Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Our Frigidaire Ice Maker leaks water between the side of the ice maker and the wall of the freezer. Recently it started to leak in the ice bin too causing the ice to jam on the bottom. Anybody has an idea on how to fix it?
    President:
  • 1,891 Answers
Replace water valve as it is not shutting off completly .. mm
Posted on Oct 16, 2010
Ice maker drips water into freezer.Makes ice but doesn't shut off when full.
How to Repair a Refrigerator Ice Maker ' HomeTips
www.hometips.com/repair-fix/freezer-ice-maker.html
Aug 6, 2015 - If the ice maker doesn't make ice but you can see the arm swing intomotion and you hear a ... 4Check the water line that enters the back of the freezer for a blockage. Find the water shut-off valve behind the refrigerator or under the sink, turn it off, ... If your ice maker keeps making ice, even when it is full:.
Refrigerator's Ice Maker Leaking Water ' ThriftyFun
www.thriftyfun.com/tf37813274.tip.html
If your refrigerator ice maker is leaking water, the first step is to locate the source. ... Its not the ice maker - in the floor of the freezer is a small drain that lets the ... I shutthe water supply off but water dispenser still leaks even though no ... My side by side refrigerator leaks water into the ice bin when filling the ice tray with water .
Dec 26, 2015 | Refrigerators
I have a KitchenAid side by side fridge, type 25SSA, water is leaking from bottom of ice maker down front of freezer and into ice bin, how do I stop leak?
Is the refrigerator and the ice maker level? Does it appear that the ice maker is over filling or slowly overflowing due to a leak in the Click here=> W10408179 Refrigerator Water Inlet Valve? Look in the rear of the ice maker where the water fill tube enters the ice maker do you see water freezing and running down to the ice bin from there? Let me know.
http://appliance911seabreeze.com/
Nov 14, 2015 | KitchenAid Refrigerators
Water leaking from Icemaker fill tube near the back wall
It probably is not the water valve. More likely it is the ice maker itself. Nothing else in the machine controls the flow of water to the ice maker except the ice maker itself. It is recommended that both the ice maker and the water valve needs to be replaced when trouble such as this.
Dec 12, 2012 | Refrigerators
Leaking water in side always
If the water leak is down the back or ctr its the drain line going to the underside of the fridge. If its down the side where the ice maker is its the ice make is not level if no ice maker your tray under the freezer may be leaking instead of draining.
Jul 20, 2010 | Frigidaire 20.6 cu. ft. Top Freezer...
We have a side by side refrigerator with ice maker that leaks water on to the floor.The water also runs into the freezer part and freezes under the bottom bin. It will not make ice but the ice maker...
Could be one of several things.
The cold water reservoir in the refrigerator could have a leak. Usually located on the back wall behind the drawers.
The ice maker may not be operating properly either, or the hose leading to it may be leaking.
Or the ice maker mold may be cracked.
Or the ice maker fill tube has gotten misaligned with the ice maker.
Let me know what you find, and I can give you more direction.
All assumes the ice maker is acting as you describe. There are situations where the drain tube under the freezer coil will clog, preventing water from properly draining from the defrost cycle.
Dec 16, 2009 | Coffee Makers & Espresso Machines
Ice maker water leaking
Is the fill tube in the cup? also is the ice maker the correct ice maker for the unit.
Mar 25, 2009 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire Ice Maker not working
sounds like you got a water valve problem. it will be found at the lower back side of fridge where the water hook up is at.
Mar 14, 2008 | Frigidaire FRS6R5EMB Side by Side...
Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Mar 03, 2008 | Frigidaire PLHS267ZA Side by Side...
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
336 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
