Question about Samsung Computers & Internet
I have a SAMSUNG P28 Laptop. Screen stays blank no sounds. I have a laptop and when I plug it into the wall the wire less card light comes and the on light is blinking. But when I take all the hardware(DVD-ROM,Hard Disk Drive,and Battery) out the on light just stays on. The CPU gets hot and CPU fan spins. USB ports get power. Any ideas? Anton
5 Suggested Answers
techguyuk
  • 33 Answers
SOURCE: acer travelmate 292elcI problem starting
Hi, sorry to hear you are having problems. When this happens it usually suggests that the CPU/system board has failed. If the laptop is still under warranty I would suggest taking it back because this is something that will be covered and they should be able to fix it or replace the laptop itself. If not you may have to pay to have the system board/CPU replaced. Good luck and hope this helps. Si :)
Posted on Sep 26, 2007
  • 1019 Answers
SOURCE: Acer Aspire 5010.. Power on, but Blank screen/ hard drive light also not.
This could be a Power/Switch Problem.
Faulty Hard-Drive.
Solution:- Leave the laptop turned Of And charge the battery to Full Capacity. ( usually between 4-16 Hours ) depending on capacity.
This will also fully charge the CMOS ( memory battery )
then boot the laptop up, and see if this solves your problem.
If not i,d suggest running a scandisk or hard-drive diagnostic program, to ensure that you have no Viruses-bad sectors on the hard-drive.
If you need further assistance please don,t hesitate to ask for more help and advice.
Mike @ Compurepair.
Posted on Feb 24, 2008
  • 10406 Answers
SOURCE: Gateway T-1625 Laptop won't boot up - screen blank
Yes, if the CPU/motherboard will not POST (Power On Self Test), then changing the CPU is the only thing that you have not tried.
Posted on Sep 10, 2009
  • 10 Answers
SOURCE: HP ZE2000 blank screen on start up.
you need to change the lcd inverter card of your note book
Posted on Oct 21, 2009
Blank Screen , Power light comes on and all lights right under screen (sound and media playerand touch pad lights) come on and stay on. disk drive works and no secondary monitor display.tried the battery...
If you have checked all functions as you described and a remote monitor, then the problem is the graphics card on the motherboard, in most cases the motherboard must be changed because the graphics card is built in.
May 13, 2011 | HP Pavilion dv7-1130us laptop
Hi...after swithcing on my dell laptop i am able to hear the soud (bo0t)...but i am not able to see anything..its showing a blank screen and i am not able to see mouse pointer also...please help me with...
There may be many different factors here. Lets start with the basic and work up from here.
1. Pull the battery and unplug the laptop from the wall, wait for 10min and replace battery and plug into wall, Does is start up?
2. When you hit the power button to start the laptop you said that there is a beep but that is it, Do the Hard drive indicator light blink/stay solid while this is going on?
3. When you start the laptop and after it beeps try to take a flash light and shine it on the screen, Do you see anything?
Let's start here and then go forward.
VCS Techs
Sep 22, 2010 | Dell Inspiron 640m Notebook
When i press the on button the fan comes on but the screen stays blank
Do the lights on the media bar of the laptop also come on when you switch the laptop on?
Also, have you tried plugging an external monitor into the DVI monitor output on the machine? If so, was that also black having toggled the monitor (Fn + F4 I think).
If so, there is a chance the graphics card on your amilo is faulty. If you could provide some more info, I should be able to assist further.
Hope this helps.
Jan 24, 2010 | Fujitsu Siemens AMILO Xi 1546 Notebook
P28 laptop blue screen it starts up with the windows logo then shuts down
hello
i have problem my laptop no work and i search laptop P28. i want buy model laptop P28. i need in changer block mainboard for loptop P28
If you can me help. please help me. i buy old laptop Samsung P28
hope you help me
Thank you
my e-mail: Live29@yandex.ru
Sep 24, 2009 | Samsung V25 XVC 2800 Notebook
I have a HP pavilion Entertainment laptop and recently the screen went blank while the power was still on. I restarted and the screen continued to stay blank. I then turned the laptop off and unplugged it...
The connecting data bus between ur laptop monitor and ur motherboard has either been at fault or else there has been some problem with the wire connection between the two......i.e it has been loosen up....
Get ur laptop checked from the hp representative and if possible get ur laptop insured under different laptop policy schemes.....
With Regards
Abhineet Raj
Jul 29, 2009 | HP Pavilion dv2000 Series Laptop Full...
Blank Display, using exernal monitor, can see display info w/flashlight, display flashes light at startup
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 03, 2009 | Toshiba Satellite A135-S4407 Notebook
Indicator lights on Samsung P28 computer
can you be a little more specific..do they have symbols on them?
Oct 14, 2008 | Computers & Internet
The hp altec lansing laptop wont turn on, you press the power button and you get this flashing electric looking icon that comes on and it's pluged into the wall. what could be the problem?
my hp altec lansing laptop doesn't opwer on, the button lights up for 1 second and then shuts down,nothing happens to the screen, it stays blank
Aug 27, 2008 | Sony VAIO R505JL Notebook
Computers & Internet Logo
212 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
