Question about EverFocus EDR410H500
Everfocus EDSR100H Unit displays no disk with hard drive installed
2 Suggested Answers
  • 50 Answers
SOURCE: formatting disks for EDSR1600
The EverFocus EDSR Security DVRs use standard PC Parallel (PATA) hard drives. I have used ATA100 and ATA133 speeds with no problems. There are no PC-type settings required except as below. The DVR has it's own internal firmware and will format the drive to its requirements.
If you are using a SINGLE drive tray, the largest hard drive I know will work is 500 GB. Set the drive to Master and you are done with the hardware setup. (CS Select would also probably work.)
If you are using BOTH drive trays, the largest hard drive EverFocus says will work on the EDSR100 or EDSR110 is 320 GB. Set both drives to Master and you are done with the hardware setup. (CS-Select on both would also probably work.)
Do NOT set any drive to Slave!
Lock the drive trays; if you don't the DVR will not go into record.
Press the STOP key and then press the MENU button. Go into the SYSTEM menu and do a DISK RENEW. This will erase the hard drive and also prepare it for DVR recording.
Do this by using ► or ◄ to select DISK RENEW. Change NO to YES (by using ▼ or ▲) and press the ENTER button. Highlight YES again by using ► or ◄ and again press the ENTER button.
Press the MENU button to exit and reboot the DVR. Then press RECord and you should be recording.
Posted on Dec 03, 2008
Formatting disks for ecor4f
The only way to fix a disk failure is to replace the hard drive. Once hard drive is replaced, if the unit doesn't give an on screen display
stating 'new hard drive detected: format now?' go into the menu
, to the disk section, & select 'format'. Problem should be resolved.
Samuel Morris
Camtek Of NY Inc
Oct 01, 2014 | EverFocus Home Security
I want to find a good app to open copied video from everfocus home security cameras
You can use restore to take the computer back to a date that you know that it worked. You can use right click and open with to set the program, you can reinstall everfocus. You can manually set the file associations.
Dec 19, 2013 | EverFocus ECOR264-9X1/2T ECOR264 Series 9...
M Brand new DVR doesn't recognize its SATA hard disk? I have confirmed there is power on Hard disk. when it was not working. I format it by using windows 7 and reinstall it . what the reason?
is this the hard drive you recieved with the DVR? it is possible that the HDD is set up in the wrong format. windows sets up your HDD in a NTFS format which is compatible with most DVR's but i know there are some EverFocus units that read the HDD in a diffrent format. if this is the case you need too check in your owners manual in the HDD section, it should tell you what format it records onto, then place the HDD in your PC and reformat it to the right one.
Nov 03, 2013 | EverFocus EDVR16D1/500 16 Channel, 120...
Hard disk is not detecting in my dvr
My sea gate 500 GB portable hard disk not detecting on computer
Mar 22, 2013 | EverFocus ECOR26416X1500 ECOR264 Series 16...
Xp installation problem
“No Hard Disk” error displayed on XP install (SATA drive versus ATA/IDE drive) The two most most popular types of hard drives in personal computers are ATA (also known as IDE hard drive) and SATA hard drives. Many newer computers have SATA hard drives installed, but your computer may have either an (older design) ATA/IDE hard drive or a (newer design) SATA hard drive installed.
After removing Vista, when you reboot your computer, a “No Hard Disk” error may be displayed if your computer has a SATA drive installed. To fix the “No Hard Disk” error, you may need configure your computer’s BIOS settings so that it can recognize the SATA drive installed in you computer. Reconfiguring your BIOS is typically not required if your computer has an ATA/IDE hard drives installed.
Step 1: Activate your computer’s BIOS menu. The first or second screen your computer displays on status may display which key (or keys) you must press to activate your computer’s BIOS menu. You can also look in the index of your computer’s manual for “BIOS” or you can try passing the [Del] or [F1] key when text is first displayed after powering on your computer.
Step 2: BIOS menus vary by computer, but there are seldom more than a few menu categories. Review the “Main” and “Advanced” menu categories to locate your hard drive setting. When you locate the hard drive setting, be sure to note the original drive setting in the bios so that you can restore the original drive setting if your new configuration doesn’t work.
Step 3: Change the drive setting to “IDE,” then save the BIOS settings (usually by pressing the [F10] function key then restart your computer.
If changing your BIOS hard drive setting to IDE doesn’t work, return to step one and restore the original hard drive setting
If it is ok , Please vote for me...!!!!
May 31, 2010 | Computers & Internet
EverFocus EDSR1600/500: system loading message stays
More than likely the small fan inside has burned out. Now both of your hard drives are fried. So replace the little fan. And install one working hard drive. Ive had to do this a few times. Ask a computor friend to help you instead of sending it in.good luck
Jan 30, 2009 | EverFocus EDSR1600/500
Formatting disks for EDSR1600
Aug 09, 2008 | EverFocus EDSR1600 16 CHANNEL 160GB...
EverFocus EDR410H500 Logo
144 people viewed this question
Top EverFocus Televison & Video Experts
Electro Med Services...
Are you an EverFocus Televison and Video Expert? Answer questions, earn points and help others
