices. If not, install and show it as default. Make sure your usb connections are ok.
Mar 19, 2014 | Canon BJC 80 InkJet Printer
I cannot connect to the internet with my laptop Toshiba?
You need to get the IP address, domain and other info from you internet service provider to set up the connection again.
Aug 21, 2009 | Toshiba Equium 100 PC Desktop
I could not print with hp laserjet p2015 usinh window vista
hi there,
Is the drivers of P2015 correctly installed on vista? If yes then you have to check your printer USB cable. Try to change it and see the result.
Good luck
Jun 24, 2009 | HP LaserJet P2015 Printer
My wGPS606 wont print on my Windows Vista laptop!
I just found a way to enable the HP P1006 with a different print server (Liveprint on Orange Livebox router). Perhaps this might work with the WGPS606 wireless print server?
I set up the P1006 via the print server as instructed (I'm using Vista 32 Home Premium) but no test page would print.
BUT!! (with thanks to another another forum):
I selected printers, then right-clicked on the wireless printer I'd just installed and selected 'properties'.
Under the 'Ports' tab I deselected 'Enable bidirectional support'.
Problem solved.
Hope this helps.
let me inform you that this printer is not compatible with any wireless print server. The drawback is that it is not possible to network such printers. A printer needs a steady flow of data, which is easily accomplished when it is connected directly to a PC, but cannot be guaranteed when the printer is connected via a LAN. Also, these technologies require intensive handshaking between the driver and the printer.
The host-based software uses the computer's resources to process print commands and rasterizing data, taking advantage of the computer's memory and processing power."
Sorry I can't be more upbeat - but its probably useful to know that someone at HP thinks the job's imposible - unless someone out there has a fix?
May 11, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
My WGPS606 wont print on my Windows Vista laptop, its prints with all normall xp windows laptops and desktops, but I recently bought a new laptop and it does not print, the print says error, can somebody...
there is a proceedure for manually adding the printer ports instead of using the wizard on the software disk. Look on the disk and go to the guide .pdf file, the instrucitons are there. i tried it and it worked fine.
Apr 01, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
Need help to connect my dell laptop to imagistics 2500 printer please
it is possible to set this multi-function fax/copy/printer for printing from your laptop. There is an available GDI driver from the manufacturer's website (http://www.oceusa.com) for Windows Vista 64 (exe file). Other than that it should install like any other printer.
Jul 01, 2008 | Computers & Internet
ML4600 only print 2 pages
It could be losing connection to the printer when there is too much information to print.
If the cable the information needs to travel through is too long or the distance to the printer is too far - information is "lost" due to the stability of the connection.  The longer the information needs to travel the more unreliable and unstable it becomes.
Have you tried from a different computer to print the document?
Nov 29, 2007 | Samsung ML 4600 Laser Printer
Windows operating system
you can make a dual book (multi OS) on your laptop so that you can just switch over to XP or vista and vice versa.
try this article on MS on how to install a multi OS. i haven't tested it in vista though...but i think it would work..please let me know.
also..you can use a Virtual PC and install XP there, its much more easier.
Oct 30, 2007 | HP Pavilion dv4000 Notebook
Samsung ML 4600 Laser Printer Logo
61 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
