Question about Toshiba Office Equipment & Supplies
On Toshiba e-studio 4520C, can I set the default printing (not copying) for all users (logon windows domain) to Black (not Auto). I do not wish to disable color printing, only set default to black (for all users).
5 Suggested Answers
  • 103 Answers
SOURCE: Can I set default printing to black and white for color laser printer?
Yes. Any printer's default options can be set as desired. Open the printer's properties (Start/Control Panel/Printers/right click the printer and left click Properties), and change the setting as you wish, then click OK. Those settings should be used each time you use the print command, unless you change the settings for that particular print job.
Hope this helps, and please rate my advice, good OR bad.
Posted on Feb 05, 2008
  • 12 Answers
SOURCE: Reseting the default settings
set printer to black and white, press utility, user settings, save and select current settings then press set, should work
Posted on Sep 15, 2008
  • 643 Answers
SOURCE: I have a studio 4520c photo copier which i want to
Press User Function--> Admin--> Copy -->Change the auto 2-sided mode to "2->2".
Posted on Jan 20, 2010
  • 58 Answers
SOURCE: I would like to set the default copy to black
you can find it in the additional functions under the common settings
Posted on Feb 10, 2010
Tip
Applying the settings to the logon desktop
Next, you need to apply the Screensaver settings to the Logon Desktop / Welcome Screen (Technically, HKEY_USERS\.Default registry key), so that the Screensaver is invoked when no user is logged on. Copying all the Screensaver settings to the Logon Desktop (or Welcome Screen) manually is a tough task. Use Tweak UI instead.
Download and install TweakUI.
Launch TweakUI and click Logon, click Settings.
Select Screensaver from the list box and choose Copy Now
The Screensaver settings are applied to the Logon Desktop
Restart Windows for the changes to take effect
Allow few minutes at the Logon screen, to test if the Screensaver is working properly. The Screensaver should launch after the timeout. It will look as if the Company Logo moves around.
Additional Tip
The User interface / slider allows the minimum value for picture change interval to 6 seconds only. To reduce the change interval to less than 6 seconds, alter the registry value named ChangeInterval (Set decimal value 1000 for 1 Second, and so forth) in this key:
HKEY_USERS \ .DEFAULT \ Control Panel \ Screen Saver.Slideshow
For Current user profile, make the change here:
HKEY_CURRENT_USER \ Control Panel \ Screen Saver.Slideshow
With no logon wallpaper set, Windows displays a pre-defined color for the logon desktop. ( If you have enabled Welcome Screen, press CTRL+ALT+DEL twice to see the logon screen background color. ) To change the logon background color to that of your choice, you need to alter the registry:
Click Start, Run and type REGEDIT and press Enter
Navigate to the following key:
HKEY_USERS\.DEFAULT\Control Panel\Colors
Backup the registry key by exporting to a REG file
In the right pane, double-click Background
In the Edit String dialog box, type the Color code in R G B format and then click OK.
Example: Type 0 0 0 if you want to see a Black background. You can choose any combination from 0-255
Points to ponder
If the logon Wallpaper is set, the background Color may not be visible. So, you must reset the Wallpaper value to a blank string in this key: HKEY_USERS\.DEFAULT\Control Panel\Desktop
If the Background value is set under the following Winlogon registry key, the above setting is ignored. In other words, the Winlogon\Background value takes precedence over the .DEFAULT..\Background value.
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Winlogon
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
How do i get rid of blank lines in copies on my Toshiba studio 3530c
Make sure the toner waste container is empty and also the charger and glass cleaner brushes are pulled out and put back to ensure these are clean. See maintenance actions in this guide. http://www.eid.toshiba.com.au/customers/c_es4520c/manuals/pdf/Mash/OM/Quick%20Start%20Guide.pdf
Sep 12, 2014 | Toshiba E Studio 3520c 3530c 4520c Copier...
Error c970
1. Check and clean the main charger, replace if required.
2. Check and clean the transfer/sep. unit, replace if required.
3. Before you replace the HVT board, check HVT connector bracket (the black color plastic piece mounted on the machine frame where the main charger connects). If this part is damaged or cracked, the high voltage will arc through this, which can cause C970. (found in several machines).
Apr 22, 2014 | Toshiba E Studio 3520c 3530c 4520c Copier...
Faint lines
Try replacing the roller, or maybe you moved it and is not in place- in the exact position.
Jun 29, 2012 | Toshiba E Studio 3520c 3530c 4520c Copier...
Logon issue in a domain trust - Win 2003
Are you logging in through terminal services? If so you need to give the user "allow logon through terminal services" permission in group policy.
Otherwise you need to give the user "allow logon locally" permission on the domain controller.
Mar 20, 2009 | Microsoft Windows Server Standard 2003 for...
E-Studio 450 network issue
toshiba e-studio 450 black photocopy
I have machines, but I can not use the printer properties. If there is information about how appreciate if you provide information.
Jan 12, 2009 | Toshiba E-STUDIO 450 Copier
Change default tray for E-studio 520
go to Control panel, select printers and faxes (windows XP),then select es520,right click properties, select Tab advanced,then you should click on printing defaults. then will open toshiba driver defaults,go to paper handling tab. THERE IS option called "destination" and there you can chose exit tray (inner,tray1,tray2...etc). After selection you must click apply and then ok. and that it. every time after that documents will be printed out to selected tray.
Jul 25, 2008 | Toshiba COPIERS E-STUDIO 520 Copier
1,009 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
