Question about Kenmore 74882 Gas Dryer
I have a Kenmore Series 70 Model #11070722990 serial #MK1712987 gas dryer. it worked fine one day and not the next. it spins and spins but does not heat up. Can you help? I want to try to fix it first before calling someone.
SOURCE: Kenmore 70 Series
hello,
i have a kenmore series 70's gas dryer that will not heat up when it is turned on and i am now smelling gas when i do try to dry my clothing. it was working yesterday but now this is happening? please help.
thank you,
tina
Posted on Oct 06, 2008
Unplug and turn off the gas feed. The fuse is located in the back of the series 70 attached to the lint housing near the bottom. About 1-1/2 inches long. Easy to remove, only two contact wire attachments. Note which wire goes where. Under $10.00 at an appliance parts store. Start with this fix.
If still no heat take out the ignitor assembly, located in the front, lower left. It is attached to the base of the dryer by 3 screws, the gas feed and two electrical wires with removable metal attachments (note which attachment goes where). The entire assembly will come out and the ingitor is attached to the front end. I took mine to the appliance parts store and it tested OK so it was the fuse. The owner helped me locate the fuse and suggested I try this first. The ignitor coil is about $25.00.
Both of these were easy enough for a novice (like me) to do. It saved a lot of money.
While the dryer was open I vacuumed out all the dust and lint and checked the integrity of the belt.
Good luck.
Posted on Oct 07, 2008
  • 1122 Answers
SOURCE: kenmore dryer series 70 won't turn on
most of the time it is the door switch that goes bad,also you can check the main fuse inside the dryer on the blower box,and always make sure your dryer vent and wall vent are clear to vent,let me know what you find-mike
Posted on Oct 29, 2008
  • 686 Answers
SOURCE: Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Posted on Apr 06, 2009
  • 1810 Answers
SOURCE: Dryer wont start.
can you hear the motor or does the unit humm or vibrate when it is turned on
if yes then have a look at the belt
if not it's time sor a service call
Posted on Aug 04, 2009
My Kenmore Series 70 Dryer will not start at all. No sensation of the start button doing anything when I push it. Thermal fuse continuity is good (0 ohms). Light goes off inside the dryer when I depress...
most likely its the push button that is bad. you can buy one from any appliance dealer that services a kenmore dryer. the part is a reasonable price. you also have to give them the model number and serial number. have a good day!!
Oct 15, 2010 | Kenmore Dryers
Need help with gas dryer Kenmore 90 series serial
Check the lint caught in the exhaust vents. If it is clear replace the spark ignitor if no click is hear upon starting up
May 14, 2010 | Kenmore 73952 Gas Dryer
Kenmore 70 series gas dryer (Whirlpool model) will not ignite!!!!
>> Do you know where the flame sensor is located? I figure the ignitor is where the "glowing" occurs and the gas line feeds to. Thanks for your help!<<
The flame sensor is right next to the ignitor. Also see this link for what it looks like:
http://www.apwagner.com/index.php?main_page=index&cPath=7_96
Mar 18, 2010 | Kenmore 73952 Gas Dryer
I have a kenmore 70 series gas dryer. It won't
Check the thermal fuse and thermostats first, then the ignitor and the valve coils are the next possibilities.
Eric
Jan 24, 2010 | Kenmore 63942 Dryer
How do I open up my kenmore 70 series dryer, it stoped running and I want to check and see if it is dirty, as that has caused this before
LE7680XSN1 Model Serial M80824319 Whirlpool Heavy Duty Dryer. Runs fine but will not heat. What should I check to get the heat to work
Dec 15, 2009 | Kenmore Dryers
My gas dryer stopped heating it is a Kenmore 70 series. I am getting good gas flow but dryer will not heat.
Try this link I hope it helps, I know it helped me a ton!! ps don't forget to rank my help. Thank you and have a nice day!
http://fixitnow.com/wp/2004/11/13/mailbag-how-to-troubleshoot-a-gas-dryer-with-no-heat/
May 07, 2009 | Whirlpool LGR3624JQ Gas Dryer
Kenmore 70 Series
The most likely cause is a bad ignitor part number 279311. It has to glow to open the valve and ignite the gas. You should hear a loud click when you first start the dryer. That tells us there is voltage to the gas valve.
Apr 07, 2009 | Dryers
Kenmore 70 Series
You probably have an open thermal fuse, the dryer will run in some cases and not heat, Just moving air across you clothes will dry them however it takes forever.
If you are electrical or mechanical replace the thermal fuse yourself if not call someone you trust, you can purchase thermal fuses on line from Sears.com just do a parts search for you specific dryer.
Jun 04, 2008 | Dryers
Kenmore 70 Series
hello,
thank you,
tina
Jan 05, 2008 | Kenmore 74602 Gas Dryer
Kenmore 74882 Gas Dryer Logo
106 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
