Question about ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
Where can I find service manuals for ESA plasma TV. PDP4294LV
  • 103 Answers
SOURCE: flashing power button
Depending on the number of flashes,it could be a power supply or y-sus board.Both parts are silly money.The flashing light indicates a fatal startup error.These units make a great boat anchor for a 16ft boat.
Posted on Mar 03, 2008
  • 23 Answers
SOURCE: ESA plasma TV remote control code.
contact the manufaturer for the code :)
Posted on May 02, 2009
Sparky2012
  • 102 Answers
SOURCE: hi . i recently purchased a ESA 42in Plasma Model:
I would check on ebay until find one, no one on sale right now
Posted on Dec 06, 2009
  • 148 Answers
SOURCE: I have a ESA 42
The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol! If this helped (or not ) then please rate, thank you!312136d.jpg
Posted on Feb 04, 2010
djchillsnyc
  • 152 Answers
SOURCE: Good picture, no sound
hello, if you have a good picture then your set is serviceble make sure you check all your options and audio set up settings before you go futher, with this symptom your set displaying fine and sound not coming trough it could be a fualty sound board module this board is identified by aquiring a service manual and then using the schematic drawings location the board that controls sound, i would then find this board online at auction or parts site and have it exchanged. hope this helps
Posted on Jun 04, 2010
Jun 04, 2010 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
My 42 inch plazma turns on but ther is no picture
my ESA 42" plasma tv turns on no picture and no sound.
Jan 30, 2010 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
My fan is not working picture fades out when over esa plasma tv
need to bring to your tv service center before it blows out and becames more expensive to fix only a tv tech will be able to fix it,,
Dec 16, 2009 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
Need to find parts for my 42 inch plasma tv. #pdp4294lv1 model year:2004
The pdp4294lv1 is a re-branded Samsung monitor, here parts available online: PDP4294LV1.
To find all parts you need to look for part number on service manual, and then purchase same parts from different manufacturers. Alternatively call the seller to get parts.
Here the service manual.
SM-PDP4294LV1X
Mar 11, 2009 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
ESA plasma TV model pdp 4294lv1 does not work
my esa plasma tv model pdp 4294lv1 has sound and i can switch the tv channels, but the color is blurrier
Jul 22, 2008 | NEC - 42" Commercial Plasma Screen ****(no...
Help
The Power Supply Board is listed below. Please note, there are 2 models with the same beginning number (PDP4294). Verify your model number before selecting the Power Supply Board as each board is different depending on the model number.
For PDP4294LV use:
Akai PDP4294LV Power Supply Board Replacement
For PDP4294LV1 use:
Akai PDP4294LV1 Power Supply Board Replacement
Apr 01, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Flashing power button
Mar 03, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Esa plasma tv
I knead the wire for the spikers I losted and is imposibe to get sound on my TV plasma esa 42"
Aug 29, 2007 | NEC - 42" Commercial Plasma Screen ****(no...
ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV Logo
71 people viewed this question
Top ESA Televison & Video Experts
Demonic-2011
Demonic-2011
Are you an ESA Televison and Video Expert? Answer questions, earn points and help others
