Question about Poulan Pro Chain Saw 46cc 20"
PRO 4000 I bought one used,I don't know the fuel oil mixture.your help would be appreciated
    Brigadier General:
  • 4,088 Answers
50:1 should work nicely. Be sure to use fresh fuel and a modern synthetic saw oil for the mix. Place the mix in it's own can and shake thoroughly just before each filling. Don't make up more than a gallon at a time unless the saw is used to make your living. Hope this helps!
Posted on Oct 16, 2010
  • 64 Answers
Id use a 40;1 oil/gas mix
Posted on Feb 23, 2011
Code p1128 weak mixture lose power on inclines engine light on melts spark plugs vehicle hyundia accent 2001
Go to www.hmaservice.com and register your vehicle by VIN #..
you'll then have access to wiring diagrams, shop manuals,
service bulletins, illustrations, etc. To diagnose a 2000 or 2001 1.5L Accent Diagnostic Trouble Code (DTC) P1128 (FUEL SYSTEM LEAN -- PART LOAD), check the following:
  • Check the intake system for air leaks.
  • Check that the Mass Air Flow (MAF) Sensor (P/N 28164-22610) operation meets the specifications listed below. If the MAF sensor output is significantly lower than the reference value (10% or more), then replace the MAF sensor.
Table 1: Using the Hi-Scan Pro in the Hyundai Diagnostic Menus Current Data Screen TPS (%) 0
3.5
5.1
7.4
MAF (kg/h) 10
21
30
47
RPM IDLE
2000
3000
4000
Table 2: Using the Hi-Scan Pro in the OBD-II Menus Current Data Screen TPS (%) 0
3.5
5.1
7.4
MAF (g/h) 2.8
6
8.5
12.7
RPM IDLE
2000
3000
4000
WITH MANUAL TRANSMISSION
Table 3: Using the Hi-Scan Pro in the Hyundai Diagnostic Menus Current Data Screen TPS (%) 0
2.4
3.9
5.9
MAF (kg/h) 9.5
19.4
28.8
43
RPM IDLE
2000
3000
4000
Table 4: Using the Hi-Scan Pro in the OBD-II Menus Current Data Screen TPS (%) 0
2.4
3.9
5.9
MAF (g/h) 2.5
5.5
8
12
RPM IDLE
2000
3000
4000
Jun 26, 2011 | Hyundai Accent Cars & Trucks
Chain saw runs great until I start cutting tree, then it stalls out. I've only used it three times since I bought it last month.
I would say its running too lean, start by replacing the fuel filter in the tank, check the fuel hose up to the carb for leakage, if this does not help unscrew the H screw on the carb 1/4 turn anti clockwise, this will richen the fuel mixture, does this help the running? if not there may well be a fuel blockage in the carb.
Jun 04, 2011 | Poulan Pro Chain Saw 46cc 20"
I bought a reconditioned Poulan pro PP4629AVX and I can't find a manual for it. What is the oil to gas mixture? Thanks Steve
The fuel-oil mixture ratio for all Poulan two-cycle products is 40:1. You can obtain this ratio by mixing 3.2 oz. of oil with one gallon of regular gas.
Sep 25, 2010 | Poulan Pro Chain Saw 46cc 20"
Do not know what mixture or how to use
40:1 mixture for the fuel:oil ratio.16:1 will cause your saw to barely run(if at all) and if it does, will fog out every mosquito for 4 blocks. You can use any reputable 2-stroke oil, though stay away from outboard engine oil. Get the good stuff that says Stihl, or Husquavarnah, or something like that. Even the Homelite stuff is ok. The oil tank takes regular bar and chain oil.
May 30, 2010 | Homelite ZR10926 16 Chain Saw
What is the fuel mixture for my new Poulan Pro 18'' chainsaw? It looks like 32:1 but not sure.Thanks! Don
If you use a mixture of 50:1 you can't go wrong.This is the industry standard and can be acheived by following the mixture guide lines one the bottle of oil.32:1 will make your saw smoke to the point of being almost unbearable and will foul the plug,so 50:1 is the mix your looking for.
Dec 15, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Fuel oil mixture
use a 32:1 mixture which is approx 4oz 2cycle oil to 1 gal of gas. you can also add an ounce or two of of a fuel sys cleaner to your fuel mixture for a good cleaning of the carb to remove any gum or varnish build up which could cause poor engine performance. hope this helps you
Aug 08, 2009 | Homelite Garden
Fuel mixture for antiqur Maytag engine
30:1 would be better.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 03, 2009 | Washing Machines
I would like the fuel mixture for my poulan chain saw. %oil,%fuel
If you don't know the model, then go with a 35:1 or 40:1 ratio. 40:1 seems common on most smaller saws from Ryobi and Poulan is a relation to those. The 35:1 suggestion is just for a little buffer in case. Generally it is ok to run a richer oil mix. It just means you may have to change spark plugs more often, however, your combustion chambers will be better lubricated and probably last longer!
Sometimes there is a little sticker or marking on the fuel tank cap or somewhere near it that indicates advisable oil:fuel ratio... Have a close look, it may be indicated somewhere on the saw itself.
Mar 13, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro Chain Saw 46cc 20" Logo
149 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
