Question about Refrigerators
Maytag frig side by side door pops open when I shut the other side
MAYTAG DOOR (FREEZER DOOR )POPS OPEN WHEN I SHUT OTHER DOOR
  • TERN Jun 03, 2008
    You the man,thanks it worked
  • Anonymous Mar 25, 2014
    UNIT SHUTS OFF WHEN DOOR IS OPENED IF UPWARD PRESSURE IS APPLIED TO DOOR UNIT STAYS RUNNING
File a lawsuit against the manufacturers. this is a major design defect.
Posted on Jul 27, 2008
    Scholar:
  • 110 Answers
The ref. is not level or too much wieght in the freshfood door
Posted on Jun 03, 2008
My freezer door used to **** shut now it easily pops open
What you are talking about sounds like the magnets in the door seal are weak.
Mar 10, 2014 | Frigidaire Freezers
Fridge doors do not close completely
1st ckeck that nothing is sticking out just far enough to pop the door open.if not that, than the gaskets can were out on frig doors , you can order it on line from all appliances, get the model # from inside the frig , be patient installing it , its tricky, but it can be done by Harry homeowner. good luck.
May 04, 2012 | Maytag MSD2756GES Side by Side...
The freezer door pops open when the refrigerator door is closed.
You're going to need to adjust the hinges on your frig and/or freezer doors.
Your cost: $zero.
There's one hinge at the top of each door & one at the bottom. The hinges at the top are
covered by a triangular shaped piece of plastic that pries up easily with a screwdriver or tack
puller - remember to put down a thin piece of cardboard (as from a cereal box) to protect the
finish on the appliance.
These screws take a 5/16ths inch socket.
Check the screws holding the top hinges first, since they're easier to get to. If the hinges on
either door are loose, you've found the problem - align the doors so the frig door doesn't also
pop open the freezer door and you're done.
If the hinges at the top of the doors are secure, then your problem is with one (or both) of the
hinges at the bottom - probably best to adjust them after emptying the door(s).
These hinges also take a 5/16-in tool, but it'll have to be a combination wrench with a flashlight,
and you'll have to lay down on the floor to adjust these hinges.
Jul 15, 2011 | Maytag MSD2732GR Side by Side Refrigerator
Freezer door pops open
there's nothing wrong w/your dr seal. add a then layer of silcone or vaseline to the seal. this will make it sticky again.
Jul 14, 2009 | Refrigerators
Bottom freezer door opens when top door is open and then closed
the door pops open because freezer and frig. are connected together via duct. air pressure builds when you swing ref door closed. apply a small amount of vasoline to the surface of the hinge side of both gaskets. this will aid in door closure. also the unit may be not level
Jul 02, 2009 | Refrigerators
Freezer side door opens when large refrgerator door is closed
no promblem when you shut one door it forces air to the other side remove the kick plate at the bottom adjust the rollers till the fridge leans back i set them so when you turn loose of the door slightly past the halfway position it shuts its self that way when it pops open it shuts its self
Feb 15, 2009 | Maytag MSD2454G Side by Side Refrigerator
Freezer door won't stay shut
This indicates that you do not have good airflow and return airflow between your freezer and refrigerator sections. That is why the pressure from closing one door is causing the other one to pop open.
Check the drain tube on the back of the machine to make sure it is not clogged or blocked with frozen water inside. Also check any return air flow vents inside the unit for clear ice.
Jan 18, 2009 | Refrigerators
I have the exact same problem - very annoying. The only thing I found to work was to purchase one of those child safety locks. I bought the Kidco Appliance Fridge Lock S330 because it was the only one I could find that automatically relocks after you shut the door. Buy two (or more) at a time because the arm will eventually wear out and break (after several months depending on how often you use it). You can check out the product's details on eBay - that's where I purchased mine. Hope that helps.
Aug 27, 2008 | GE GTS22KBP Top Freezer Refrigerator
Kenmore doors getting air vaccum and will not open right away
  • that is just a sign of a very cold freezer and a good sealed refrigerator.
  • if you don't like it then turn your freezer down so it wont get so cold.
Jun 29, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer side door not locking shut
Mine has been doing this for over a month. Then on Friday it started making a clicking sound a CONSTANT clicking sound. I get home from a marriage retreat for families getting ready to be deployed and gee ALL my food in the fridge is BAD!!!!
My model number is ssh25kfrfww Please give yours. Also my door NEVER locked from day one. As my children are older I didnt think it was a big issue till today.
Apr 14, 2008 | GE GSS25SGSSS Stainless Steel Side by Side...
Refrigerators Logo
160 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
