Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
The washer made a horrible noise and the tub seems to be loose from the machine. Can I fix it? The tub in my Frigidaire stacked washer all of a sudden with a fairly heavy load of jeans started making a banging horrible noise, I shut it off and the tub doesn't seem to be attached. Did a belt break?
  • 1,531 Answers
You need to remove the agitator and check the bolts that hold the trunion to the shaft and make sure they are not broken.if one is just replace them make sure that the bracket is in the flat key way on the tub hope fully the tub seal is still good.
Posted on Oct 16, 2010
Testimonial: "Sounds like I need to call a repairmen. Thank you so much."
My washer make's horrible noise and it's leaks water out.
Posted on Jan 21, 2011
Fridigaire fwb9200es1 washer making rattling noise when spinning
Hello terilym - From what you have described it sounds like you possibly have foreign objects such as coins or safety pins in the tub or pump. I suggest unplugging the washer and carefully check the tub and to verify that the drum is also not damaged. If noise continues after washer is restarted, objects may be in the actual pump. Contact a professional to accurately diagnose and repair the unit.
Sep 30, 2012 | Frigidaire ATF6000ES Front Load Washer
Tub thumps after nail wedges through small hole bottom and stops tub
You could have an unbalanced tub or the piece is rotating around in the outer tub and making the noise. Contact a professional to have the machine taken apart if the noise continues.
Jul 28, 2012 | Frigidaire FEX831CS Top Load Stacked...
Starts Banging really ******* spin cycle, then quits... seems like the drum is loose.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Aug 12, 2011 | Frigidaire GLTR1670A Front Load Washer
My Frigidaire front load stacked washer/dryer makes a horrible noise and won't spin. It works perfectly except for the spin cycle
you need to remove the agitator take the cap off and remove the bolt from inside the agitator and then remove it look at the metal trunion in the bottom of the tub and see if there is a broken bolt holding the trunion to the shaft.there is a chance the transmission need to be replace if there is no broken bolt
Nov 03, 2010 | Frigidaire FEX831CS Top Load Stacked...
Washing machine makes a horrible noise in spin cycle and turns itself off. When we hold the Start and Cancel button together we get code E23.
Check out this tip I wrote about the noise and vibration that front load washers can make..
heatman101
Sep 04, 2010 | Frigidaire Affinity ATF6000F Front Load...
I have a top load stacked washer/dryer. my washer is out of balance and the tub is lose also starting to make a seaking noise.
you need to remove the agitator and look at the bolts that hold the tub to the shaft it sounds like you have one broken or loose.there is a slot on the sied of the shaft that the braket fits in and gets tightend to make sure it is seated properly.
Feb 12, 2010 | Frigidaire FEX831CS Top Load Stacked...
Dryer makes screeching noise..dries the clothes ..seems the tub is loose
at the top of the drum there is a felt pad with 3 white nylon glides attached to it. if this is worn, and it does wear, it will make a screeching noise like you described because it changes the postion of the drum and it will also appear like it is loose. you can purchase this part as a kit along with the glue to hold it on and it is not an expensive part. hope this helps.
Oct 14, 2009 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire was tub makes loud thump noise during spin cycle....
Need more information to make an accurate diagnosis, try removing the front panel (two screws at bottom) and visually check first the belt (all the way around) and then the springs that hold the tub suspended.
I would bet on the belt.
Quentin
Jul 22, 2009 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
648 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
