Question about Onkyo TX-DS474 Receiver
Have power but no sound
We shut it off earlier & then when we truned it back on there is no sound at all. We checked all the ideas from the manual....any ideas?
  • 4,234 Answers
I would guess that the unit is in "protect" mode. listen carefully when you turn on the receiver. You should hear a click followed shortly thereafter by another. If you do not hear the second one, the unit is in protect. This means that a problme has been detected in the output amplifier section and hte receiver will disable it to prevent further damage. The typical problem is shorted output transistors. Expect a parts cost of $12-$25. Add in the local labor rate for the total repair cost.
Dan
Posted on Jun 03, 2008
  • 1,512 Answers
Hi doodles mom
thats an odd one,if it worked earlier, how come not now. I would suggest trying a hard reset of the unit by powering it down completely by unplugging it from the wall for 30 mins. Then fire it up again and see if it clears the fault. This is like the first thing to do when this sort of problem occurs. If it is the same, please get back to me here.
I am more than happy to answer any other questions you may have about it, just give me a hoy :) If you are still unsure, or have problems, then before you give a rating for this advice, please get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
I have a punch 800.2 hooked up to two 12 in Kenwoods in a ported box and it will hit for about 20 minutes then turn off why I had another amp just like it before hooked up to 4 free air never did that
??if your question is why will amp over heat and shut off ,when using a ported speaker enclosure VS. a non ported enclosure . then the answer is Force feed back , the entire idea behind a ported box vs not , is that port or tunnel is cut to length of time it takes for a narrow set of sounds to travel thru tunnel and out to front , this adds a known delay , hence it adds to "Punch" speaker can put out , and since the times of neuton (really before) we have known that in physics you all ways have to give something to get something , so it takes more power to force that sound thru the tunnel vs just out the front . more power means more current , more current is more heat , hence amp shuts off earlier than if using a compression type box
May 13, 2016 | Car Audio & Video
2000 lincoln ls want start just keep truning over reset button end and you can hear relayes clicking
Sounds`like`your`battery`is`dead.Your`local`parts`place`will`do`a`diagnostic`check`if`you`take`it`to`them.
Mar 02, 2015 | 2000 Lincoln LS
Steering wheel sound when truning
Check for worn bearings in the power steering pump where the drive belt pulley attaches to the pump shaft.
Jan 14, 2014 | 1996 Ford Ranger SuperCab
Change fuel pump and car wont start
Did you check the fuses or try swapping relays under the hood. Sounds like more issues. Is the fuel filter plugged? Do you smell gas when trying to start? Check your fuses and relays to ensure fuel pump is working. You may have a shut off for the fuel pump in the trunk on the drivers side.
Jan 27, 2013 | 1994 Toyota Camry
I have a HP dv6500 laptop and when i turm it on it shuts off and turns back on every 3 seconds.Just before that happend my DVD/CD rom wouldnt read a week earlier. I can keep it on when I push my B button...
Is the fan dirty/dusty is there sufficent air flow? Try a Cold-Restart, unplug AC cord, remove battery, hold down on/off button for 10 seconda, replace battery, plug into AC outlet, start normally. if that fails Try a system restore/recovery. That's a start. It sounds like a hardware issue, the shut off issue. The DVD/CD sounds like a driver issue. Thouroghly clean the fans, get more air flow, use a laptop cooler if necessary, Restore/recoery if necessary.
Nov 05, 2012 | Computers & Internet
Sound not working, Was working earlier today and after shutting off the tv, when we turned it back on, sound wasen't working
Sound issues and answersa short list:
sound on set or a box muted or turned down?
speakers inside the set (see menu) switchedon or off?
internal/external switch somewhere in or on back of set?
Clearly it could be a audio problem (a model number?) but explore all here thatyou have not already done--make sure theremote set to TV and look for a button on it marked MTS and if there cycle it.
You can also determine if same trouble when you play a DVD.
Apr 03, 2012 | Vizio 42 in. LCD TV
Power goes off when truned on
Hello
The power supply starts ON and suts down immedieatly, means there is some short circuit with its main board. In most cases Horizontal output section will have the shorted component/s. You must ahve knoledge in electronics, and experience in troubleshooting the horizontal output section of your set.
Feb 15, 2012 | Mitsubishi WS-55819 55" Rear Projection...
Our oven has no power since truning self cleaning on.
We have the same problem, we placed our oven in self cleaning mode and now it will not open up... All power has since has shut off. Please assist us with turning the power back on, thanks....
Jan 04, 2010 | KitchenAid Architect Series II 30"...
Onkyo TX-DS474 Receiver Logo
208 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
