Question about Roper RAS8445KQ Top Load Washer
Roper washing machine
Washer will not pass wash cycle...Will not Drain
  • 1 more comment
  • Anonymous Jun 03, 2008
    I am having the exact same problem, the washer will fill with water but will not drain. I need help
  • Anonymous Jun 19, 2008
    My Roper will not drain either. Agitation during rinse, stops to transition into spin/drain, and I can hear (for about a second) the water starts up the drain hose but then it stops there.
  • yakbuilder Feb 16, 2009
    washer was spinning slowly when draining prior to this.Washer will not empty water or spin,makes noise like motor running but not doing anything.
  • 240 Answers
Does it spin? drain pump is directly mounted on motor, works in spin. may need new pump. Whirlpool standard pump.
Posted on Jun 03, 2008
Roper top loader problem with a RTW43408q0. Washer wouldn't spin at first. I ran that cycle again. It filled with water and didn't agitate or drain the water at all.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 21, 2011 | Roper Washing Machines
My Roper washing machine will not drain the water after the wash cycle.
heatman101
Apr 17, 2011 | Roper Washing Machines
Washer does not drain and spin
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 20, 2010 | Roper RAX4232KQ Top Load Washer
Washer will not spin after it goies thru wash cycle
check door switch.you can bypass the door switch.you do not nead the door switch.you can order the switch you nead to by pass it.
Nov 17, 2009 | Roper RAS8445KQ Top Load Washer
Will not drain
Check your drain pump, it might disconnected from wash motor, or drain hole clogged.
Aug 04, 2008 | Roper RAB2121KW Top Load Washer
Nightshade, in most cases, no spin, no drain is a lid switch problem. If you advance the timer to the spin position does it spin? If the machine is agitating you can rule out the coupler. If you are sure that it is not a lid switch problem, then you are probably looking at a bad timer....Catriver..post back.
Nov 08, 2006 | Roper RAS8445KQ Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
184 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
