Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I start the engine and it sputters at fast idle and then eventually shuts off.
  • 110 Answers
I think that after you start the engine you need to move the throttle lever off what you are calling fast idle (which is full choke). Simply slide the throttle lever down until it smooths out and runs properly.
Posted on Oct 25, 2010
I recently purchased a 1987 toyota celica gt-s. I am dealin with an idle problem/loss of power. Just recently it started acting up. At first it was only happening when i was shifting into second. Shifted...
Check for code there is a small electric boxe may be 1 inch by 1.5 inch you have to jump 2 wire to get code at dash (long blink digit and fast blink unit)
May 04, 2014 | Cars & Trucks
1995 geo tracker sputters and stalls and wont idle
need more input. (8valve or 16valve engine , which option?)
black top engine , or silver 16)?
does it fail, cold or hot engine or both?
does it have full power from engine , at all speeds and loads (hills)?
and wide open throttle power.?
ever do the 60k tune up, not just a fuel filter?
http://www.fixkick.com/IGN_timing/tune-ups.html
how old is the fuel?
the pump/reg holds 34-43 psi.at all times...running.
sputter, from too low RPM ? below 800
or idle fast, but sputters at 800 and more?
if the latter, that is called misfire.
if the former that is lost of idle controls.
need to now which engine. because the are worlds apart.
EFI wise !
but here is a page on misfire. "sputter"
50 reaons and more causes.
we dont guess, we do about 5 tests and bingo....
http://www.fixkick.com/misfiring.html
when was the last time it ran good,?
Jan 16, 2014 | 1995 Geo Tracker
1998 Honda Accord engine rumbles and stops
rumbles?, did the RPM drop below 800 RPM? that is called idle failure
and when it does, idle can go to 400 rpm and will shake hard.
and is normal for illegal idle speeds. so post that first.
post that engine stalls
and that the RPM is 400-500 just before the stall.
then post if the fast right foot can save the stall (a key test !!!!)
if easy the ISC is sticking.
if tad hard the EGR is stuck open'
if impossible to save. then more possible (many)
ever do the 60k mile tune up this decade????,. if not why not./ now.
Dec 08, 2013 | 1998 Honda Accord
1981 John Deere 1050 Diesel Tractor - Engine will go to high idle by itself. You can shut key off and engine will eventually die. What would cause the engine to high idle? Afraid engine will lock up.
There are 2 types of governors on diesels. one is controlled from the foot and is fixed speed at the foot setting. The other is variable speed which will run to high idle if the setting is not changed IE on start it will idle ok but if you use a fast setting on a hand throttle say to warm up the motor it will run to high idle. I suggest that if you have not had a problem before then you should have a diesel pump specialist look at it as there may be a fault in the governor control.
Jun 23, 2013 | John Deere Tractor Side Screen...
Jeep Grand Cherokee shuts off at idle while stopped. RPM fluctuates then engine eventually dies.
your idle air control valve is going out located behind the throttle body.
Feb 12, 2013 | 2001 Jeep Grand Cherokee
I have a 96 Chev. Beretta, and hard to start with sputtering and sneezing after misfire. and then will eventually start but very high idle speed.
If the check engine light is on I would check it for trouble codes first.
The high idle could be a vac leak or faulty idle air control valve.
Jul 27, 2012 | 1996 Chevrolet Beretta
My 9N is having trouble starting. It turns over fine but seems to be flooding. When it finally sputters to a start, it takes a while to run smooth. Also the idle seems to be fast and there is no change in...
Shut off fuel to carburetor, drain carburetor. Open fuel and count to three then shut off fuel. Crank engine then pull choke for 1 second then push in. If engine starts open fuel valve at tank. Also try lowering float level in carburetor. Good luck.
Jun 26, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
291 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
