Question about MotorGuide Motg W 75 Wireless 60"
Motorguide w75 trolling motor will attempt to steer but seems to not geting enough power. batteries show full charge. what advice can you give me?
Plastic steering gears are probably stripped. Metal gears are available, and are easily replaced. Contact me at groshartl@gmail.com
Posted on Feb 06, 2011
My motorguide x15 trolling motorjust wants to spin around .. it has a remote foot control
Define 'wants to spin around'?
The propeller motor is supposed to spin around :>)
If the whole motor unit is spinning around you need to clamp the motor stem.
For factory support, you can get that from the website.
Xi5 Trolling Motor Xi5 Wireless Trolling Motor MotorGuide
Jul 19, 2016 | MotorGuide FW71 FB Freshwater Series...
My trolling motor stopped working suddenly. It is a 96 motorguide 56. It is completely charged. What else do I check. I check 5 fuses by the battery as well.
First you need to check to see if power is getting to the motor. If power is not getting to the motor, then check the battery. If you are getting power to the motor, then troubleshoot starting with checking to see if power is getting to the foot pedal. From there check the switches, and make sure they all have power. If they do, then most likely it is the brushes which could be worn on the powerhead itself.
Jun 02, 2011 | MotorGuide FW40 FB 42" 12V FLXMT Trolling...
I bought a W75 wireless trolling motor at an auction. It sold as new and still in the box. There were no owners manual with it or any other papers like warrany papers and the such. Everything looks new...
there is no warranty for second hand goods sold as new or not
is the battery for the unit connected correctly a sit needs it's own to work besides the battery for the remote unit
is the receiver in the unit switched on to receive the remote control signal
try going google and typing in -- operator's manual for ( make and model ) trolling unit ---and downloading any pdf versions available
Apr 24, 2017 | MotorGuide Motg W 75 Wireless 54"
How do you reset remote for w75 wireless trolling motor
Its very easy:
Reprogramming the Wireless Foot Pedal or RemoteNOTE: This activation procedure applies to the foot pedal and remote.
IMPORTANT: To activate multiple foot pedals or remotes, the motor must be unplugged from the power source and then plugged
back into the power source between activating each control device.
1. Unplug the battery cables from the power source. Wait 30 seconds and then plug the motor into the power source.
2. In less than ten seconds, press and hold the "+" and "-" buttons on either the handheld remote or the foot pedal controller
simultaneously.
May 07, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
My Motorguide W75 trolling motor has a single black wire in the receiver case that is detached at one end. I need to determine where to connect it?
That is probably the antenna for the RF remote control system. Is there a connector on the end of the wire? Contact me at groshartl@gmail.com
Sep 07, 2010 | MotorGuide Motg W 75 Wireless 60"
Recently purchased a used 74# Maxxum 24 volt trolling motor to replace the 46# MotorGuide I had. It doesn't seem to be getting enough power it runs slower than the 46# Motorguide. Positive from motor to...
sound like either voltage drop or hi resistance from cables... if you test 24v at the plug then resistance is the problem and may have to rewire to a 6ga wire to carry the load, pretty simple just hook the new cable to the old one and SLOWLY pull it thru, help may be required because you dont want to loose it half way.....hope this helps...GL
Jul 03, 2009 | Boating
Foot pedal on Motorguide is out of time with steering...
There should be a couple of allen screws on the shaft that you can loosen, which should allow you to swing the motor head in the direction you want it to be pointing for the desired pedal position. Tighten and carry on.
Jun 01, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
New MotorGuide VariMAX trolling motor does not run
The motor should work without the circuit breaker for a test. The breaker is a safety device to protect the motor and wires if something malfunctions.
May 23, 2009 | MotorGuide Electrical Supplies
MotorGuide Motg W 75 Wireless 60" Logo
1,307 people viewed this question
Top MotorGuide Boating Experts
Mike
Phil Walker
Phil Walker
Angel Joseph Jr.
Angel Joseph Jr.
Are you a MotorGuide Boating Expert? Answer questions, earn points and help others
