Question about Acer Aspire 5100 Notebook
My computer's "driver" won't start therefore my computer won't boot.
I push the power button and the computer turns on, however the screen that it
usually goes to after the acer screen doesn't appear. Another black screen with 5
lines shows up and repeats itself. We took out the battery and unplugged the laptop
from the AC adapter but have no success. What do you suggest?
  • 1 more comment
  • lexikate Jun 03, 2008
    there is no load optimal setting but there is a load setup default. Should I try this one
    Many thanks!
    While Booting the Laptop, Press the F2 Key (some use DELETE key) ..
    THis will take you to your Bios Setup.. Look there for .. LOAD OPTIMAL
    SETTINGS.. Choose Save & Reboot..Also In there If You See.. ENABLE
    FAST BOOT, or something Similar.. Set it to that to Bypass the screen
    youre seeing.. Hope that helps your Problem.. Cheers
    THANKS FOR YOUR RESPONSE. WE CANNOT FIND ANY WORDING TO SUGGEST LOAD OPTIMAL SETTINGS...CAN YOU BE SPECIFIC AS TO WHERE IN THE BIOS THIS MAY BE.
    WE SO APPRECIATE YOUR TIME AND TIMELINESS IN THIS FRUSTRATING SITUATION
    The type of bios setup page is called pheonixbios setup...are there different steps we should follow because of this?
  • 458 Answers
While Booting the Laptop, Press the F2 Key (some use DELETE key) .. THis will take you to your Bios Setup.. Look there for .. LOAD OPTIMAL SETTINGS.. Choose Save & Reboot..Also In there If You See.. ENABLE FAST BOOT, or something Similar.. Set it to that to Bypass the screen youre seeing.. Hope that helps your Problem.. Cheers
http://www.wnycomputerpro.com
Posted on Jun 03, 2008
  • Garry Romaneo
    Garry Romaneo Jun 04, 2008
    Yes... try load default settings.... if that has no effect.... try holding F8 upon bootup to boot in Safe Mode... hopefully it will boot and you can then view the problem in the event viewer from your admin controls
My Asus X553M laptop is not booting up. Any ideas how to fix this problem?
Temitope, Hard reset. Open computer, remove battery,hold power button down (((1 minute))), reinsert battery, reassemble laptop, push/hold power button a couple seconds.
2nd fix, try to boot laptop without hdd.(hard drive). Remove the hdd, then turn on the laptop.. then it can get into the bios.. reset the bios to the default setting, turn off the laptop, and then turn it on again with hdd reinstalled. This seems to be what works in the forums with this issue found in Asus laptops. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Asus Laptop unable to boot black screen no bios
How to Fix Laptop that Won Turn On Asus X551M
Laptop Won Turn on Fix How to Hard Reset Laptop
Asus laptop not booting
Aug 21, 2016 | ASUS Computers & Internet
When i turn on my Dell Inspiron 2400 Desktop Computer why won`t it start.
Is the computer plugged in to a known good power source with a known good power cord? Also, make sure the power is fully seated on both ends. When you press the power button are you getting any indicator lights? The power button itself has an LED that will be either solid green, blinking green, solid amber, blinking amber, or off. Do you hear any beeps?
May 19, 2014 | Dell Inspiron 530s Desktop Computer...
Acer am1100 won't start up
Discribe what happens when push the on/off button and you try to boot, fan spin? LED's blink? HDD/DVD light blink? Sound? Any thing on screen at boot? What blue light?
Feb 26, 2013 | Acer Aspire AM1100-B1410A Refurbished AMD...
Dell inspiron 1300 won't boot
If you want to keep your important data, use some softwares can solve thewindows won't startproblem most quickly, and no data will lose. Besides, it is very easy, even the people who lack of computer knowledge can deal with windows won't boot issue.
