Question about Compaq Presario 700 470024-192 Notebook
Compaq c700 monitor flickers when you try to open it and at about a 30 degree angle it is ok
5 Suggested Answers
Paeroa
  • 457 Answers
SOURCE: Screen problem
Perhaps your connections on the inside have come loose. It may warrant you take it to a specialist to check it over before it gets any worse. Some other person was on here some time ago who had a similar problem and all it was is the switch in the lid. Apparently they tinkered with it by just kept on pushing it back and forwards as if to continue to open it and it came right they tell me that they hardly used it thats why!.
Posted on Oct 02, 2007
SOURCE: compaq presario c700 dvd drive does not open sas
error when opening dvd rom
Posted on Aug 06, 2009
  • 285 Answers
SOURCE: Laptop monitor flickering, resolution off
THe flickering and off resolution may be a software problem. Try rght-clicking yor desktop, select properties, go to settings, then set the resolution to the highest possible. If that doesn't help, it's a hardware failure, (unless you recently installed any drivers or did anything out of the ordinary, please let me know if you have)
and we'll have to troubleshoot a little.
First connect another monitor to the laptop. If that flickers too, your graphics card (or chip, if you have on-board video) is broken. You'll then have to have the motherboard (or graphics card, if you have one) replaced.
If the other screen functions correctly, either your monitor cable or the screen itself is broken.
You can try opening the laptop case, reattach all cables into the monitor. (on both ends, if possible) If you can't reach the cables or it doesn't help, you'll have to have the monitor cable or the screen itself replaced, or both.
I hope you can solve your problem,
Yannick.
Posted on Dec 09, 2009
  • 59 Answers
SOURCE: Compaq Presario CQ50 notebook screen goes fuzzy
it sounds like you've damaged the cable that goes from your graphincs card to your screen or when you move it to 90degrees it's disconnecting. it's usually caused by someone opening the laptop and not putting the cable back in the right place, or loose screws in your hinges or a broke hinge. there are plently of videos showing how to open it up. follow one of them and make sure your wires are sitting in the right place, you don't have loose screws and the hinges aren't broken.
Posted on Jan 15, 2011
Sin 43 degrees 30'
Press SIN 4 3 2ND [ANGLE] 1 3 0 2ND [ANGLE] 2 ENTER
2ND [ANGLE] 1 gives you the degrees symbol, 2ND [ANGLE] 2 gives you the minutes symbol. If you need seconds, use ALPHA ["] (on the + key).
Note that this usually won't give you an EXACT value, but only a ten-digit approximation.
Dec 05, 2012 | Texas Instruments TI-84 Plus Calculator
A scalene triangle has side measuremnts a=43, b=55, c=30 . Angle a plus Angle b must equal 43. Angle b plus Angle c must equal 55. Angle c plus Angle a must equal 30.
Answer: angle a=9 degree angle b=34 degree angle c=21 degree Explanation: we have, a+b=43............(1) c+b=55..............(2) c+a=30..............(3) from (3) we get, c=30-a...........(4) substituting value of c from (4) in (2) we get, 30-a+b=55.........(5) a+b=43..........(1) (5)-(1) give 30-2a=12 30-12=2a a=18/2=9 degree giving value of 'a' in (1) 9+b=43 b=34 degree similarly giving value of 'a' in (3) c+9=30 c=21 degree
Oct 14, 2012 | TOPICS Entertainment Snap! Geometry...
Monitor flickers at start for 20-30 seconds, then everything is ok.
Either a dying backlight or bad internal connection. If under warranty, RMA it with place of purchase. If not, you can try opening it up & tightening any loose connections then reassemble & test. If problem still persists, replace the backlights.
Nov 29, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Yannick.
Dec 08, 2009 | HP Pavilion dv9000z Notebook
No display c700 compaq
perhaps the resolution is set to a value that the monitor cant display (try other monitors) or if using windows tap F8 at start up and start in SAFE MODE this will start the display driver in minimal resolution and if alls ok you should see a picture
Jul 14, 2009 | Balance CP4401 PC Desktop
Outside corner one side 30 down [ crown moulding ]
If the corner is to be 90 degrees than all you need do is set the compound angle on your chop saw at 15 degrees to get the 30 degree down side. If you cut only one side the thickness will be different at the joint so you have to spit the angle. Boy now you got me going. Tomorrow I'm going to be trying this cut in the shop myself. Good luck.
Apr 05, 2009 | Saws
Screen flickers for about 20-30 seconds sporadically
Try looking at the LCD screen at a sharp angle to see if ghost-like video can be seen during the 'off' time of the flicker.  If video is still present even though not that visible, then either the backlight or its power supply are failing. The color problem could also be caused by a backlight lamp that is not ionizing completely.
Dec 14, 2008 | Acer AL1912B 19" LCD Monitor
Compaq laptop c700's mic is not working (sound setting is ok)
My laptop model is compaq presario c754tu, I have installed Windows Vista Business, and the audio is working fine, but the internal mic and external microphone both work together........i want to mute the internal mic..... how i can do it ? please reply me on my email id i.e. vsdoshi@gmail.com
Jun 28, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq monitor
OK your monitor is failing in the Horizontal circuitry.... OR the PSU is failing to supply the correct Voltages. Either way it is probably going to fail completely soon. With monitors so cheap now, here in NZ they are about NZ$20.00 - $50.00, repair isn't adviseable to do so, it would make more sense to put the Repair monies into a NEW screen... maybe time for an LCD?
Jul 22, 2007 | Compaq fs740 17" CRT Monitor
Compaq Presario 700 470024-192 Notebook Logo
108 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
