Question about HP w1907 LCD Monitor
My monitor is saying ...input signal out of range change settings to 1440x900-60Hz...I can't see how to adjust the settings since the monitor isn't working
    Genius:
  • HP Expert
  • 1,325 Answers
Hot connect it to another PC/Notebook that is using 1024x768 as a display resolution. Turn the monitor off, pull the power plug, wait 10 seconds, plug it in again and turn it on.
Posted on Oct 16, 2010
  • 11,361 Answers
2 Suggested Answers
SOURCE: "Input signal out of range"
update ur driver
Posted on May 21, 2009
My monitor says "input signal out of range change settings to 1280x1024 - 60Hz
Change the settings on the PC by going to Control Panel and clicking on the display icon, then change the adaptor settings.
Jun 02, 2014 | Computers & Internet
What is the problem of HP w1972a LCD monitor ?
If you have problem with your pc graphic card boot in safe mode 640 x 400 and change the settings of graphic card to 1366x768 60 hz. Then boot normal
May 06, 2014 | HP w1907 LCD Monitor
The monitor is black with a error message :input signal out of range We are connected to a Mac Mini This problem seemed to happen after the monitor was accidently disconnected and then when it was...
Can you please get me the make and model of the monitor? Also did you check to see if the refresh rate of the monitor matches with that of the mac mini?
Nov 21, 2010 | Hannspree Computers & Internet
Input signal out of range......my problem...hp w1707
your video card setting may not be compatible with your monitor's capability. you may need to reduce the screen resolution. you need to boot up on safe mode to change this or use another monitor for a while and try to adjust the screen resolution.
Oct 07, 2010 | HP W1707 LCD Monitor
Inout signal out of range Answer Failed: retry
It shows out of range because the PC is sending out the video signal that is higher than the monitor can display, you need to set the PC video resolution to the native resolution: 1024 x 768 @60Hz. You can reboot the PC into save mode (hitting F8 key while booting up) then set the resolution to 640 x 480 (try 1024 x 768 if it allows you to do so), reboot and reset the resoltion to 1024 x 768 @60Hz.
Mar 06, 2010 | IBM ThinkVision L151 15" LCD Monitor
Did you mean "out of range". Try reloading video drivers. If that doesn't work, perhaps screen cannot use that resolution.
Jun 28, 2009 | HP Pavilion F1523 15" LCD Monitor
Signal out of range
1: Signal out of range meas the monitor can't handle the input refresh rate. lcd and Tft monitors usually supports 60 and 75Hz refresh rates.
2: The Resolution you are using to view the desktop is too high, this number is depending on the size of the lcd monitor.
a 15" lcd usually runs with: 1024x768 with 60hz
a 17" lcd usually runs with: 1280x1024 with 60hz some of them supports 75hz.
a 19" lcd usually runs with 1600x1200 or higher.
I recommend reading the user manual if you have it, or checking the information on the manufacturer's website.
3: As a solution turn on your computer and after it passes the bios screen press F8 and select VGA mode.
This will enable 640x480 (standard vga) resolution and 60Hz refresh rate, after windows boots up you can change thease nmbers , and windows automatically asks for turning to 800x600 60Hz.
If you want to change the resolution go to: Right click on your desktop, select properties , select settings tab, and adjust the resolution on the bottom of the window.
Hope this helps, good luck.
Nov 10, 2008 | Kogi L7CH Monitor
Cannot remove "input signal out of range"
input signal out of range would normally indicate the the screen resoloution is either too high or too low for the monitor to display properly.
is this on just one game? which version of windows do you use?
Jun 21, 2008 | Hanns.G Corporation HW191D 19" LCD Monitor
Input Signal Out of Range
I have been having the same problem with my hpvs17 monitor when i start to use my web browser on linux distros. Now, for the next few days i am going to try my system on a regular crt monitor. if the monitor does not crash, than i will have to say that the hpvs17 monitor has a defect.It seems that when i go online, while i am in the middle of searching something, the monitor just shuts off and i get "input signal out of range".
Jan 31, 2008 | HP Vs17 17" LCD Flat Panel Monitor
HP w1907 LCD Monitor Logo
2,752 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
