Question about Goodman GMS90703BXA Heater
I have a goodman natural gas furnace model # gms950703bxa wont turn on replaced thermostat has power to unit but doesn't start and no red light what could be problem
  • 40 Answers
Check the on board fuse and make sure the transformer is putting out 24 volts
Posted on Mar 29, 2011
How do i reset power to thermostat from amana furnace is there a reset for controls?
The manual says it should automatically reset. However to manual reset the unit it says to "interrupt" the power supply. --which I think means unplug/turn off electric to unit for 20 seconds. If you do not have the manual go the manuf website and download it. --Also, this is a Goodman unit. If it does not reset something else it wrong that is preventing the unit from starting for safety reasons.
Sep 01, 2014 | Amana GMH81405DN 140,000 BTU 80% Gas...
Gms81005cn furnace will not light, red light on board not on. Please help!
Is your unit plugged in? Check the breaker in breaker box in the house. Does the fan come on? Is your door switch on the unit pushed in it is located in the fan section on the unit just a push button. This sounds like a power problem. Turn on the fan switch to ON on the thermostat to see if it runs this will tell you if you have 24 volts to the board. If it doesn't run then you have a transformer problem or a board problem. I hope this helps
Oct 20, 2013 | Goodman Manufacturing Goodman GMS81005CN...
Furnace will not light,on Goodman Furnace model#GME80704BX
Is the gas turned on or does it come on but goes off quickly?
Oct 06, 2012 | Cozy Enclosed Front Console Heater 70,000...
I turn my thermostat to the HEAT position, I hear the Thermostat click and the Furnace begins to hum but no air comes out of the vents. Also if i turn the fan to the ON position air will come out of the...
need to go to furnace and watch it...if your hearing a hum the enducer draft motor may have failed...it should start first if there is no fault codes...reset unit by unplugging furnace or in some cases turning power switch off...turn thermostat on heat and watch unit ..the small enducer draft motor should start first the a ignitor glows and the should light...goodman units have a control board with a light on control board when it fails should flash a code and on the door or inside on lable should give you what that code is...hope this helps good luck
Jan 07, 2011 | Goodman GMS90703BXA Heater
Goodman furnace model # GMNT100-4B On vacation neighbor checked house house filled with gas. He shut off main and furnace. Came home turned on gas to everything except furnace. All good. Furnace will not...
from my experience with goodman units ,it could have been a gas supply problem there are so many protective sensors that i dont think it is the unit by the way is it electronic ignitor or pilot
May 14, 2010 | Goodman GMS90703BXA Heater
I have an goodman model gsc130241ae unit will not
Hello Does the thermostat have a display?Check emergency wall switch and curcit breaker all on.Fan on should at least run if power.
Mar 31, 2010 | Goodman CLQ36AR49 Air Conditioner
My Goodman furnace wont light.
Open up the unit to get to the control board. Make a short jumper wire and disconnect the wires going to R and W terminals on the board. Connect the jumper to R and W. Depress the door safety switch. The circuit board should indicate a call for heat and the furnace should start. If it doesn't, look for a fuse that may have blown either on the circuit board or in the wiring. If the unit started by jumping the W and R but does not when you reconnect the thermostat, you either have a bad thermostat or a bad thermostat wire.
Dec 02, 2009 | Goodman GMS90703BXA Heater
Have a goodman furnace wont fire check light staying red no errors and i cant smell gas but my gas is on could it be there limiter switches there two upper and lower please help
Probably not, take a small piece of wire and open up the furnace. On the control board find the R and W terminal. It's ok to touch the terminals because the door safety switch will be open. Take that small piece of wire and jump the R and W terminals. Then hold in the door switch to see if the furnace starts. It may take 30 seconds or so so tape the switch closed. If the furnace starts you have either a bad thermostat, broken thermostat wire or a lose wire. If it still does not operate, you have a bad circuit board.
Oct 16, 2009 | Goodman GMS90703BXA Heater
Goodman furnace
double check your wiring. R terminal on the furnace will provide 24 volts to the t-stat. W terminal in the t-stat will send 24 volts back to the furnace W terminal to turn on the heat. G terminal in the t-stat will send power to the G terminal in the furnace when the t-stat is switched to fan on. Y terminal in the t-stat will send power to the Y terminal in the furnace which in turn will send 24 volts to the A/C outside. The C terminal in the furnace should be connected to the c terminal in the A/C outside as well as to the T-stat. Check the fuse again
Jun 02, 2009 | Goodman GMS90703BXA Heater
Goodman GMS90703BXA Heater Logo
100 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