Sep 21, 2012 | Dell Computers & Internet
Gateway MP8708 Won't boot past BIOS and won't boot into CD/USB/Safe Mode on XP - Blank screen with keyboard dead - Num locks on and wireless light
Windows won't start up? Well, try this Download Tenorshare Data Recovery from its offical site and install it. Burn it into CD/DVD, or USB flash, put into the computer you need to repair, Bios setting. It can make sure your important data will not lose. Best of luck
Related: windows won't start
Aug 25, 2012 | Gateway MP8708 Notebook
Device could not start
what device? is *********** board won't start? Or a hardware doesn't start like ram or your printer
If the problem is your motherboard check all your hardwares and connectors like this:
  1. If the motherboard won't start if you click the power button check the LED(the small light bulb on your motherboard) if its glowing. If not, check the connector of your power supply or check the power supply if its working by looking its fan if revolving.
  2. If you push the button and there's a sign of power but didn't start up that will appear on your screen check the connection of your monitor screen to your desktop computer. If it's connected, remove your RAM from the motherboard and insert it to another memory slot to check if it's broken.
  3. Last, if you push the power button and here 1 short beep but the boot screen didn't appeared from your screen check your graphic card. Remove the graphic card and re-insert it again to its graphic card slot and plug in your monitor connector to it. If it still remain that way, buy a new graphic card.
Aug 01, 2011 | Computers & Internet
ACER ASPIRE 5532 LOCKED UP, WON'T GO PAST THE "ACER empowering people" logo at startup. press f2 and it says "please wait" then won't do anything else. Pressing f12 to change start-up...
1. Turn the Laptop off 2. Remove the battery 3. Disconnect the AC adapter from the laptop 4. Disconnect any peripheral devices from the laptop such as printer usb cables, PCMCIA cards etc. 5. Push and hold the power button for 60 seconds then let go 6. Connect the AC adapter to your laptop 7. Push power button to turn on the laptop 8. If this resolves the issue shutdown the laptop connect the battery and turn laptop back on
If issue is not resolved restart the computer and begin tapping the F8 key repeatedly until you see a screen that gives you options to enter different modes. Highlight "Safemode" and press enter. If the computer boots completely into safemode you likely have a driver that has corrupted or a hardware device that has failed. Likely driver failures are video card drivers. Got to Device Manager and uninstall the video card driver and restart the system. You can do this with other drivers as well.
Mar 05, 2011 | Acer Computers & Internet
When you push the power button, the button turns green but the computer doesnt start up. The lights are on but there is nobody home, there is no sound indicating that the computer is starting up.
Remove the battery, and unplug the A/C adapter and hold down the power button, for 40 seconds.Soon your laptop will reset,and run well.Now you will install all the accessories and start.
Hope this helps you.
Feb 18, 2011 | Acer Aspire 9300 Notebook
Dell Inspiron Desktop PC won't start up
Hit FN at boot then let me know what it does
Jan 14, 2010 | Dell Inspiron 530 Desktop Computer
My MX6453 won't turn on
You may have turned off the LCD screen. After you turn the computer on, hit Fn+F4 keys and then wait a moment. Then try it again. The F4 key cycles the video output through three settings: from LCD only, to external monitor only, to LCD + external video. You could also try connecting the video output on the back of the computer to a different monitor to see if it's a screen problem on the laptop of a broken video card.
The F4 key has the blue icons for a little TV screens. The Fn key is in the lower left corner.
About two weeks ago I started getting a "Catalyst Control Center" error about the video driver for my MX6453, so I assume there was some sort of update that was pushed through Microsoft or from ATI that changed display settings or drivers. Your computer may have had an extreme reaction to the software update if you accepted it. I did not accept the update and my computer works fine.
You can also try to boot in safe mode which should prevent the advanced drivers from installing. Basically you hit F8 as it's powering up. See here for more info: http://www.pchell.com/support/safemode.shtml
Mar 19, 2009 | Gateway MX6453 Notebook
Acer Aspire 5100 Notebook Logo
89 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
