Question about 474L TX 4-Button Replacement TX Remote
How do you change the battery in the remote of a avital car starter
jpk528
  • 95 Answers
SOURCE: I have a 1998 Chevy cavalier with Avital 3200
it sounds like its the bypass module. When it doesnt start the car goes into security mode and wont let it start for up to 15 minutes. I would check the bypass module to see if it still has power or has been reset, if its not something you can do, bring it to a local mobile electronics shop and they should be able to take care of it for ya.
Posted on Mar 03, 2009
  • 171 Answers
SOURCE: AVITAL 4103 REMOTE STARTER STARTS BY ITS SELF
Check the alarm program it shoudl be programing to turns it On every 2 hours, or if you have a temperature sensor should be programed to turns it On when is too cold.
Posted on Jan 05, 2010
logosc75
  • 625 Answers
SOURCE: can an avital 4113 remote starter be installed in
Yes, just program the wait to start to 15 seconds.
Posted on Sep 16, 2010
logosc75
  • 625 Answers
SOURCE: We had the Avital 4003
You mean the igniton powers up but it does not start, correct? Sounds like the remote starter is not sending power to the starter. Did it ever work? It's possible that one of the 30amp fuses (one that supplies power to the starter output of the remote starter) is blown. If there is 12 volts present, check for voltage at the starter wire (purple) from the remote starter. If it has voltage,make sure it's connected. Also make sure that the harnesses of the remote starter are completely plugged into the module.
Posted on Sep 26, 2010
SOURCE: my avital 4113 car remote
DEI sent out a recall on a batch of theit antennas for this sysetm that were remote starting the car by its self. If you call customer service they will send you a replacement antenna and this sould fix your problem.
Posted on Jan 26, 2011
2002 cavalier, ignition cylinder was changed for pass lock failure now remote start cranks but wont start. avital 4103L
Hi, ur problem is a simple one. U have a factory alarm-starter kill. The key and ecm have to comunicate. Ur alarm has a digital modual to make the ecm think its seeing the key when u remote start. Since u changed the "code"u have to reprogram your alarm interphase so it all comunicates the code.
Nov 28, 2015 | 4103LX Remote Start System with Two...
My car battery went dead and tried to start my car a few times but it wouldn't start.I jumped start the car and battery is good now but;my Avital remote starter won't start the car anymore.
when u jump started, and may I add here one must NEVER jump start modern cars without appropriate special jumper leads, as doing so often glitches the cars computer and or resets settings memory etc?, requiring it to be reprogrammed by local car dealer mechanic no real other way, then u need to recode yr remote back to the car get a manual.
Aug 21, 2015 | Avital Vehicle Parts & Accessories
Ford f150 Avital 4103
You can put an amp meter on the battery, an amp clamp meter is easier and safer or a multimeter with 20 amp rating or better, find remote starter unit, find fuses for unit red wire on most starters is 12 v constant, you can put amp meter between the Avital fuse but there may be multiple Red wires or run the ampmeter on the battery + terminal through the ampmeter, DO NOT START THE CAR with the meter connected, just hook it up and close all the doors and wait 2 hours for all the car computers to reset and idle, record your amp readings, its tough to say what your truck actually drains per hour, I am guessing under 60ma is ok, remember when you open the car door you will activate the SJC computer "smart junction box in most Fords and it will drain current for a little while, disconnect your Avital and then see what the current is after an hour, remember most Digital volt meters shut off now after 5 minutes and you have to push buttons or flip knobs to activate them, doing this may disturb the current reading tests because you might open the circuit , try an old analog amp meter if you can find one.
Mar 01, 2014 | Avital Vehicle Parts & Accessories
Need to program additional fob to Avistart 4111
Turn ignition on, press and release valet switch then, press and hold valet switch. Press button on remote. Release valet switch, turn off ignition. Test
Feb 08, 2014 | 4111 4111L Remote Car Starter
5103 Not working after dead battery
Your vehicle requires a data/immobilizer interface that controls the door tirggers, brake shutdown, remote starter sequence, etc. When you lost power, the interface lost programming. it need to be reset.
Feb 04, 2014 | Avital Vehicle Parts & Accessories
Avital 473L TX will start and keep the starter engaged
Sounds like the ignition or accessory output from the remote starter is connected to the starter wire. Has it always done this?
Mar 06, 2013 | Avital Vehicle Parts & Accessories
My avital 477l starter has some Zs by the car and it won't let me set my alarm. How can I restart starter?
The Zs mean that the alarm is in valet. To exit valet with the remote: open any vehicle door, press lock,unlock,lock. The zs should disappear from the remote allowing you arm the alarm.
Feb 16, 2011 | 477L Ask RXTX HHU Remote
I got avital remote control starter and the car cant star
What kind of vehicle? And did you wire it into the alarm? If you reply with a vehicle year and model I can give you the wiring diagram.
Jan 13, 2010 | Car Audio & Video
474L TX 4-Button Replacement TX Remote Logo
437 people viewed this question
Top Avital Vehicle Parts & Accessories Experts
D. E. Hev
Colin Stickland
Colin Stickland
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
